Re: Dominator or 4150?
[Re: Oldbracketracer]
#2160178
09/23/16 03:27 PM
09/23/16 03:27 PM
Thumperdart
State of confusion
UPDATE-Finally got the opportunity to try this change and the preliminary results are mostly encouraging. I removed a team G single plane manifold with a Bill Mitchell Hardcore 750 that I believe was pretty well set up. I installed an Edelbrock Super Victor manifold with the previously mentioned 1050 that had been worked on by Thumperdart. I have to say that I have never seen a carb that seemed to be this close to right out of the box. I set it up based on info from Thumperdart, the man seems to know his stuff. Out of the box,allowing for weather data, the car picked up .06-.08 (1/8 mile) and almost 1 MPH. Incremental numbers led me to believe the car wanted more starting line rpm, I bumped the launch chip 600 rpm, the car launched much harder, picked up.04 in 60 ft., however turned right and forced me to abort the run. Some suspension adjustment will be needed from here. Keep in mind this was a T&T night at my local track, normally an excellent racing surface, but still it was a T&T. The crowd was huge and it wasn't (at least in my mind) practical to do anything further that night.Plug color looks close to optimim, car starts and idles well, over all pretty happy so far. Should be more improvement available with a little more tweaking. That`s the news I live for and know there's more there for sure........... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
#2160742
09/24/16 11:25 AM
09/24/16 11:25 AM
Posts: 1,030 ohio
67mprfan
ohio
Glad you got to see some good results from it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Thumperdart]
#2160838
09/24/16 01:49 PM
09/24/16 01:49 PM
Posts: 1,030 ohio
67mprfan
ohio
The carb WASN'T the issues you were having unfortunately but at least it`s back in service and it sounds like you guys found some fixable power......... Never said I had a issue with the Carb
[Re: 67mprfan]
#2161153
09/25/16 12:43 AM
09/25/16 12:43 AM
Posts: 38 Ohio
Oldbracketracer
Ohio
Glad you got to see some good results from it Looks like it's going to work out well for me, thanks for hooking me up with a good deal on it.
[Re: 67mprfan]
#2161332
09/25/16 01:13 PM
09/25/16 01:13 PM
Thumperdart
State of confusion
The carb WASN'T the issues you were having unfortunately but at least it`s back in service and it sounds like you guys found some fixable power......... Never said I had a issue with the Carb Then why sell it? ![work work](/ubbthreads/images/graemlins/custom/work.gif) You also said you were going in a different direction as in late model efi so a bit confused but none of my bizz just trying to keep up.......... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
