Re: 70 Hemi Cuda pulley questions...........
#213790
02/04/09 09:50 PM
02/04/09 09:50 PM
Posts: 2,484 Minneapolis, MN
hemi70se
Minneapolis, MN
Wow............what a basket of worms.........
I should have mentioned that I don't think this is an original balancer because it's marked in 2 degree increments like most aftermarket ones.........
It was real common for racers to add degree grooves to original balancers. So, what you have is a modified original.
The Ebay ad for the 059 alt pulley is the correct one. Sure is strange that he's the only one whos ever got them for sale. Buy that pulley along with a repro water and crank pulley (I'd suggest Hoover's) and you'll be done straightening out that car.
[Re: hemi70se]
#213791
02/04/09 11:47 PM
02/04/09 11:47 PM
So, you're sure that I have an original balancer? I guess I'd have to for all of the early Hemi pulley's to line up??? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I just bought that pulley on eBay........ ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mopar mike]
#213793
02/05/09 09:04 AM
02/05/09 09:04 AM
Posts: 4,799 ILL
MLR426
ILL
not to be smart, but isn't the power steering pulley on backwards??
No it isn't. This thread shoud be achieved.
logan426
[Re: mopar mike]
#213794
02/05/09 09:32 AM
02/05/09 09:32 AM
Yeah, it looks that way, but the piece where you attach a puller to pull it off is on the front........ ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Snoopy]
#213798
02/05/09 06:10 PM
02/05/09 06:10 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
There are plenty of 2875 711 alternator pulleys around, you just have to make a spacer to use it.
Do you know how thick that spacer needs to be , I have a number of original double pullies . Also is that pulley needed on the 68 down pulley arrangement ? I have a repop 69-71 water pump pulley , but a Fluidampner, so I can use std B/RB pullies instead of getting a hemi lower pulley and a spacer .
In Wayne's pics it looks like a single groove alt pulley will work , is that a special pulley ? My junk doesn't have to look correct , it just has to work .
[Re: HPMike]
#213801
02/05/09 09:28 PM
02/05/09 09:28 PM
Thanks Mike........and MOPARTS, So, what's the reasoning on the thick balancer? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I didn't realize they even offered that.........
[Re: Snoopy]
#213802
02/05/09 10:04 PM
02/05/09 10:04 PM
Posts: 2,655 western PA
mopar4ya
western PA
Yes, late 68-71.
Comparison between Hemi (LH) and non Hemi (RH) alternator pulleys.
Did someone in the aftermarket have these back in the day, or was this always a chrysler part only?
Dan
#213803
02/06/09 10:56 AM
02/06/09 10:56 AM
JohnRR
Street Hemi's have always had the thick dampner , Why ??? I have no clue Chrysler put the thin ones on the crate motors , why again ??? maybe to use up parts laying around in inventory considering the mismatch of parts on my heads ???
