Anyone ever test running only one plug vs two? Loss of HP?
#2122520
08/01/16 11:50 AM
08/01/16 11:50 AM
Posts: 577 Arkansas
Adrielp
Arkansas
Anyone ever done this and what were your results? I know there would be a loss of combustion efficiency but that doesn't always result in power loss.
This is more theoretical thinking out loud but here is the reason I ask. If you were to revise the left or right spark tube to instead exit the cylinder head at what would be the center of the spark plug tubes at the top of the cylinder head, you be much more free to get the valvetrain geometry more correct. Given there is already some misalignment in the z axis that can only be modified with offset lifters or adjusting the lifter bore spacing, you could at least get both pushrods in line with the lifter bore angles in the x-y plane. Also, it definitely seems like Steel rockers give you best chance to get the most clearance as well since you don't have to use as much material to make them work well.
Adriel Paradise Substation Design Engineer III
Re: Anyone ever test running only one plug vs two? Loss of HP?
[Re: Adrielp]
#2122586
08/01/16 01:39 PM
08/01/16 01:39 PM
Posts: 112 Michigan
ghinmi
You couldn't go to a single plug centered, the valves would be in the way or would have to be very, very small.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: ghinmi]
#2122633
08/01/16 02:29 PM
08/01/16 02:29 PM
Posts: 577 Arkansas
Adrielp
Arkansas
You couldn't go to a single plug centered, the valves would be in the way or would have to be very, very small. Not centered in the chamber, only centered at the top.
[Re: Adrielp]
#2137068
08/20/16 02:19 AM
08/20/16 02:19 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Nah, i'll just run all 16 and no plug wires.
Mopar to the bone!!!
[Re: Adrielp]
#2137114
08/20/16 08:55 AM
08/20/16 08:55 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Given the huge expense Mopar has spent over the years in development and production, I have to say they had to have seen an overwhelming benefit of the dual plug design. Whether that benefit is in power or emissions, I have not determined, but whatever it was had to offset quite significant cost increases. A
s I am in production of vehicles, I know those engineers had to make quite a case to management/penny-pinchers to get those extra 8 spark plugs per car, the added raw materials into the head and a coil to handle both plugs as well...and they won. I'll carryover their lessons learned and just run the 16 plugs, if it's just for emissions...well that's fine too. The cost is insignificant.
[Re: Adrielp]
#2147770
09/05/16 02:18 AM
09/05/16 02:18 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Wonder why BES would waste money putting 2 distributers on his prized Hemi engines.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Adrielp]
#2147779
09/05/16 02:39 AM
09/05/16 02:39 AM
72Swinger
Nebraska
I think it is part of the reason they dont need so much lead. Ask any Fuel team out there the same question.
[Re: Adrielp]
#2148817
09/06/16 02:35 PM
09/06/16 02:35 PM
Posts: 300 MA
Greg55_99
MA
[Re: GoodysGotaCuda]
#2150628
09/08/16 09:04 PM
09/08/16 09:04 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
s I am in production of vehicles, I know those engineers had to make quite a case to management/penny-pinchers to get those extra 8 spark plugs per car, the added raw materials into the head and a coil to handle both plugs as well...and they won. I'll carryover their lessons learned and just run the 16 plugs, if it's just for emissions...well that's fine too. The cost is insignificant. A little column A a little column B. The flame front can only travel so fast. Putting 2 plugs in the chamber the flame front doesn't have to travel so far (there is no "penalty" for the flame fronts crashing together) so you get a more complete burn which is good for both performance and emissions. The center plug is one of the benefits of the original HEMI design. For instance, if you have a 4" bore the flame front only has to travel 2" in any direction, with a wedge head, with the plug to one side of the cylinder, the flame front may have to travel up to 3.5" in one direction. As you can imagine, at higher RPMs the ability of the flame front to travel to the edges of the cylinder become more critical as there is less time to complete the burn. I suspect that they couldn't fit the plug in the center of the chamber without sacrificing valve size, so the nested a plug between the valves on either side. It probably didn't add too much to the cost of the coil packs, and at the volumes they buy spark plugs that probably wasn't a big deal either.
No longer taking $h!t from anyone!
[Re: Adrielp]
#2157120
09/18/16 11:52 PM
09/18/16 11:52 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
I tried it with only one plug. No difference in 1/4 mile times. I was running 10.2 at the time.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
