Re: 318 valve cover leak
[Re: 77ProStreet]
#2116551
07/24/16 11:45 AM
07/24/16 11:45 AM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
Try a set of Mr Gasket ultras.If they dont seal something is bent or warped.My buddy just had a set or the high buck blues leak.Replaced them with the Ultras and no leaks.Silicone and cork dont mix.If you need to use both you have a problem.Rocky
Chrysler Firepower
[Re: 440_Offroader]
#2119951
07/28/16 05:14 PM
07/28/16 05:14 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't usually recommenced the use of silly-cone. However to verify it is the valve cover gasket, get both the mating surfaces super clean, don't even need to be completely flat. Put a 1/4 inch bead of the silly stuff all the way around on the head. Let it set up for a good 15 minutes. Put the cover on and lightly tighten the bolts till the silly cone just peaks out from the edge and let it set overnight. Once the silly stuff cures, it should not leak. If it does, then as mentioned above, it's elsewhere.
I have mechanical Aptitude. I can screw up anything.
