Re: Pros and cons of the Dodge Rampage's?
[Re: DCI]
#477203
10/13/09 08:34 AM
10/13/09 08:34 AM
I am not sure if you are referring to my swapping out the trannys in the 89 LeBaron GTS that has a 2.2 turbo that has a bad trans and get a trans that came from a 90 LeBaron convertible. But, no I have not. However according to the discussion, it should work. I plan to look at the car and the trans this wk. As for the Rampage, it is not my daily driver and I can wait to fix it. Unfortunately, a low budget is ditacting all of this.
#477204
10/13/09 01:52 PM
10/13/09 01:52 PM
DaytonaTurbo
Manitoba, Canada
Yes this will swap fine if both are 4cyl cars. However the turbo automatics were a little more stout than their non-turbo counterparts. Also the turbo automatics did not get the lockup torq converter that the non-turbo auto's got.
[Re: DCI]
#477205
10/13/09 01:58 PM
10/13/09 01:58 PM
Pro - They make a cute LITTLE race car???!
[Re: 474218]
#2158229
09/20/16 07:12 PM
09/20/16 07:12 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
All the transmissions used with the 2.2 (and 2.5) engines will interchange. However, there is differences in the shifters. L-bodies, like the Rampage used shift rods. The G-bodies, like the Lebaron, used shift cable.
Not 100% correct. Axles have interchange issues. My wife owns one, turbocharged.
"I think its got a hemi"
