Page 3 of 3 1 2 3
Re: auto body cost question [Re: 67autocross] #2121088
07/30/16 02:49 AM
07/30/16 02:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By 67autocross
Take it to Canada to get painted, with the exchange rate a $ 15000 paint job will cost you $ 11500 US
The problem is getting the correct paint into Canada.
Plus you will lose that delta on all the money you blow on Molson while you are there.
Re: auto body cost question [Re: eightlitermopar] #2121170
07/30/16 10:48 AM
07/30/16 10:48 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
After painting I spent 70 hours sanding to 3000 grit, 3 pad buffing/polishing, and clean up on a 69 GTX! But it is nicer than 99.9%.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: auto body cost question [Re: DAYCLONA] #2121177
07/30/16 11:07 AM
07/30/16 11:07 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By DAYCLONA
here's approx 30 hrs a week. Mike
Gawed!!!
That is one Be-You-Tee-Full paint job. up
Would LOVE to see an example of that kind of work in...
Medium Blue metallic.
I have mechanical Aptitude.
I can screw up anything.
Re: auto body cost question [Re: astjp2] #2121213
07/30/16 12:09 PM
07/30/16 12:09 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
Originally Posted By astjp2
But I watched Chip Foose do it in a week...... violin
I assume this was a sarcastic comment, but I still must reply to it because I hear this a LOT.
yes he CAN do it in a week.
but there are a few things you don't see.
first there are probably at least 5 guys working 12 hour days doing the job. that's 60 hours used in 1 day. multiply that by 5 days that's 300 hours in 1 week. yes it was done in 1 week but a months worth of labor was used.
second his top of the line paint jobs aren't done in 1 week. primers and top coats need time to properly cure. I don't care how much you heat them to cure the primer, and use special short wave lamps to speed cure. it takes time to properly cure primer and top coats until it fully shrinks and fully gasses out. also even the really high solids primers still have solvents in them. I use the newest PPG high solids urethane primer. it cures quickly but I have seen jobs months later and they still soak down and shrink. not as bad as the older stuff but it still shrinks.
I also use water based speed primer. it's not as fast it's advertised and it shrinks also. I also really don't care for how it sands.
the only exception I have seen to this is UV cure primer. I have only seen this used in paint school. prime, UV lamp for 5 min, sand. biggest problem is $$$. the primer is $$$ and the lamps are $$$. and the lamps only do small areas, so the side of a car takes longer than regular primer.
ok rant off.
perception is 90% of reality
Re: auto body cost question [Re: Morty426] #2121236
07/30/16 12:38 PM
07/30/16 12:38 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
You can all the paint you want here....and even more beer!
A new iron curtain drawn across the 49th parallel
Page 3 of 3 1 2 3
