Should I add a ARB to the mix #2137345
08/20/16 04:45 PM
08/20/16 04:45 PM
michigan
turbo toad Offline OP
michigan
The suspension upgrades in my valiant are almost complete and ive been in contact with some leaf spring races that suggested I install A anti roll bar. I understand the theory of how they work and the benefits one may get from installing a ARB. Does a setup like this work for a torsion bar stock style suspension, and whats your guys experience with adding one,pros and cons.
The rearend has to come out one last time after i figure my pinion angle out to weld the spring perches and the brake line fiting brakets. So if i added one now I could save myself some future headaches down the line. So it looks like I need you members on moparts guidance one more time.
BB,TURBO CAR,POWERGLIDE,DANA 60,CALTRAC ON LEAFS,DA VIKING SHOCKS UP FRONT,SA RANCHO SHOCKS OUT BACK for now,SMALL TIRE CAR
Any and all help is always appreciated pics would be a added bonus
Thanks All in advance
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Should I add a ARB to the mix [Re: turbo toad] #2137354
08/20/16 05:08 PM
08/20/16 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They help a lot on leafs... the rear end is trying
to roll(flip over to the drivers side) and this applies
the load equal to each tire... I used a S&W ARB
wave
Re: Should I add a ARB to the mix [Re: turbo toad] #2137475
08/20/16 09:23 PM
08/20/16 09:23 PM
gregsdart Offline
gregsdart  Offline
I am betting much better shocks are way more important. The torque applied to those leaf springs is going to be huge, even with a low ratio gear in a PG trans. An anti roll can,t help if the rear separates violently and runs out of shock travel. Look in the old race car thread. My dart is in there, showing what happens with big torque, poor shocks and SS springs.
Re: Should I add a ARB to the mix [Re: turbo toad] #2137500
08/20/16 09:54 PM
08/20/16 09:54 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Absolutely, a huge difference at the track, and on the street. I mounted mine between the rear down bars of the cage in the trunk, and mounted it on top of the axle tubes. It's a team z motorsports universal kit. Very nice piece.
Re: Should I add a ARB to the mix [Re: gregsdart] #2137504
08/20/16 09:58 PM
08/20/16 09:58 PM
michigan
michigan
Thanks Mr.Pbody for the speedy reply your advice and experience is always appreciated I'm going to look into one.
Yah greg I planned on better rear shocks in the near future I've read enuff info on this site to final realize the importance of a good set of shocks. up
Re: Should I add a ARB to the mix [Re: turbo toad] #2137507
08/20/16 10:07 PM
08/20/16 10:07 PM
michigan
michigan
1980volare thanks for that pic thats what I'm looking for my rear bars are landed in a similar location as yours. Any chance you could take a pic of how you mounted it on the housing. thumbs
Re: Should I add a ARB to the mix [Re: turbo toad] #2137582
08/21/16 12:35 AM
08/21/16 12:35 AM
gregsdart Offline
gregsdart  Offline
. Great. Looking forward to your ride hitting the road
Re: Should I add a ARB to the mix [Re: turbo toad] #2137628
08/21/16 01:42 AM
08/21/16 01:42 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yep. Much needed
Re: Should I add a ARB to the mix [Re: turbo toad] #2137728
08/21/16 10:29 AM
08/21/16 10:29 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Mounted between frame rail on ours. ARB will help to launch square but as everyone says, you need good shocks to help axle rotation / rear separation. My next move is to mount the shocks on the front of the housing.
HTH's
Re: Should I add a ARB to the mix [Re: turbo toad] #2138569
08/22/16 02:07 PM
08/22/16 02:07 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
^^^^^^^^^^^^^^^Don't waste your time on moving shocks to front. Helps or solves nothing.
To OP, YES to anti roll, but not one like in above pic. Any bar that has the ends bolt on will eventually cause a problem when it wallows out the holes........which it WILL. Arms should ALWAYS weld on to tube
Re: Should I add a ARB to the mix [Re: Monte_Smith] #2138581
08/22/16 02:24 PM
08/22/16 02:24 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Billet arms?
69 GTX 68 Road Runner
Re: Should I add a ARB to the mix [Re: turbo toad] #2138635
08/22/16 03:30 PM
08/22/16 03:30 PM
michigan
michigan
Thanks all who posted pics and those who gave solid advice I spent a couple hours on the net yesterday doing research and yes ill be adding a arb to the mix.
JERICOGTX that billet arm setup looks to be a nice setup i acutally got a ad from leaf spring unlimited on FB and was looking at that setup yesterday...
Re: Should I add a ARB to the mix [Re: turbo toad] #2138684
08/22/16 04:26 PM
08/22/16 04:26 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
That is where I saw the ad also. Looks nice. Isn't real cheap, but you get what you pay for... usually.
Re: Should I add a ARB to the mix [Re: turbo toad] #2138737
08/22/16 05:49 PM
08/22/16 05:49 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If those cool billet arms are aluminum and are supposed to bolt on the end of a piece of steel tubing as the anti-roll. It WILL eventually elongate the hole in either the tubing, the arm or both and you have slop. At that point the anti-roll is useless
Re: Should I add a ARB to the mix [Re: Monte_Smith] #2138742
08/22/16 06:00 PM
08/22/16 06:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The S&W ARB kit has splined arms and a bolt...
they offer 2 different widths... so measure what
you need.. I had to go narrow
wave
Re: Should I add a ARB to the mix [Re: Monte_Smith] #2138751
08/22/16 06:16 PM
08/22/16 06:16 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
No they are steel. Need to be welded onto 1.5" tubing. I have a Chassis Engineering Top Gun ARB for my RoadRunner. Arms are fully welded. The billet arms would save a lot of welding time over the TG piece.
Re: Should I add a ARB to the mix [Re: turbo toad] #2138753
08/22/16 06:17 PM
08/22/16 06:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Re: Should I add a ARB to the mix [Re: turbo toad] #2138907
08/22/16 09:16 PM
08/22/16 09:16 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I assume this car will be street driven. I will give you the advice that I give anyone who asks.
"I" wont put a rear bar on a car with stock(ish) front travel/suspension unless it has a front bar. I've seen WAY to many cars get a little out of shape and have the action exaggerated by the stiff rear and loose front.
If you go with a rear bar, make sure you have one in the front also.
Watch youtube. Any drag car crash video compilation will show this in action. You will see the car sway a little bit, one rear tire will come off of the ground, the car will act like a tricycle and boom. Done.
Don't misunderstand. I don't blame the bar for the initial looseness, but the ability to correct a car that has stock travel in the front, no front bar, and a stiff rear is a handful, even for an expert driver like me grin
Re: Should I add a ARB to the mix [Re: turbo toad] #2138994
08/22/16 11:13 PM
08/22/16 11:13 PM
gregsdart Offline
gregsdart  Offline
Or you can build your own
Re: Should I add a ARB to the mix [Re: TRENDZ] #2139107
08/23/16 01:36 AM
08/23/16 01:36 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Say huh...what? I am definitely not following. The anti-roll prevents body roll. And nothing that has enough power to NEED and anti-roll should never have the front end sloppy loose
