Thank, you, but does anyone know what the resistance value of the resistor is? Mine measures only .5 ohms. Also, It seems like I get low speed without a resistor at all. I put power to terminal "L" and it ran slow. Then went to terminal "H" and got high, then to the park switches and that worked. I just restored my motor and wanted to make sure everything is working correctly, and I want to know if I need a new resistor or not. Thanks for the diagram though, now I know for sure I had the wires connected correctly.
