This winter the changes were going from a 360 to a 408.Everythng else is the same
360 combo.KB107 pistons +.009 out of hole .030 over,stock rods balanced,stock crank,974 heads ported with 2.02's or stock Eddys car ran the same
Scott Brown 240/252H cam with 530/540 lift,Air Gap intake and 750hp carb and TTI headers.Ran 11.53 @ 116 with 1.52 60'
408 scat package KB744 pistons,forged rods & crank
"0" deck,Crane cam 258/268 @ .050 560/580 lift 103 ATDC,Eddy heads but reworked,cleaned up around guides and pinch area,same intake/carb & headers.
Running through a 999/904 trans low gear set with 4000 stall TCS converter with 4.30 gear and 29x9 Hoosiers.
What ET/MPH will this give me?
