Wally World's ATF+4 ??? #2155125
09/15/16 03:01 PM
09/15/16 03:01 PM
North Central, Indiana
Roughbird72 Offline OP
Does anyone know who makes Walmart's Super Tech ATF+4 or the quality of it? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2155128
09/15/16 03:04 PM
09/15/16 03:04 PM
I've seen on here that Phillips makes it and also Conoco shruggy I use it in my Ram CTD 3500 4 whd drive up
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2155140
09/15/16 03:20 PM
09/15/16 03:20 PM
Thanks Cab!
Need to change the fluid & filter in my 07 1500 4x4 Ram, but want to get some input before i decide which fluid to use.
The price they have on it is quite low compared to others.
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2155211
09/15/16 05:29 PM
09/15/16 05:29 PM
Free enterprise system works, the more you buy of a product the bigger discount you can get work
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2155724
09/16/16 02:03 PM
09/16/16 02:03 PM
A727Tflite Offline
A727Tflite  Offline
All ATF + 4 is made under license from Chrysler and has to use the base stock and additive package to be approved as ATF + 4.
Re: Wally World's ATF+4 ??? [Re: A727Tflite] #2155747
09/16/16 02:36 PM
09/16/16 02:36 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I use their store brand oil (Walmart) in my daily drivers and if I remember right it says Valvoline in the small print so check it out. It may be the same.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2155776
09/16/16 03:10 PM
09/16/16 03:10 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Pretty sure it's made by Warren Oil Company.
Their Walmart label stuff gets good reviews on Bobistheoilguy as far as analysis goes.
Kevin
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2155918
09/16/16 07:37 PM
09/16/16 07:37 PM
S.E. WI
allmopar Offline
allmopar  Offline
S.E. WI
Let me tell you about my experience with Wally World ATF+4. I did a trans filter change on my 03 T&C minivan and used the Wally World trans fluid. I had all kinds of jerky upshifts and downshifts. I thought the filter was not on correct and sucking air. I dropped the trans pan again and found the filter was fine. Still had shift issues so I changed the shift solenoid pack. Still had jerky shifts. Then I drained out the Wally World oil and replaced it with Valvoline. Trans shifted smoothly immediately and has been just fine for the last 2 years. I bought the wally fluid because it was cheaper but it really cost me in the long run.
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2156124
09/17/16 09:27 AM
09/17/16 09:27 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The original additive package for ATF+4 was made by Lubrizol, which is now a division of Berkshire Hathaway.
I wonder if some less expensive ATF+4 uses a non-Lubrizol additive in less expensive syn base oil?
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2156773
09/18/16 12:31 PM
09/18/16 12:31 PM
After a little searching i found the Mopar brand for $5.33 a quart.
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2157374
09/19/16 01:48 PM
09/19/16 01:48 PM
A727Tflite Offline
A727Tflite  Offline
Regarding the jerky shifts after a fluid change on your 41TE. That is not uncommon after a fluid change - regardless of the fluid. It is always suggested to perform the "quick learn" with the scan tool to reset the adaptive values after a trans replacement, overhaul, valve body, solenoid pack replacement and in many cases just the fluid change. If you don't use the scan tool to reset the adaptives - it just takes longer for the trans controller to learn again - by driving it and performing various upshift and down shifts - it will accomplish the same learning - this is called the "drive learn". It only learns between approx. 80 to 120 F - lower or higher than these temps - it won't learn.
Re: Wally World's ATF+4 ??? [Re: A727Tflite] #2157388
09/19/16 02:00 PM
09/19/16 02:00 PM
PA.
"Little"John
"Little"John
PA.
That's what I was thinking. My transmission builder won't let you pick up your vehicle after a rebuild til he puts 20 miles on it. Thanks for chiming in.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Wally World's ATF+4 ??? [Re: A727Tflite] #2157465
09/19/16 03:37 PM
09/19/16 03:37 PM
S.E. WI
allmopar Offline
allmopar  Offline
S.E. WI
I aggree with what you are saying about the jerky shifts after a fluid change but this was still jerky after weeks of daily driving. the 2-3 upshift and the 2-1 downshift. That is why I changed the solenoid pack. After a few days the jerky shift came back and then I decided one last try to swap the fluid. This whole process was over a few months of researching the issues and trying different solutions. Once the fluid was changed the shifts were smooth and 45,000mi later they are still smooth.
Re: Wally World's ATF+4 ??? [Re: allmopar] #2157477
09/19/16 03:54 PM
09/19/16 03:54 PM
S.E. WI
allmopar Offline
allmopar  Offline
S.E. WI
Forgot to mention that I did do the quick learn and it only helped for a few days. That was before the new solenoid pack.
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2157613
09/19/16 06:43 PM
09/19/16 06:43 PM
A727Tflite Offline
A727Tflite  Offline
Not to beat this to death - but why did you change the fluid to start with? How many miles on the trans/vehicle? And did you do the quick learn after the pack was replaced? What scan tool did you use to do the quick learn? Just wonderin'
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2157814
09/19/16 11:20 PM
09/19/16 11:20 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I have used it for several years now, works fine.
Re: Wally World's ATF+4 ??? [Re: 135sohc] #2157912
09/20/16 01:38 AM
09/20/16 01:38 AM
S.E. WI
allmopar Offline
allmopar  Offline
S.E. WI
the minivan had 150,000 miles when I did that fluid change. I do it every 50,000 miles. I am almost at 200k now.
This was just my experience with wally world +4. I used it in the past in a chrysler LHS and it worked fine. I am sure it works fine for other people in other vehicles but I will not buy it again.
Re: Wally World's ATF+4 ??? [Re: allmopar] #2157916
09/20/16 01:45 AM
09/20/16 01:45 AM
PA.
"Little"John
"Little"John
PA.
Thinking my buddy told me that the mini vans had a transmission filter in the radiator that needed changed too while servicing the transmission
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Wally World's ATF+4 ??? [Re: pittsburghracer] #2157940
09/20/16 03:22 AM
09/20/16 03:22 AM
SE PA
Yellow Fever Offline
SE PA
I've been using the Walmart ATF+4 in everything, never a problem. Just used it in my Challenger and used the Mercedes trans pan with the drain plug for easier oil changes down the road.
Re: Wally World's ATF+4 ??? [Re: Roughbird72] #2157968
09/20/16 08:52 AM
09/20/16 08:52 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I would be careful buying from a retailer that buys the cheapest stuff they can find and does not have the facilities or expertise to monitor the quality of what they sell. Maybe the supplier they're buying from today is a good one but no one knows who will be making their stuff tomorrow. The whole idea of putting their name on the can is so they can change suppliers at any time. Just my two cents.
