Re: Wally World's ATF+4 ???
[Re: Roughbird72]
#2155140
09/15/16 03:20 PM
09/15/16 03:20 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Thanks Cab! Need to change the fluid & filter in my 07 1500 4x4 Ram, but want to get some input before i decide which fluid to use. The price they have on it is quite low compared to others.
72 Plymouth Roadrunner 11.08@123.25
[Re: A727Tflite]
#2155747
09/16/16 02:36 PM
09/16/16 02:36 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I use their store brand oil (Walmart) in my daily drivers and if I remember right it says Valvoline in the small print so check it out. It may be the same.
[Re: A727Tflite]
#2157388
09/19/16 02:00 PM
09/19/16 02:00 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Regarding the jerky shifts after a fluid change on your 41TE. That is not uncommon after a fluid change - regardless of the fluid. It is always suggested to perform the "quick learn" with the scan tool to reset the adaptive values after a trans replacement, overhaul, valve body, solenoid pack replacement and in many cases just the fluid change. If you don't use the scan tool to reset the adaptives - it just takes longer for the trans controller to learn again - by driving it and performing various upshift and down shifts - it will accomplish the same learning - this is called the "drive learn". It only learns between approx. 80 to 120 F - lower or higher than these temps - it won't learn. That's what I was thinking. My transmission builder won't let you pick up your vehicle after a rebuild til he puts 20 miles on it. Thanks for chiming in.
[Re: allmopar]
#2157916
09/20/16 01:45 AM
09/20/16 01:45 AM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thinking my buddy told me that the mini vans had a transmission filter in the radiator that needed changed too while servicing the transmission
