AC trouble NOW WORKING
#2149673
09/07/16 03:28 PM
09/07/16 03:28 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
1966 Chrysler 300 with a 383.
Just restored the ac compressor with new rubber seals and gaskets. Filled it up to day with the help of my friend and ac expert(not expert on old car ac´s) It is leak free and seems to be fine.
But it´s not blow any cold air, the inlet is pipe is cold and the outlet pipe is hot. He thought it´s a valve problem?
What could it be??
Thanks.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: AC trouble
[Re: MrSixpack]
#2149746
09/07/16 05:19 PM
09/07/16 05:19 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is it blowing air from the dash registers when in the A/C mode?
Re: AC trouble
[Re: MrSixpack]
#2150198
09/08/16 08:16 AM
09/08/16 08:16 AM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
What could it be??
Thanks. As in water valve or expansion valve? Gauge pressures will tell you if it's an expansion valve problem. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: AC trouble
[Re: MrSixpack]
#2150849
09/09/16 04:01 AM
09/09/16 04:01 AM
MrSixpack
Stockholm, Sweden
Okey, I drove the car to work again today and I had the windows down because it was hot outside. And I thought I will try the AC again, and now I had a thermometer with me in the car. I put the sensor in the outlet and had 87F, then I put the windows up and put on the AC, after 5 minutes it was blowing 57F.
We can only use R134 here in Sweden so I think it´s pretty good for what it is.
So with new oil in the system and fully charged the valves are unstucked :-)
The system has been out of use for 10-15 years so finally it works.
Thanks for all your help guys :-)
1968 Mini Cooper
