Best aftermarket disc brake set up 69 b body #2112512
07/18/16 03:30 PM
07/18/16 03:30 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
Looking for the best disc brake set up. Right now I have manual drum brakes, and I want to keep the disc brakes manual as well. What is the over all best kit to go with and master cylinder to use. Just looking for mainly a street car 69 superbee, weight is about 3500lbs with a 4 speed.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: Best aftermarket disc brake set up 69 b body [Re: R_Blaha] #2112515
07/18/16 03:32 PM
07/18/16 03:32 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Dr.Diff/Cass would be your best bet including the master to go with it.
Re: Best aftermarket disc brake set up 69 b body [Re: OzHemi] #2112561
07/18/16 04:47 PM
07/18/16 04:47 PM
None
71rm23 Offline
71rm23  Offline
None
X2
Re: Best aftermarket disc brake set up 69 b body [Re: R_Blaha] #2112565
07/18/16 04:58 PM
07/18/16 04:58 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I used Dr.Diff for my front brake conversion in my 69RR. Works great.
Drum to Disc with manual master.
Re: Best aftermarket disc brake set up 69 b body [Re: Beep Beep] #2112822
07/18/16 10:28 PM
07/18/16 10:28 PM
dogdays Offline
dogdays  Offline
Good advice, but the proper reply to your question is, "How much do you want to spend?"
R.
Re: Best aftermarket disc brake set up 69 b body [Re: dogdays] #2112835
07/18/16 10:35 PM
07/18/16 10:35 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have used Dr. Diff for 3 disc brake conversions. Two of them were 13" front disc, but you have to go to 17" wheels with those. His prices are as good as I have found, but the main thing you get is service and hands on Mopar experience if you have any difficulties.
Re: Best aftermarket disc brake set up 69 b body [Re: R_Blaha] #2112924
07/18/16 11:50 PM
07/18/16 11:50 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Buddy of mine used a Dr. Diff kit on his Barracuda. He is extremely happy with it.
Re: Best aftermarket disc brake set up 69 b body [Re: dogdays] #2113805
07/20/16 03:45 AM
07/20/16 03:45 AM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
R.
I don't really have a price point, I'm just looking for a nice brake upgrade that I can run a 15inch wheel with. I don't want any cross drilled rotors or pro touring stuff.
1989 Mustang GT
1993 mustang lx 5.0
2013 CVO Roadglide
