Page 2 of 3 1 2 3
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: cudaman1969] #2147804
09/05/16 04:31 AM
09/05/16 04:31 AM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
Originally Posted By cudaman1969
Originally Posted By bee1971
I run that same carb on my 71 BEE - 383 Magnum - Put the smaller AVS 6125 s up in the attic
Perfect - Carb is Awesome
I also blocked off the HIC
Made my own flat metering rod covers - Edelbrock doesn't sell them when I asked
104 Primaries
107 Secondaries
68-47 Metering Rods
Blue Edelbrock Metering Rod Springs , had to replace factory springs
The 4640 is for AC cars and I would look at the hot idle compensator for leaks (cork gasket) or block it like bee 71 said. Is your car AC? If not look for 4618 carb, they have different air adjusters. Check the rods to see if they are free moving and down when running, might not be seeing vacuum to pull down (restriction)
Like I said, the HIC is blocked off. The metering rods move freely, and are down at idle.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: RapidRobert] #2147846
09/05/16 10:28 AM
09/05/16 10:28 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted By RapidRobert
I would highly suggest not opening anything up (drilling). we gotta find/fix the root cause first.
do you have any experience with changing idle feed/jets in any carbs?
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2147934
09/05/16 01:02 PM
09/05/16 01:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
104 Primaries
107 Secondaries
68-47 Metering Rods
The holly must be duel feed? Square bowl will fit with stock coil bracket, and I wouldn't put the tq on with an adapter. So find a 440 tq intake, less hassle since all the linkage and choke hooks up factory.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: RapidRobert] #2148018
09/05/16 02:51 PM
09/05/16 02:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The root cause is the design. These are emissions carbs intended to run lean and they do; drivability problems were well known when the cars were brand new and today's gas exacerbates the original problem.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: John_Kunkel] #2148079
09/05/16 04:27 PM
09/05/16 04:27 PM
yes it is an emissions era carb & is lean & tweaking the innards does work excellent to fine tune em spot on but it can & will run at least on the idling circuit fine for the most part without em (& OP has a mild cam). there is another problem going on that needs to be fixed (something is severley damaged/leaking etc). I cant see fine tuning the innards with drilling fixing what is damaged. Like the one guy posted & my exp with em, they are fine but can be made better. if drilling mods fix this carb I'll be the first to admit I was wrong!
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2148930
09/06/16 04:48 PM
09/06/16 04:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'm with Lew and John on this one...... Drill 'em out.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: John_Kunkel] #2148969
09/06/16 05:35 PM
09/06/16 05:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Emission carb, in 1969?
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: cudaman1969] #2149067
09/06/16 07:52 PM
09/06/16 07:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You bet. All factory AVS's (Mopar started using them in '68) are emission carbs.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 62maxwgn] #2149945
09/07/16 10:08 PM
09/07/16 10:08 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Originally Posted By 62maxwgn
Originally Posted By ademon
Holley
Not if the TQ is set up right !! no
AGREED! Finding a good TQ is one thing. Getting parts to tune it is the other trick. Once you have a good TQ carb tuned in, there really quite an excellent carb. IMO, perfect for a street strip application.
A Holley is the easy way out. And I wouldn't blame a sole for going to one.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: Rob C] #2149954
09/07/16 10:20 PM
09/07/16 10:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Holley
The TQ a least has the right Chrysler linkage, not a bandaid adapter.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2149996
09/07/16 10:57 PM
09/07/16 10:57 PM
B5XP29, FOR SURE holler how the AVS turns out! what you did to it/how it acts now. Inquiring minds want to know.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2150059
09/08/16 12:02 AM
09/08/16 12:02 AM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
I ordered some #63 drill bits (.037"), as nobody local carries them. Hopefully they'll be here by the weekend. If I can't get the AVS running right, maybe I'll try the thermoquad. Thanks to everybody for the advice/suggestions
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2150168
09/08/16 04:17 AM
09/08/16 04:17 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One of my favorite cars. Rode around many a nite in my friends 69 RT, forest green, he bought the car right off the showroom, paid for it himself.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2150307
09/08/16 12:57 PM
09/08/16 12:57 PM
dogdays Offline
dogdays  Offline
The best bet is a brand new Holley 750 Street Demon, $346 delivered to your door. It looks a lot like a Thermoquad and has the latest metering ideas.
R.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2150309
09/08/16 01:01 PM
09/08/16 01:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not interested in something the "looks like" a Thermoquad.
Question is, does it SOUND like one?
Don't be the exception.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2150374
09/08/16 02:31 PM
09/08/16 02:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
I like the Edelbrock 800avs in an application like this.
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2151454
09/10/16 02:39 AM
09/10/16 02:39 AM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, it worked! Drilling out the idle fuel jet tube to .037" did the trick. It has never idled better. Smooth as silk. Who would have thought something so simple could have done it. Thanks to everyone that offered up the great advice! Gotta love Moparts! 👍
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: fast68plymouth] #2151540
09/10/16 11:09 AM
09/10/16 11:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also agree with you guys. Does anyone know what size the economizer or the other idle feed restriction is ? I take it that it is larger then the lower idle feed restriction at the bottom of the idle tube since drilling the idle restriction at the bottom of the tube helps and makes it richer ? Ron
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: 69L78Nova] #2151601
09/10/16 12:37 PM
09/10/16 12:37 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Interesting , Awesome To Hear
By drilling them out , could you actually have cleaned them out , as in dirty or plugged ???
My 4640sa starts and idles perfect stone cold , idles cold with no choke not even touching the gas pedal , running the Mopar 284 / 484 Cam , transition off idle beyond smooth , I don't even want to try this , if not broke don't fix it ,since the many times I opened it up playing with jetting and fine tuning it
Anyways makes the Edelbrock 1407 that it replaced , man what a Headache that 1407 was , biggest POS carb I ever worked on
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues [Re: bee1971] #2151623
09/10/16 01:35 PM
09/10/16 01:35 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
Not a chance. This carb couldnt have been any cleaner. I always clean all passages out with torch tip cleaners, carb cleaner, and a blast of over 120psi of air. Not every carb needs to be modified internally, but I guess this one did. Like I said, it has never idled better or cleaner, I leaned out the primary cruise step and fattened up the secondary jets while it was apart. Plugs look good, pulls harder, and idles great.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Page 2 of 3 1 2 3
