70 B Body Hydraulic Clutch master with Power Brakes #2123461
08/02/16 03:45 PM
08/02/16 03:45 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Does anyone have a picture of where they chose to mount the reservoir? Firewall space is kinda tight....
Thanks!
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 70 B Body Hydraulic Clutch master with Power Brakes [Re: AlexP] #2123641
08/02/16 08:28 PM
08/02/16 08:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Most of the Keisler hyd TOB installs I've done mount it here on the brake master cylinder...
Re: 70 B Body Hydraulic Clutch master with Power Brakes [Re: DAYCLONA] #2123661
08/02/16 09:12 PM
08/02/16 09:12 PM
IN
ahy Offline
ahy  Offline
IN
Mine is mounted in the same spot pictured by Dayclona. It has worked fine there.
