Re: Fusible link or glass fuse
[Re: Publicbottle]
#2120743
07/29/16 05:11 PM
07/29/16 05:11 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Do I understand your plan (MAD?) correctly, you want to fuse the output of the alternator, it s rated amperage is, and if so, why? http://www.delcity.net/store/Maxi-Fuse-Holders/p_11183
[Re: Publicbottle]
#2120793
07/29/16 06:10 PM
07/29/16 06:10 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Do I understand your plan (MAD?) correctly, you want to fuse the output of the alternator, it s rated amperage is, and if so, why? He is referring to the Mad Electrical upgrade found in this link. http://www.madelectrical.com/electricaltech/amp-gauges.shtmlBasically it amounts to running a large wire from the alternator output stud directly to the starter relay. You are bypassing the bulkhead connector and charging the battery in a more direct fashion.
[Re: Publicbottle]
#2120797
07/29/16 06:17 PM
07/29/16 06:17 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
To the OP, are you planning on keeping the stock alternator wire hooked up or are you going to remove it? If you are leaving the stock wire in place, I think it would be OK to run a fuse. If the fuse blows, you still have the original wire there as a backup.
I haven't decided what I want to do yet as far as protecting that jumper wire on my car. Technically, you could have a short in the center of the wire. 1 link or fuse at the end of the wire won't cut power to that wire.(power will still be fed from the other end) I think I want to run a link/fuse on each end. That way if there is a short, both will blow and the jumper wire will be completely dead.
I'll also add a fusible link to the existing output wire right off the alternator. With a jumper wire in place, you are now feeding the interior with two wires.(original charge wire is now feeding interior as well)The one side already has a fusible link. With a link added right off the alternator, both wires are protected from an interior short.(both links should blow and cut all power to the interior) Basically I'll be doing what the MAD article says except I'm leaving the original wire hooked up to the alternator instead of connecting it to the starter relay.
[Re: Publicbottle]
#2120897
07/29/16 08:52 PM
07/29/16 08:52 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The Glass Fuses, and ANL/MIDI/Maxi/fuseable link are different in function and rating. The glass fuses open quickly (less than a second) at their rated capacity, so a current spike will take one out easy. The ANL/MIDI fuses are slow to open. I think the spec for 100% current rating an room temp is around 100-Hours for the fuse to blow? These are usually sized to they blow when the current is around 150%-200% the rated current, and it may still take a minute at the rating to blow.
Usually a fast acting glass fuse is used to protect an electronic component part of hardware like the radio, and the ANL/MIDI/Maxi/fuseable are used to protect the wiring from melting in short circuit conditions.
Most cars use the glass and little fuse, fast acting fuses, to protect the hardware and wiring. I think this is mostly because of the lower cost and smaller size of those fuses.
The smaller mini-ANL fuses are popular for wiring stereo equipment, and are available in many current ranges, so they make a good replacement for fuseable links, and fuses for most car stuff like cooling fans and fuel pumps that have a high in-rush (initial) current spike.
[Re: 451Mopar]
#2120927
07/29/16 09:31 PM
07/29/16 09:31 PM
jcc
Bitopia
I understand now what the plan is, but unclear "why" the OP needs a fused alternator feed, most cars of our era never had one, intentionally, the bulkhead solution/bypass is certainly advised, but the fuse, I don't know. Francis wiring? had a graphic posting on the downsides of fusible links, that would most think twice about the benefits.
[Re: jcc]
#2120982
07/29/16 11:18 PM
07/29/16 11:18 PM
Posts: 885 alberta
Publicbottle
alberta
I understand now what the plan is, but unclear "why" the OP needs a fused alternator feed, most cars of our era never had one, intentionally, the bulkhead solution/bypass is certainly advised, but the fuse, I don't know. Francis wiring? had a graphic posting on the downsides of fusible links, that would most think twice about the benefits. Here is the article I believe you are referring to. http://www.dragzine.com/tech-stories/ign...francis-wiring/
[Re: jcc]
#2121092
07/30/16 02:59 AM
07/30/16 02:59 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I understand now what the plan is, but unclear "why" the OP needs a fused alternator feed, most cars of our era never had one, intentionally, the bulkhead solution/bypass is certainly advised, but the fuse, I don't know. Francis wiring? had a graphic posting on the downsides of fusible links, that would most think twice about the benefits. They had the alt output fused by a fuseable link. It was usually at the starter relay because the alt output wire on a stock setup on our older Mopars goes back to the ammeter and through the ammeter back to the starter relay through the fuseable link. If the alt or the alt out wire shorts it will blow out the fuseable link at the starter relay. The output wire is not a dedicated wire with the stock wiring. Course when you run a dedicated output wire the ammeter wont show a charge. Ron
[Re: Publicbottle]
#2121106
07/30/16 03:40 AM
07/30/16 03:40 AM
RapidRobert
as said definitely not a glass fuse. the Madd bypass is used but will render the ammeter inaccurate. seperate issues. I have not done it but I dont see a problem with a piece of 14 ga FL at the alt for the bypass EDIT (for your 10 ga bypass). In my exp fusible links open too late. way back on here an electronics guy posted an electronic fuse or circuit breaker that sounded like a good option. there's gotta be a better way to protect the circuit. on my old '66 the wiring insulation melted/shriveled & the fl did NOT open
