Opinions needed on IHRA #215155
02/05/09 05:05 PM
02/05/09 05:05 PM
Utah
dragnduster Offline OP
Utah
With Rocky Mountain Raceways dropping NHRA and going IHRA, will this be a good thing for the average sportsman racer? What types of classes does IHRA offer and do they run any heads up type of classes that a mid 10 second car could fall into?
Re: Opinions needed on IHRA [Re: dragnduster] #215156
02/05/09 06:58 PM
02/05/09 06:58 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
If you are a bracket racer, you probably won't see any changes at your local track. If they run a sportsman points meet, you can run Hot/Rod, 7.00 index on 1/8th mile on a .500 pro tree.
Re: Opinions needed on IHRA [Re: cgall] #215157
02/05/09 07:04 PM
02/05/09 07:04 PM
Utah
Utah
Thanks, if they do run a sportsmans points meet, do they adjust the index for the elevation of the track?
Re: Opinions needed on IHRA [Re: dragnduster] #215158
02/05/09 07:27 PM
02/05/09 07:27 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Wow, here's an article on the switch.
http://www.ihra.com/article/3896.html
I don't think IHRA has been that far west before. They have a National event scheduled for your track, so H/R will probably be run on 1/4 mile. You will have to check with them on the altitude adjustment. One nice thing about IHRA is that you don't need any grade points or pre-entry, you just show up and pay at the gate.
Nice Duster, by the way.
Re: Opinions needed on IHRA [Re: cgall] #215159
02/05/09 07:43 PM
02/05/09 07:43 PM
Utah
Utah
Thanks for the help, and thanks for the compliment. It would be cool to do some heads up racing. Looks like the track will be having a racers meeting in March, so I guess will find out more then.
Re: Opinions needed on IHRA [Re: dragnduster] #215160
02/05/09 09:07 PM
02/05/09 09:07 PM
You don't need the chassis inspected until you run Super Comp/Rod times. No need for a Dr's permission slip to get your license until you hit TS or TD.
With the money you save from just that, it's like you get the first five races entry free.
Re: Opinions needed on IHRA [Re: ] #215161
02/05/09 11:32 PM
02/05/09 11:32 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
After running both over the past forty years, I can tell you without a doubt that IHRA is much more grass-roots-racer-freindly. It's not even close.
You'll like it.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Opinions needed on IHRA [Re: Steve1118] #215162
02/06/09 12:05 AM
02/06/09 12:05 AM
Utah
Utah
Sounds like it could end up being a positive thing then, thanks for all the replies .
Re: Opinions needed on IHRA [Re: dragnduster] #215163
02/06/09 12:14 AM
02/06/09 12:14 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Hey dave, guess my info last week was proved correct, from the press release doesn't sound liker it'll be a big issue, guess we'l just get to join both if we keep racing at Boise, Grand Junction, or Vegas.
Re: Opinions needed on IHRA [Re: wyoming] #215164
02/06/09 12:22 AM
02/06/09 12:22 AM
Utah
Utah
Yup you called that one correct. Hopefully this will turn out to be a good thing for us. If they run that Hot Rod index I think I will look at slowing the car down and give heads up racing a try. RMR web site says they will have a racers meeting with IHRA in March, are you going to go?
Re: Opinions needed on IHRA [Re: dragnduster] #215165
02/06/09 01:32 AM
02/06/09 01:32 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
If I'm around the house I will, but just as likely to be away at work, but I do know several guys going for sure, so I'll get the scoop either way, by the way, got the diaper, it fit really well. Not a bad deal at all.
Re: Opinions needed on IHRA [Re: wyoming] #215166
02/06/09 02:23 AM
02/06/09 02:23 AM
Utah
Utah
Good deal,I'll have to get him some measurements and get my diaper ordered.
