Page 2 of 7 1 2 3 4 5 6 7
Re: car won't 60 foot video [Re: birdtracker] #2118071
07/26/16 01:31 PM
07/26/16 01:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Yup, not enough gear for starters.
IMO, unless the motor is at least an honest 13.5:1cr, both the comp .690 and .692 rollers have too much duration for that combo.
And even at 13.5:1, I think for 1/8 mile racing especially, something shorter would be quicker.
The other thought I had was to try and verify you're getting a good clean release in the trans when you let go of the button.
If the 60' times are about the same when footbraking it, that would tell you the brake is releasing fully.
Re: car won't 60 foot video [Re: fast68plymouth] #2118098
07/26/16 02:20 PM
07/26/16 02:20 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
X2 on that cam, when I had a 3.9 stroke combo I switched from that comp .690 which is 287 @ .050 to a custom comp which was 276 @ .050 and picked up 2 tenths. I ran a 31" tire with 4.56's also.
Re: car won't 60 foot video [Re: birdtracker] #2118115
07/26/16 02:41 PM
07/26/16 02:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The 119 mph shows your making power. The converter might be the issue but you said you have try'd two. That MPH should be in the 1.20s sixty foot. The 1.76 glide is killing your sixty.
Re: car won't 60 foot video [Re: a493demon] #2118144
07/26/16 03:22 PM
07/26/16 03:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By a493demon
Looks to me like it's dead hooking and bogging it down.
Yep, needs a little wheel speed.
Re: car won't 60 foot video [Re: birdtracker] #2118302
07/26/16 05:20 PM
07/26/16 05:20 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
What's the weight? First off I would lay off the burnout. Mickey's don't need it. I'm not convinced you need that much more gear. I wouldn't go more than .88's personally. I still don't think the gear is your issue. I would take the timing to 38 and see if there is any change.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: car won't 60 foot video [Re: Eric] #2118361
07/26/16 07:03 PM
07/26/16 07:03 PM
birdtracker Offline OP
I tryed a 4:86 gear at the beginning of last year. It was screaming before the 1/8 mile. I do run some 1/4 mile such as Norwalk this weekend. I degreed the cam in and know its in at 106 unless something moved when I slide the gear drive cover on. I can check that. I was going to try timing this weekend and maybe a different carb. Thanks for all the suggestions. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2118380
07/26/16 07:23 PM
07/26/16 07:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What size dominator is it............My bad just saw 1050...... realcrazy
Re: car won't 60 foot video [Re: birdtracker] #2118462
07/26/16 08:58 PM
07/26/16 08:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Screaming? Mine was going 125 mph at 6100 with a 4.56 and 33 " tire, driveshaft speed, 5800. 60 was 1.2. Something might be amiss in the trans or converter.
1/8 mile
Re: car won't 60 foot video [Re: birdtracker] #2118736
07/27/16 12:31 AM
07/27/16 12:31 AM
So. Burlington, Vt.
So. Burlington, Vt.
I agree, that thing should be able to pull a 4.88 in the 1/4 with 32" tires no problem.
Re: car won't 60 foot video [Re: birdtracker] #2118778
07/27/16 01:26 AM
07/27/16 01:26 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
9.97 @ 135 mph. 6,500 trap speed. 14 x 32 4.56 gears.
[image][/image]
Re: car won't 60 foot video [Re: birdtracker] #2119007
07/27/16 12:59 PM
07/27/16 12:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
I guess maybe we need to backtrack a bit......
What is the motor build like? Compression, heads, intake, headers, etc?
What does the car weigh?
What do you expect it to run in the 1/8 and 1/4?
Re: car won't 60 foot video [Re: birdtracker] #2119069
07/27/16 02:30 PM
07/27/16 02:30 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Heck I ran 5.13's for a while with that cam....7400 thru the traps......1/4 mile also.
Re: car won't 60 foot video [Re: B1MAXX] #2119242
07/27/16 07:05 PM
07/27/16 07:05 PM
https://www.youtube.com/watch?v=H7NWfO---hE
here is a video that shows the tach over on the left. Leaving at 5,000. It doesn't rpm like I would expect. Birdtracker
Re: car won't 60 foot video [Re: birdtracker] #2119260
07/27/16 07:27 PM
07/27/16 07:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What was that 60 cos it seems to lay down then pick up...........
Re: car won't 60 foot video [Re: birdtracker] #2119288
07/27/16 07:54 PM
07/27/16 07:54 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
Re: car won't 60 foot video [Re: birdtracker] #2119340
07/27/16 08:38 PM
07/27/16 08:38 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
From the last video I'd recommend trying different gear ratio.
Re: car won't 60 foot video [Re: 1980volare] #2119349
07/27/16 08:51 PM
07/27/16 08:51 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Post the timeslip let us look at the increments
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: car won't 60 foot video [Re: birdtracker] #2119411
07/27/16 10:13 PM
07/27/16 10:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Must be the motor build and car weight are top secret.
Re: car won't 60 foot video [Re: birdtracker] #2119428
07/27/16 10:30 PM
07/27/16 10:30 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If that mph is right the car has decent power. Big block A-body..........so what? 3000lbs. If that is accurate, for that mph, 700ish horsepower. HP based on the ET and weight would be 150 or so less. So the car is WAY down on power early. General consensus here is add gear and while that may help, the problem appears that the converter is way wrong or broken. 4.10 is enough gear. May not be optimal, but it's enough for this car to 60 way better than it does
Re: car won't 60 foot video [Re: fast68plymouth] #2119430
07/27/16 10:33 PM
07/27/16 10:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Must be rather lite, all that aluminum inside, did you see the in car video?
