Re: SB VICTOR OTT, Update [Re: Jason B] #2324301
06/20/17 05:50 PM
06/20/17 05:50 PM
sst404b Offline
sst404b  Offline
Thought I would update what has been going on with this build. We changed cam to a Bullet and rockers to T and D push rod oil,and made changes to the ring pack and oiling. The heads and intake are the same, pretty much OOTB,and no changes to the car. We went to Baytown and made 3 laps. The first was a shake down and the last 2 were with the setup that was in the Grid, because we forgot the laptop, which shifted at 7200 and went on high speed chip at 7500. The starting line was done by the last one and it spun a little. I think we can get this thing in the mid to low 8.90s at 150 which is goood for a set of OOTB heads.
Ray Buckner
Re: SB VICTOR OTT, Update [Re: sst404b] #2324303
06/20/17 05:53 PM
06/20/17 05:53 PM
sst404b Offline
sst404b  Offline
Dyno Sheet before and after changes
Ray
Re: SB VICTOR OTT, Update [Re: Jason B] #2324314
06/20/17 06:11 PM
06/20/17 06:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Those two sheets are a bit puzzling.......
At 7200rpm, the "after" sheet shows roughly a 100hp improvement, while at the same time using over 50lbs/hr less fuel.
The fuel flow at the end of the "after" pull(7700) is less than what it is at the beginning of the "before" pull(5800).
Averages at the bottom of the page;
Before - 320.1 lbs/hr
After - 237.2 lbs/hr
Re: SB VICTOR OTT, Update [Re: Jason B] #2324319
06/20/17 06:20 PM
06/20/17 06:20 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Curious, why the change in rockers? Just a change in spring pressure with the new cam requiring something a bit better? or did they break.
Re: SB VICTOR OTT, Update [Re: Jason B] #2324354
06/20/17 07:57 PM
06/20/17 07:57 PM
sst404b Offline
sst404b  Offline
Changed rockers because I've always had problems with ball and cup push rods so I thought I would try ball and ball push rod oiling for a change. I was told by the the engine builder that BSFC lb/hph is what he prefers. The car ran 9.23 @143 before the changes, so it's heading in right direction. My son and Brett Miller have been talking about this build and what he thought it needs and about what the heads and intake need to get this thing to the next level
Ray
Re: SB VICTOR OTT [Re: Jason B] #2324358
06/20/17 08:06 PM
06/20/17 08:06 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Very nice car!
Re: SB VICTOR OTT, Update [Re: Jason B] #2324380
06/20/17 09:08 PM
06/20/17 09:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
Were both tests done with the same carb and same fuel?
Re: SB VICTOR OTT, Update [Re: sst404b] #2324424
06/20/17 10:49 PM
06/20/17 10:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Are you saying your engine builder (and dyno operator?) is trying to tune from the BSFC, instead of the air-fuel ratio?
If so, somebody should tell him to Google "you can't tune using BSFC" to help him understand why that's a flawed approach.
Re: SB VICTOR OTT, Update [Re: BradH] #2324432
06/20/17 11:08 PM
06/20/17 11:08 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Next step in power😀
Re: SB VICTOR OTT, Update [Re: Jason B] #2325667
06/23/17 11:20 AM
06/23/17 11:20 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Any before pictures?
Re: SB VICTOR OTT, Update [Re: Jason B] #2325779
06/23/17 03:27 PM
06/23/17 03:27 PM
UK
rb446 Offline
rb446  Offline
UK
That is totally gorgeous and exactly the car/combo I'd want if I was to ever get back into racing over here, slay those BB Mopar boys just like I did in the old days.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: SB VICTOR OTT, Update [Re: BradH] #2325795
06/23/17 04:09 PM
06/23/17 04:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And so does Pettis and EVERY carb on his dyno needs more fuel across the board when in the car and at the track making passes. Afr's to me are the base of tuning then salt to taste from there........That car is a complete work of art............ bow beer
Re: SB VICTOR OTT, Update [Re: Jason B] #2325845
06/23/17 06:24 PM
06/23/17 06:24 PM
sst404b Offline
sst404b  Offline
The point I want to make is that the Victor head is worth the investment. They made 1.7 hp/cu in, which on a 408/416 is around 700 hp. And the best part is you can bolt them on and go. All that was done to ours was a valve job and clean up the tool marks. Everything is available now to complete the build. I admit it's not cheap, but it's a lot more affordable than you think.
Ray
Re: SB VICTOR OTT, Update [Re: sst404b] #2325905
06/23/17 09:10 PM
06/23/17 09:10 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Here are some before pictures.
Re: SB VICTOR OTT, Update [Re: W5DART66] #2325911
06/23/17 09:22 PM
06/23/17 09:22 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Re: SB VICTOR OTT, Update [Re: W5DART66] #2325974
06/24/17 12:45 AM
06/24/17 12:45 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Does vicbloomer still post on here...just asking been a long time since I seen a post from him .
Re: SB VICTOR OTT, Update [Re: Jason B] #2325977
06/24/17 12:52 AM
06/24/17 12:52 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Oh! Started with a raw casting!!!!! Wow
Thanks Brett!
