Opinions on Thermoquad Carbs? #2118320
07/26/16 05:59 PM
07/26/16 05:59 PM
Albuquerque, New Mexico
moparmatt Offline OP
Good Bad? I still have a couple on a a couple cars I have restored but as an everyday going to work vehicle Ive heard nightmares from some? I am restoring a 1978 dodge power wagon factory 440 automatic with A/C still has thermoquad a couple friends said get if off there before it burns up? Let me know what you all think?
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118443
07/26/16 08:43 PM
07/26/16 08:43 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
My opinion is find something you know how to work on if you intend to daily drive. I always liked my thermoquad with my 318. However, I was never comfortable with it. My Holley is idiot proof so even I can work on it. Lol. I do intend to go back to using it when I get my next engine finished. Non daily driver so I can live with it just to hear those four barrels opening up again. Haha.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118541
07/26/16 10:01 PM
07/26/16 10:01 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
TQs are the best street carb hands down. Anyone that says otherwise doesn't know how to set one up
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118547
07/26/16 10:03 PM
07/26/16 10:03 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
I just rebuilt the TQ on my '72 Challenger. I love it, but if you, or whoever works on it doesn't know what there doing, they can be a PITA. back in the 90's when i use to have a 440 in my Challenger, it would run 12.0's all day long with a TQ.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118557
07/26/16 10:09 PM
07/26/16 10:09 PM
I am restoring a 1978 dodge power wagon factory 440 automatic with A/C still has thermoquad a couple friends said get if off there before it burns up? Let me know what you all think? Thanks
yes they can be finicky (but we are the complaint/fixit dept so we get all the problems) but you have it & I'd kit it & (highly) likely you will be fine. the black phenolic bowls have warped on a few of em. make sure your choke is working correct (flooding is a frequent complaint). it is one of the finest OE carbs out there & compares to the rochester quadrajet as far as metering systems. You may need to richen (drill out) the jets.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118579
07/26/16 10:29 PM
07/26/16 10:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Nothing like the sound of a TQ when the secondarys open.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118581
07/26/16 10:30 PM
07/26/16 10:30 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Thermoquads are great if you are willing to pull them off and re-kit them about every other year, and adjust them every "season" for proper operation.
I pulled the the one off my last carbed daily 3 years before the truck got wrecked. I was tired of constantly jacking with it. The last 3 years of its life, I ran a Carter AVS. It ran untouched those last 3 years, and would have continued to function correctly for at least a few more.
The truck ran a lot harder with the Thermoquad (when it was in tune) then it did with the AVS, but the AVS didn't need constant attention. I've been carb free since 2011 (except the mower) and I intend to stay that way. Gene
Re: Opinions on Thermoquad Carbs? [Re: poorboy] #2118746
07/27/16 12:39 AM
07/27/16 12:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I'll debate you on doing it every other year,been running them since the early 70's,A/B and C body,hardly ever had to touch them.Biggest issue is having someone doing one that isn't familiar with the adjustment procedure.There are about eleven steps,do a few out of sequence and you mess up the balance.As far as burning up,I have yet to see the first.This one on this 71 Dart went untouched for over 7 yrs.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118802
07/27/16 02:20 AM
07/27/16 02:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They are a good carb. But if you or whoever works on yours cars they need to understand the Thermoquad and know how to work on it so it functions right and will run great. They are not a carb that you want a backyard mech tearing into if they dont know how they work. They are a very good carb when working right. Ron
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118815
07/27/16 02:56 AM
07/27/16 02:56 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I would probably try and keep the T Quad in your case they generally get fairly decent mileage (if thats a concern of yours) compared to aftermarket performance carbs plus they usually do very well at full throttle opening and you don't have to mess with all the linkage, fuel line, and possibly adapters needed to change carbs. One area I had problems with on some of the T Quads is the the off idle throttle stumble which seems to be related to them being very lean and also some of the accelerator pumps you get in the carb kits are junk.
I tend to prefer the squarebore carbs over spreadbores for my type of spirited driving they tend to have better off idle throttle response depending on how well the carb is matched to the combo and they take less throttle movement to get a desired result when your doing anything other than going full throttle. Just my opinion.
Re: Opinions on Thermoquad Carbs? [Re: stumpy] #2118941
07/27/16 11:38 AM
07/27/16 11:38 AM
Banana Republic
FM3AAR Online content
FM3AAR  Online Content
Banana Republic
+1 thumbs
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Opinions on Thermoquad Carbs? [Re: poorboy] #2118943
07/27/16 11:39 AM
07/27/16 11:39 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I disagree with much of the comments in this thread.
