Re: Small block timing tensioner?
[Re: bill_greenwood]
#214436
02/05/09 01:10 AM
02/05/09 01:10 AM
Do not- DO NOT- remove the spring clip before installation. It will be very annoying if you do. Don't ask me how I know this.
now that made me laugh the first one of those i did i thought to myself, wow, what a pain in the butt. now that i'm used to them and have learned a couple tricks along the way, that pin is the first thing i remove.
#214438
02/05/09 01:29 AM
02/05/09 01:29 AM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
Please share those tricks, only done one and now gotta do mine so would like to save myself the pain.
[Re: 69Cuda340S]
#214442
02/05/09 10:59 AM
02/05/09 10:59 AM
Posts: 3,695 nc
emarine01
nc
What are the advantages to running one of those tensioners?
They take up the slack in the chain , keeps cam from retarding with ware
[Re: Dos Snails]
#214446
02/05/09 09:10 PM
02/05/09 09:10 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
My buddy who has worked on street cars warned me about this when I asked him if I should get one. IIRC he mentioned them coming apart after a while.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: RyanJ]
#214449
02/05/09 09:57 PM
02/05/09 09:57 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
If the pin comes out prior to installation, just use a long screwdriver & pry the tensioner back in place by applying leverage against the oil dripper tab, & stick the pin back in, or you can use a small punch instead, & by using a punch in the pin hole you can gain leverage over the tensioner to make it easier to get the chain on & off.
The backside of the tensioner does have a single slot for oiling, I've added additional oil slots in past depending on use..... also I put a coat of CMD #3 extreme pressure lube on the backside where the cam will ride when first assembling.
I use 5/16" ARP SB header bolts to attach the tensioner with red loctite...
& I lube the chain & tensioner where the chain rides with ARP moly graphite assy lube.
This stuff is'nt rocket science, just use common sense.
