Re: 727 HELP just stopped moving in forward and reverse
[Re: Alaskan_TA]
#2113675
07/19/16 11:09 PM
07/19/16 11:09 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
No, but they probably jacked up the car and put blocks under the springs, so the tires spin.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: scatpacktom]
#2113919
07/20/16 11:39 AM
07/20/16 11:39 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Pump ears/converter snout don't usually break on a 727 so it'll be interesting to see what the cause is ?
But no forward and no reverse means you either lost pressure pressure or a shaft broke ?
[Re: JohnRR]
#2114034
07/20/16 01:52 PM
07/20/16 01:52 PM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
But no forward and no reverse means you either lost pressure pressure or a shaft broke ? You're right that it is not a common failure but it does happen. I've repaired two 727's with broken pump gear lugs that I recall over the years. This is the reason for the max lug pump gears sold be vendors. 904's are more likely to break the converter snout.
[Re: JohnRR]
#2114118
07/20/16 03:46 PM
07/20/16 03:46 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Pump ears/converter snout don't usually break on a 727 More common than you'd think, lots have happened right here on this board. Another TF weak link.
[Re: scatpacktom]
#2115595
07/22/16 03:53 PM
07/22/16 03:53 PM
John_Kunkel
Rio Linda, CA
A faulty rooster comb will have lost motion (slop) between the detents when operating the shift lever by hand.
A faulty rear servo won't prevent the car from moving forward in Drive.
[Re: scatpacktom]
#2115641
07/22/16 05:23 PM
07/22/16 05:23 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
One of the "advantages" of getting older is you have less energy to try and fix things right away...... And as a result you get to ponder about them more before any actual work begins.
I don't know if this would be a valid test or not, but if the trans still had the pan on and fluid in it, if the pump ears were busted, then with the motor running and the trans in neutral, the level on the stick should still read way high, like if it was in park because the pump wouldn't be filling the converter. Yes??
Which made me wonder, is it possible the converter fill valve could be stuck and it's just "empty", making it so the car wouldn't move?