I daily drove my satellite for 10 years with a thermoquad on a 440. Anyone who says you need to rekit them every year, constantly retune them, deal with leaking phenolic bowls, live with poor throttle response and suffer with an overall finicky carb is either full of bull or just regurgitating what they've read on the internet.
A well tuned thermoquad is the next best thing to fuel injection. Number 1 issue is guys don't know how to tune them, then blame the carb for their own shortcomings. There is a lot of tuning that can be done on them without changing parts. You bend linkages to tune them. Number 1 issue is getting the choke setup right. You tune the choke so the choke flapper door does not fully close. It should stay open in the front by a pencil width. If yours closes fully, you've set it up wrong. After that, even at below freezing temperatures, mine would fire up easy, and I could kick it down and drive away after 30 seconds without any hickups. Then you will need to get your idle speed/mix setup right, however that's as easy as on any other carb. The hard parts come with getting the secondaries setup, many guys don't understand the relationships between the secondary air door tensioner, travel limiter and accelerator pump adjustments. Just because it looks like it's setup right, doesn't mean it is.
After I got mine dialed in, I drove it for many years without touching it. I only had to touch it again when I upgraded cam and cylinder heads. Throttle response is crisp, better than any newer pickup truck I've driven.
I've never seen a thermoquad with a leaking phenolic bowl. I did have one that was cracked, because the carb was thrown around in a pile of parts after it was removed from the vehicle. Not really the fault of the carb.
Biggest favor you can do yourself is to study the vaanth thermoquad guide (google it) and only run the 6000 series thermoquads. The later thermoquads, the 9000 series are emissions carbs, have varying levels of additional ports and are not preferable. The ones with a part number starting with a 6 are good pre-emissions carbs. Mine doesn't even have provisions for the charcoal canister, just one vacuum port for the distributor.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2118961
07/27/16 12:00 PM
07/27/16 12:00 PM
None
71rm23 Offline
71rm23  Offline
None
I was told the TQ and Quick Fuel carbs are similar. True? Thoughts?
Re: Opinions on Thermoquad Carbs? [Re: DaytonaTurbo] #2118963
07/27/16 12:05 PM
07/27/16 12:05 PM
ND
dodgedon Offline
dodgedon  Offline
ND
What about the aftermarket 9800 series carbs? These are not emission type carbs are they? The only difference I see is the electric choke.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Opinions on Thermoquad Carbs? [Re: DaytonaTurbo] #2118985
07/27/16 12:37 PM
07/27/16 12:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I would have continued as you did but didn't feel like typing everything,you got it right !! twocents
Re: Opinions on Thermoquad Carbs? [Re: dodgedon] #2119065
07/27/16 02:21 PM
07/27/16 02:21 PM
Manitoba, Canada
Manitoba, Canada
From what I have read you correct in that they are non-emissions electric choke carbs. I have never seen one in person however. The 4000 series competition thermoquads are out there as well, however same deal, I have never seen one in person.
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2119085
07/27/16 02:54 PM
07/27/16 02:54 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Years ago I had a 75 Road Runner I put a 71 440 in, slightly warmed up with a 292-509 cam, 452 heads with a port clean-up, and a factory iron intake with an 800cfm Thermoquad. Probably one of the funnest cars I've ever owned to drive - with a few tickets to prove it. Slightly lopey idle, crisp throttle response, and the trademark Thermoquad moan. Pulled hard from idle to 6000 - I'm pretty sure there would have been nothing to gain with a Holley carb.
While there is more to tune them than a Holley, a properly tuned one is a great performing carb.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Opinions on Thermoquad Carbs? [Re: Evil Spirit] #2119181
07/27/16 04:58 PM
07/27/16 04:58 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I worked in the factory that produced the thermo bowls and we pitched one out of every four for bubbles and vacuum leaks. I wish I would have kept a few of the marginal ones... frown
JB Rhinehart, Realist
A-Body's RULE!
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2119198
07/27/16 05:23 PM
07/27/16 05:23 PM
P
Paul_Fancsali Offline
P
I ran TQs for years and AVS { Much better reliability} About 16 years ago I took off the tq went to Holley and have not looked backThe Holley plain out performs the TQ not much if the tQ is tuned but I often wondered why my car would not make it down the track without busting up or vapor locking All TQ related found out you need the factory base gasket not a aftermarket. Suddenly I go down almost .5 and pickup 4 mpgh just by taking to a dbl pumper Holley after taht I took my well tuned but finicky TQ and sold itI still have around 7 cores and two new remans but they will sit till Holleys piss me off
Re: Opinions on Thermoquad Carbs? [Re: moparmatt] #2119206
07/27/16 05:52 PM
07/27/16 05:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
This iagree
I can't believe how much mis information is out there concerning these carbs, one of the, if not THE the most misunderstood and fantastic carburetor designs ever offered to the public.
