71 Duster V8 K frame #2127984
08/08/16 04:32 PM
08/08/16 04:32 PM
Atlanta Indiana
Dave Watt Offline OP
Atlanta Indiana
After disassembly I noticed this area looks to have been repaired on my 71 Duster 340 K-frame. My 73 doesn't look like this.
Can anyone tell me if this is correct?
Thanks in advance.
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128019
08/08/16 05:39 PM
08/08/16 05:39 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep that has been repaired. frown
JB Rhinehart, Realist
A-Body's RULE!
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128023
08/08/16 05:43 PM
08/08/16 05:43 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The car probably was owned by someone that neglected the lower control arm bushings until they went metal to metal. After that, the thin tube and meager weld in the K member starts to rattle loose.
When I prep a K member to install into a car, I'll weld washers to the area and grind it all smooth. The guy that did that just did a quickie job. It can be tuned up though. While out, I'd weld a washer on the other side to be safe. Be careful to use a washer thin enough to NOT push the LCA rearward by any amount. THIS causes a loss in caster!
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128029
08/08/16 05:55 PM
08/08/16 05:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Common problem on A-body K-members. The factory even knew it was an issue because on 340 cars, they added a half circle piece of metal around the area to beef it up.
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128189
08/08/16 09:25 PM
08/08/16 09:25 PM
Atlanta Indiana
Atlanta Indiana
Thanks everyone for the replies. I'll make it look like my 73 K-frame.
The exterior weld is actually very nice, inside, not so much. Even the paint looked factory.
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128297
08/08/16 11:28 PM
08/08/16 11:28 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Hello Dave, here's from my 71 duster project.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128344
08/09/16 12:06 AM
08/09/16 12:06 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I wrecked my 70 Duster back in 1982 and it punched the K member pretty bad. Had to have it welded up like that
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128387
08/09/16 12:51 AM
08/09/16 12:51 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've repaired a lot of K members that way. The damage isn't limited to A body K members, it happened across the board.
They really didn't like the load the big tires put on them on the local dirt tracks. Gene
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128634
08/09/16 12:59 PM
08/09/16 12:59 PM
Atlanta Indiana
Atlanta Indiana
Thanks for the photos Tim.
Looks like the driver side of mine hasn't been repaired.
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128790
08/09/16 04:43 PM
08/09/16 04:43 PM
Atlanta Indiana
Atlanta Indiana
The repair is on the right, factory on the left.
Re: 71 Duster V8 K frame [Re: Dave Watt] #2128828
08/09/16 06:19 PM
08/09/16 06:19 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The photo shows what appears to be no difference. The first picture in this thread shows a full washer welded on. The last picture shows a semi circle washer.
Are you sure that you didn't mix up the pictures?
