Re: SB VICTOR OTT, Update
[Re: Jason B]
#2324314
06/20/17 06:11 PM
06/20/17 06:11 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Those two sheets are a bit puzzling.......
At 7200rpm, the "after" sheet shows roughly a 100hp improvement, while at the same time using over 50lbs/hr less fuel.
The fuel flow at the end of the "after" pull(7700) is less than what it is at the beginning of the "before" pull(5800).
Averages at the bottom of the page;
Before - 320.1 lbs/hr After - 237.2 lbs/hr
[Re: Jason B]
#2324380
06/20/17 09:08 PM
06/20/17 09:08 PM
fast68plymouth
So. Burlington, Vt.
Were both tests done with the same carb and same fuel?
[Re: sst404b]
#2324424
06/20/17 10:49 PM
06/20/17 10:49 PM
BradH
I was told by the the engine builder that BSFC lb/hph is what he prefers. Are you saying your engine builder (and dyno operator?) is trying to tune from the BSFC, instead of the air-fuel ratio? If so, somebody should tell him to Google "you can't tune using BSFC" to help him understand why that's a flawed approach.
[Re: Jason B]
#2325667
06/23/17 11:20 AM
06/23/17 11:20 AM
Posts: 792 Earth
Rob C
Earth
[Re: Jason B]
#2325779
06/23/17 03:27 PM
06/23/17 03:27 PM
Posts: 570 UK
rb446
UK
That is totally gorgeous and exactly the car/combo I'd want if I was to ever get back into racing over here, slay those BB Mopar boys just like I did in the old days.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: BradH]
#2325795
06/23/17 04:09 PM
06/23/17 04:09 PM
Thumperdart
State of confusion
I was told by the the engine builder that BSFC lb/hph is what he prefers. Are you saying your engine builder (and dyno operator?) is trying to tune from the BSFC, instead of the air-fuel ratio? If so, somebody should tell him to Google "you can't tune using BSFC" to help him understand why that's a flawed approach. And so does Pettis and EVERY carb on his dyno needs more fuel across the board when in the car and at the track making passes. Afr's to me are the base of tuning then salt to taste from there........That car is a complete work of art............
[Re: sst404b]
#2325905
06/23/17 09:10 PM
06/23/17 09:10 PM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#2325911
06/23/17 09:22 PM
06/23/17 09:22 PM
Posts: 1,784 PA
W5DART66
PA
