Re: Tools to remove snap ring on 727 clutch drum
[Re: SlickRS23]
#2117392
07/25/16 04:03 PM
07/25/16 04:03 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
Yes, use to use half of a muffler clamp and the press
Then made a tool using the same muffler clamp and a center bolt and some washers, lot like the factory tool.
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: 70AARcuda]
#2117431
07/25/16 05:13 PM
07/25/16 05:13 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
Was fortunate to acquire the original Miller tool years ago. Got one of those off ebay 12 yrs ago...for 50 bucks. Wow,that Miller Tool looked mighty familiar, once i saw a picture of it. Went and opened up a couple of storage containers, and come to find, i have one of them, too. Also used to collect, buy, Miller Tools, back in the old days. This one of mine has to be NOS, as i never used it, as i have the other tool, that i used all the time.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Adam71Charger]
#2119695
07/28/16 10:55 AM
07/28/16 10:55 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
cOOL TOOLS!
Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new? As far as re using,sometimes yes and sometimes no.The main reason to change the snap ring is to get the correct clearance between the pressure plate and snap ring if you change disc's.
[Re: Adam71Charger]
#2119716
07/28/16 11:24 AM
07/28/16 11:24 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
cOOL TOOLS!
Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new? it all depends on which they are and how they look. The one being talked about in this thread using the tools shown to aid their removal don't see a lot of abuse, and very little pressures, so there is no reason to change it unless it is damaged.
[Re: Adam71Charger]
#2119757
07/28/16 12:16 PM
07/28/16 12:16 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
cOOL TOOLS!
Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new? If you use the proper tool to depress the clutch spring retainer, it makes it much easier to remove the snapring.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: bboogieart]
#2119840
07/28/16 02:27 PM
07/28/16 02:27 PM
Posts: 8,374 fredericksburg,va
cudaman1969
fredericksburg,va
Works on other trans beside mopar. As far as changing snap ring, the ring could brake and the tangs on the retainer will hold it anyway, never seen a reason to change one in all my years.
[Re: Adam71Charger]
#2119912
07/28/16 04:12 PM
07/28/16 04:12 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
cOOL TOOLS!
Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new? The snap rings on the front clutch spring retainers can't pop off when correctly installed, there are tabs on the retainer to keep the snap ring in place and I've never seen one break.
[Re: SlickRS23]
#2121605
07/30/16 11:26 PM
07/30/16 11:26 PM
Posts: 145 Chicagoland 'Burbs
SlickRS23
Chicagoland 'Burbs
Thanks for all the replies, I learned a lot. I ended up purchasing this one: Tool #1 For $23.00 shipped it actually worked very well for a Chinese tool. After I deburred the bottoms of the legs so all 4 would sit flush, Cleaned up the threads on the ends of the rod and cleaned up the threads in the base, it worked very well. I don,t have a clue what the wing nut is for as I used a wrench. Just thought I would share my results with you guys. Thanks, Jeff
[Re: Adam71Charger]
#2121620
07/30/16 11:39 PM
07/30/16 11:39 PM
SlickRS23
Chicagoland 'Burbs
cOOL TOOLS!
Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new? Hanging around the maintenance guys at work, one guy told me that a snap ring like this should fit snug in the groove. The I.D. of the snap ring is slightly smaller then the O.D. it sits on. Before I assembled my drum I test fit the snap ring. It should turn by hand with a slight resistance. If it spins freely or moves side to side or is bent, it should be replaced. Same with the snap rings on the output shaft for the governor and bearing and the selective thickness snap ring on the front of the output shaft. Jeff
