Gearing Question #214994
02/05/09 12:52 PM
02/05/09 12:52 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I would like to know if I left any on the table. I recently purchased a spool and 4.86 gears for my 72 Duster: 3060lbs(w/me), 340 .030 over,ported J heads,Racer Brown STH-42cam,1 3/4 headers, 2.74 low geared 904,29.75 tall tires, 4800 converter....crossed line @6200 w/4.56 gears. I was thinking if I went w/5.13 I would spin too far out of the torque curve.
Yeah, it's got a smallblock.
Re: Gearing Question [Re: 340B5] #214995
02/05/09 01:10 PM
02/05/09 01:10 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Can you list the specs on the cam? I'm not familiar with RB.
Re: Gearing Question [Re: S/ST 3040] #214996
02/05/09 01:17 PM
02/05/09 01:17 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
This is LA engine. Specs: 254@50, 300 total, .520 lift 108 lobe CL, installed 105 ATDC.
Re: Gearing Question [Re: 340B5] #214997
02/05/09 01:23 PM
02/05/09 01:23 PM
S/ST 3040 Offline
S/ST 3040  Offline
What do you currently run with the 4.56? 11.50 @ 114?
Re: Gearing Question [Re: S/ST 3040] #214998
02/05/09 01:34 PM
02/05/09 01:34 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
12.03@111.2, Racer Brown cam took me from 12.38 to this point and it still pulls past finish.
Re: Gearing Question [Re: 340B5] #214999
02/05/09 01:40 PM
02/05/09 01:40 PM
S/ST 3040 Offline
S/ST 3040  Offline
Since you have the 4.86, I'd try them. 5.13 looks like it will be too much.
It's been my experience, 340s like tight lobe centers and alot of converter.
Re: Gearing Question [Re: S/ST 3040] #215000
02/05/09 01:43 PM
02/05/09 01:43 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Thanks, I have a habit of second guessing myself.
"Question everything-assume nothing"
Re: Gearing Question [Re: 340B5] #215001
02/05/09 03:42 PM
02/05/09 03:42 PM
ohio
prochamp Offline
prochamp  Offline
ohio
what carb/intake are you running? how much compression? what rpm are you shifting at? what valve size?
Re: Gearing Question [Re: prochamp] #215002
02/05/09 04:07 PM
02/05/09 04:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what size is the converter? I bet your leaving something on the table with 4800
Re: Gearing Question [Re: prochamp] #215003
02/05/09 05:02 PM
02/05/09 05:02 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Shift @63501st,67002nd,750 Holley w Proform main body-Quickfuel metering blocks, Holley Strip Dom. Converter stalls @ approx 4800.11.6:1 comp, 2.02 Valve
Re: Gearing Question [Re: 340B5] #215004
02/05/09 05:15 PM
02/05/09 05:15 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What rpm does the engine pull strong to?
Re: Gearing Question [Re: emarine01] #215005
02/05/09 05:44 PM
02/05/09 05:44 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Tough Question, only 4 runs on cam last year. Three w/tire slip, and one solid run after mods on the next outing. Seems to pull pretty good at 6700.
Re: Gearing Question [Re: 340B5] #215006
02/05/09 05:46 PM
02/05/09 05:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what size converter? 8"-9" ?
Re: Gearing Question [Re: Quicktree] #215007
02/05/09 05:52 PM
02/05/09 05:52 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Turbo Action 19508XXSM42. Listed as an 8" actually is 9.5 Dia.
Re: Gearing Question [Re: 340B5] #215008
02/05/09 06:01 PM
02/05/09 06:01 PM
ohio
prochamp Offline
prochamp  Offline
ohio
i assume that its an 8inch converter? i ran a very similar combo to yours years ago that ran around 11.20. the heads were all done around 6600rpm.i shifted both gears at 6600 trapped about the same.you definately don't need more than 4.86s have you tried advancing the cam some more say around 102? a 2inch carb spacer always helped on mine also.how long is the header collector? it needs to be about 18inches running the rpms your at.thats a few things you might try once you get back on the track...good luck
Re: Gearing Question [Re: 340B5] #215009
02/05/09 07:21 PM
02/05/09 07:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
good converer but I would have it loosened up a little.
Re: Gearing Question [Re: Quicktree] #215010
02/05/09 11:09 PM
02/05/09 11:09 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
