Page 2 of 11 1 2 3 4 10 11
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108386
07/12/16 12:36 AM
07/12/16 12:36 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
My question about the mono-leafs has to do with the double whammy of the car being a pack-mule, combined with rough roads. It's not unusual for a car on Drag Week to have 400 to 800 more lbs. in it over "race weight" while driving down the back roads.
I would love to start preparing for Drag Week 2016...but I haven't finished the 2015 story yet...
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: The Road to Drag Week, 2016 [Re: Bad340fish] #2108389
07/12/16 12:37 AM
07/12/16 12:37 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Originally Posted By Bad340fish
I am planning on dropping the new for drag week 416 in this weekend. I really want to get to the track this Month. Since the EFI is still new to me I want to try and get a handle on what this motor wants prior to drag week.
Any details on the new combo Clark?
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108415
07/12/16 12:58 AM
07/12/16 12:58 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
60 days, Billy...
That's a good question on the mono leafs Billy. I'm going to call Jay tommorrow and ask, I think he ran mono leafs on his Galaxy.
Good luck on the efi, Clark. You're braver than me.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108465
07/12/16 02:03 AM
07/12/16 02:03 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I just wrecked mine driving to the track on wet roads. Broke and twisted up my k frame.
Re: The Road to Drag Week, 2016 [Re: rt66jim] #2108566
07/12/16 10:09 AM
07/12/16 10:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Its a W2 headed 416 my Dad and I built last summer from a sum of parts we both had, mostly his. We were going to run it last year but thought we had a thrust issue so we pulled it the weekend before drag week and put the 360 back in. Turns out the thrust is in spec although on the loose side and the thrust bearing and surface look great.
68 Barracuda Formula S 340
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108568
07/12/16 10:14 AM
07/12/16 10:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted By Hemi_Joel
60 days, Billy...
Joel the EFI has been running on the 360 and I have been to the track with it. I Still have a little learning to do but it starts idles and runs the ET it should in the air conditions. I ran this EFI Controller(Megasquirt) to control my ignition last year so I have some time on it, although I still have lots to learn about what all it can do.
My car has Mono springs on it. DW12 was my first and I packed more than I needed and really beat the springs up. After 2012 I started swapping to an air shock for the road sections. Its not a big deal to swap them since I am already swapping tires. 30psi in the air shocks and it rides good and sits good.
After 4 DWs my mono springs were beat, I just replaced the rear halves with the stock ride hieght version and the difference between them and the old ones just laying on the ground is big. I haven't set the car down on the ground yet to see how much higher it made it but it needed to raise up. I am sure the beating I gave them on DW12 did them no favors at all, I have rub marks in my fenders from some of the "roads" and I just can't picture how a tire was able to make it up that far LOL.
Re: The Road to Drag Week, 2016 [Re: sixpackgut] #2108573
07/12/16 10:31 AM
07/12/16 10:31 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
No good man. Hope you're OK.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108579
07/12/16 10:51 AM
07/12/16 10:51 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I've been working on my 66 Plymouth that has seen street/strip duty for the last 15 years. Going to run DD or SRBBNA.
Things already done:
-Built a new, larger fuel cell w/ in tank pumps
-added elec fan
-wired horn
-Converted to TBI
-built hitch
-minor weight reduction
To Do:
-inspect rockers/valvetrain
-finish N2O install (although I won't be using it...or will I)
-Rollbar?
-balljoints/alignment
-build hitch/tire carrier
-make some passes, I haven't had it to the track this year, just street miles tuning the EFI
-determine if I am going to run 1 set of tires, or swap at the track
And yeah, they do look a bit better with bigger tires out back
Re: The Road to Drag Week, 2016 [Re: sixpackgut] #2108770
07/12/16 03:29 PM
07/12/16 03:29 PM
Minnesota
Minnesota
Are you OK? Can you fix it in time for DW?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108776
07/12/16 03:35 PM
07/12/16 03:35 PM
Minnesota
Minnesota
OUTLAWD, cool. We will probably end up in the same class.
I talked to Jay about mono leafs. He ran them on the Galaxie for 2 years without a problem, but he pulls a trailer so he only had a couple hundred pounds in the trunk.
I'll load it up and see how it looks. I don't know if my trunk monkey is up for switching air shocks/race shocks at every track. shruggy purple
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108818
07/12/16 04:35 PM
07/12/16 04:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Fwiw, my car worked just fine with mp xhd springs and cal tracs.
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108838
07/12/16 05:07 PM
07/12/16 05:07 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
You could always leave your umbrella at home? Less weight then.
You have a good trunk Monkey, but changing shocks every day? Only if you buy Texas Roadhouse every night...
69 GTX 68 Road Runner
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108863
07/12/16 06:11 PM
07/12/16 06:11 PM
Minnesota
Minnesota
Strategy for Drag Week attire: Save clothes all year that would have got thrown away. Put them in a suitcase, bring them on Drag Week. When they get dirty, throw them in the trash at the motel. No packing out dirty laundry! I learned this from former DW competitor Mike Moore. So what if you look like a hobo?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108871
07/12/16 06:26 PM
07/12/16 06:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For the amount they want for a T-shirt now...
your right... I use to buy the year old ones
for a cheaper price(4 for X amount).. what do
they want now.. $25 each
wave
Re: The Road to Drag Week, 2016 [Re: JERICOGTX] #2108893
07/12/16 06:55 PM
07/12/16 06:55 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
At least you don't have to buy a seat to ride in this one!
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2108922
07/12/16 07:45 PM
07/12/16 07:45 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Cool project
Good Luck!
Re: The Road to Drag Week, 2016 [Re: sixpackgut] #2109033
07/12/16 10:41 PM
07/12/16 10:41 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Ohhh man, say it ain't so!!! How bad is it?
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2109110
07/13/16 12:07 AM
07/13/16 12:07 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I gripe about it a lot but the shock swap is pretty easy. While I swap the shocks my dad caps or uncaps the exhaust and whoever is done first starts on the tires.
Re: The Road to Drag Week, 2016 [Re: Bad340fish] #2109120
07/13/16 12:21 AM
07/13/16 12:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I tried to build mine as a one man show.. now
I just have to swaps the cam and heads.. should
make close to the same power.. maybe 20hp less..
just a guess...I'll drag a small trailer.. no
changing tires and elec cut outs... I worry more
about the front suspension than anything.. one
big chuck hole could break a heim joint... I'm
thinking about bigger tubing and bigger heims
wave
Re: The Road to Drag Week, 2016 [Re: fast68plymouth] #2109154
07/13/16 01:11 AM
07/13/16 01:11 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
same as how I run my 68 Satellite plus Rancho rear shocks .
I drive to the track , and have driven a few times interstate . Race wheels , spare wheel , jack , spares , tools in the boot . Esky on the back seat if needed . No worries . All I do is empty trunk , swap rear wheels , adjust shocks (F&R) and fit carb air pan . Oh and hook up harness . About 30 minutes .
Done this for the last 5 or 6 years
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
