Little wheel stand action from my Dakota R/T #2157954
09/20/16 05:49 AM
09/20/16 05:49 AM
jacksonville,FLORIDA
slammedR/T Offline OP
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2157962
09/20/16 07:37 AM
09/20/16 07:37 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
looking good ,did you get a clean pass ,what did you run
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158027
09/20/16 11:49 AM
09/20/16 11:49 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
YIKES! That looked violent! I am not a huge chassis guy (hence some of my struggles recently) but I was told that the fastest passes are the ones that look the slowest (smoothest). My analysis is your rear shocks are too soft on the compression and you could use some front limiters ??
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158040
09/20/16 12:07 PM
09/20/16 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a 727.. if so that move backing up and
just pulling forward a few inches is a bad move.. you
dont set the sprag doing that
wave
Re: Little wheel stand action from my Dakota R/T [Re: MR_P_BODY] #2158044
09/20/16 12:19 PM
09/20/16 12:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
wave
1st thing I thought too then how violent the chassis is..........w/work it will fly...........
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158050
09/20/16 12:24 PM
09/20/16 12:24 PM
an8sec70cuda Offline
Gonna fly when you get it sorted out!!!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158249
09/20/16 07:42 PM
09/20/16 07:42 PM
it needs a bar change, it has to much squat in the rear and I'm pretty sure the rear shocks are too soft as they are just a set of single adjustable strange coil overs. Also I already plan on front end limiters, you have to make a pass to see where you need to go with a four link.
I have a Coan racing billet trans brake valve body with low band apply. the rolling forward was all due to my lack of experience with a trans brake, I have always foot braked the truck till last Saturday.
racemagnum
Re: Little wheel stand action from my Dakota R/T [Re: MR_P_BODY] #2158251
09/20/16 07:43 PM
09/20/16 07:43 PM
wave
I made a boo boo staging, that is why I backed up, waited on the other guy, then rolled back in. Any advice on staging with a Trans brake will be appreciated.
racemagnum
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158261
09/20/16 08:02 PM
09/20/16 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Trans brake is easy... just ALWAYS be rolling forward
so it sets the sprag.. IF you back up make sure you roll
in forward ABOUT 4' to set the sprag... when you hit the
prestage light bring up the revs to about 1500 or more..
(some trans brakes will creep if you arent up in the rpm
some).. creep in to set the stage light(try to always be
the same location).. then hit the button.. it MIGHT roll
back and forth if your moving when you hit the button(slack
in the drive train).. then get the revs and be ready
wave
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158277
09/20/16 08:23 PM
09/20/16 08:23 PM
Houston, Texas
Houston, Texas
Mike, you really have to roll it forward 4 feet if you had to back up to set the sprag? I have never had the issue but just in case.... Or did you mean about 4 inches?
Also, as hint, I like to pre-stage first and wait for the other to pre-stage so as soon as he does, I can be ready... Sometimes the lights can be quick (so it seems with autostart).
But with more experience, I guess it will come as second nature.
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158278
09/20/16 08:24 PM
09/20/16 08:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Cool ride, keep up the good work.
The trans break is a different animal.
Re: Little wheel stand action from my Dakota R/T [Re: TheOtherDodge] #2158287
09/20/16 08:41 PM
09/20/16 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I meant ABOUT 4 FEET.. I found out in my driveway teaching
my new driver doing burn outs.. 2 feet forward didnt set it
and it was easy to see that it didnt set... was REAL slow to
accelerate(spin the tires).. as soon as I seen he wasnt spinning
I shut him down then had him roll forward again
wave
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158327
09/20/16 09:43 PM
09/20/16 09:43 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I agree with Mr P....you need to roll forward about 4 feet to make sure the sprag is set. Looks like you were at Gainesville.
Nautilus Racing-
Re: Little wheel stand action from my Dakota R/T [Re: Chris2581] #2158342
09/20/16 10:00 PM
09/20/16 10:00 PM
Um, it says SGMP in the video title......
racemagnum
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158383
09/20/16 10:51 PM
09/20/16 10:51 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not sure how far forward you have to go to set the sprag. But that vid shows how Not to go down the track. Sloppy and not alot of control. Okay, a little harsh, but get it under control and you have a great ride. She's a beast alright. Get her tamed and in control.
Re: Little wheel stand action from my Dakota R/T [Re: Sport440] #2158401
09/20/16 11:08 PM
09/20/16 11:08 PM
Don't hurt my feelings none, but since this is the first pass in the truck in two years and with an all new engine and nitrous combo in it, I can't complain too much about it.
I now know what changes need to be made and what mistakes I need to correct dakota
racemagnum
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158472
09/20/16 11:57 PM
09/20/16 11:57 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yeah mate make a few rear end changes and all good, great stuff !
1963 Plymouth Max Wedge
1971 Barracuda
Re: Little wheel stand action from my Dakota R/T [Re: MR_P_BODY] #2158625
09/21/16 10:58 AM
09/21/16 10:58 AM
Houston, Texas
Houston, Texas
wave
Thanks! I will keep that in mind! up
Re: Little wheel stand action from my Dakota R/T [Re: slammedR/T] #2158644
09/21/16 11:31 AM
09/21/16 11:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
While I'll have the R's up slightly, I don't wood it until the tree starts coming down. Getting up on the trans brake creates a lot of heat like RIGHT NOW!
Re: Little wheel stand action from my Dakota R/T [Re: J_BODY] #2158721
09/21/16 01:28 PM
09/21/16 01:28 PM
Houston, Texas
Houston, Texas
Can't do that when you run a Pro tree! eek
