Howards timing chain question
#2119638
07/28/16 08:43 AM
07/28/16 08:43 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Is the Howards #94340 billet timing chain a good unit ? Billet 9 key way . Or should i buy a Cloyes . For a big block with solid flat tappet cam , street and bracket racing
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Howards timing chain question
[Re: tex013]
#2119657
07/28/16 09:29 AM
07/28/16 09:29 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Pro Gear from Hughes engines is a good set for the money.
The only Carbs I care about are under the hood!
[Re: tex013]
#2119737
07/28/16 11:54 AM
07/28/16 11:54 AM
Posts: 326 Alberta
Wookie316
Alberta
I have a Howards in my 440. I thought it was a good unit for the price. Fit nice and snug, not excessively sloppy like some you get.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
