Re: Bucky found the wall
[Re: jughed]
#2147181
09/04/16 09:35 AM
09/04/16 09:35 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Diaper didn't work very well did it? Must not have been a ballistic one.
[Re: justinp61]
#2147224
09/04/16 11:42 AM
09/04/16 11:42 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
That sucks. Did anyone else notice the amount of left front wheel wobble when the car put the front end back down? I'm sure that has to stress the front end, too.
[image][/image]
[Re: CMcAllister]
#2147244
09/04/16 12:27 PM
09/04/16 12:27 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Bucky is determined and resilient. He'll be back. Yes he will. I saw the video on Facebook yesterday and it shows him on the top end getting out of the car He was one pissed off dude as I would be too.
[Re: CMcAllister]
#2147274
09/04/16 01:20 PM
09/04/16 01:20 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Bucky is determined and resilient. He'll be back. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I was told it was a rod that let go. Ran into Herb McCandless at the Auburn Auction yesterday.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2147318
09/04/16 02:39 PM
09/04/16 02:39 PM
Posts: 4,704 Wichita
GY3
Wichita
Heartbreaker!
That car looked amazing!
[Re: sgcuda]
#2147325
09/04/16 02:48 PM
09/04/16 02:48 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
That sucks. Did anyone else notice the amount of left front wheel wobble when the car put the front end back down? I'm sure that has to stress the front end, too. one of the reasons they've wanted to go rack steering and aftermarket steering components.... but that "stock" thing keeps getting in the way Bucky was running some pretty good numbers.... still a Line Hemi between the fender wells?
[Re: GY3]
#2147461
09/04/16 06:27 PM
09/04/16 06:27 PM
Posts: 7,506 Az
Crizila
Az
Heartbreaker!
That car looked amazing! Yep. A real bummer. Some times it's best to step away from it for a short before you start to asses the hole thing. Usually not as bad as first thought.
Fastest 300
[Re: justinp61]
#2147787
09/05/16 03:02 AM
09/05/16 03:02 AM
Posts: 20,213 Park Forest, IL
slantzilla
Park Forest, IL
Bodywork will be cheaper than replacing that Elephant. It looked like it done blowed up real good.
[Re: Crizila]
#2147968
09/05/16 01:34 PM
09/05/16 01:34 PM
Posts: 11,721 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Heartbreaker!
That car looked amazing! Yep. A real bummer. Some times it's best to step away from it for a short before you start to asses the hole thing. Usually not as bad as first thought. He's not one to step away from something and spend any time thinking about it. He's probably taking it apart today and will be on the phone tomorrow morning ordering parts.
[Re: J_BODY]
#2148474
09/06/16 12:51 AM
09/06/16 12:51 AM
Posts: 757 Reading PA
duster400
Reading PA
[quote=sgcuda]That sucks. Bucky was running some pretty good numbers.... still a Line Hemi between the fender wells? That is what they said over the loud speaker at the track. Anthony
[Re: justinp61]
#2148640
09/06/16 09:51 AM
09/06/16 09:51 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
That really sucks bad, I believe he had the lowest ET of the event also for that class.
[Re: Monte_Smith]
#2148641
09/06/16 09:54 AM
09/06/16 09:54 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
While not a "soft" hit by any means........damage looked minimal. Car should be easily fixable The paint to duplicate might be a little tough on that extremely detailed car. It's a 1 of 1.
[Re: Sammy]
#2148663
09/06/16 10:56 AM
09/06/16 10:56 AM
Posts: 10,049 MN
JERICOGTX
MN
While not a "soft" hit by any means........damage looked minimal. Car should be easily fixable The paint to duplicate might be a little tough on that extremely detailed car. It's a 1 of 1. It's the second time the car has tagged the wall. Bucky and Travis will have it looking even better the next time around. They are the BEST at paint jobs like this.
69 GTX
68 Road Runner
