Page 1 of 3 1 2 3
71 340 Cuda vs 67 440 GTX #211331
02/01/09 09:43 PM
02/01/09 09:43 PM
rtplumcrazy1 Offline OP
which is faster-my friends 71 340 4 speed cuda has a balanced engine with cam headers intake and carb-with 3.55 rear end gears-or my other friends 67 GTX 440 automatic with 3000 stahl cam headers intake and carb with 3.23 gears-who would you bet on-i have seen them street race but who would win a 1/4 mile speed contest daren
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: 71 340 Cuda vs 67 440 GTX [Re: rtplumcrazy1] #211332
02/01/09 11:25 PM
02/01/09 11:25 PM
Have them line them up at the track and find out
Re: 71 340 Cuda vs 67 440 GTX [Re: Cab_Burge] #211333
02/02/09 12:10 AM
02/02/09 12:10 AM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
I say the GTX. Big block with a converter to get it going should outrun the relatively stock smallblock.
Re: 71 340 Cuda vs 67 440 GTX [Re: BEEQUIK] #211334
02/02/09 12:26 AM
02/02/09 12:26 AM
Central NC
gch Offline
gch  Offline
Central NC
I would likely give the nod to the big block although the 3.23's may hurt a little.
It could easily be a drivers race.
Re: 71 340 Cuda vs 67 440 GTX [Re: gch] #211335
02/02/09 12:56 AM
02/02/09 12:56 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
GTX should be lighter, right? gtx gets it.
Re: 71 340 Cuda vs 67 440 GTX [Re: ademon] #211336
02/02/09 01:28 PM
02/02/09 01:28 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Uh, no, not right
Re: 71 340 Cuda vs 67 440 GTX [Re: ScottSmith_Harms] #211337
02/02/09 01:43 PM
02/02/09 01:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i bet the weight dif is not that much even with the hemi
Re: 71 340 Cuda vs 67 440 GTX [Re: ademon] #211338
02/02/09 01:49 PM
02/02/09 01:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Break out your wallet, I'll take that bet!
Re: 71 340 Cuda vs 67 440 GTX [Re: ademon] #211339
02/02/09 02:00 PM
02/02/09 02:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If the guy can shift a 4 speed I'd put my money on him,
also if they are running slicks. If on street tires
I might go with the GTX because of the gear
Re: 71 340 Cuda vs 67 440 GTX [Re: ScottSmith_Harms] #211340
02/02/09 02:05 PM
02/02/09 02:05 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Well i'm not a Mopar expert like yourself, thats why in my post it was phrased as a question, so what is the weight difference? I have never owed the two cars we are talking about.
Re: 71 340 Cuda vs 67 440 GTX [Re: ademon] #211341
02/02/09 02:58 PM
02/02/09 02:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Both cars are similar in wiegh if equipped the same, the Cuda may have a 100-200 lb advantage as a roller without an engine. The small block vs big will be the biggest difference, and that will undeniably going to favor the Cuda. Overall you are probably looking at 2-300lbs difference between them, maybe more.
Re: 71 340 Cuda vs 67 440 GTX [Re: ScottSmith_Harms] #211342
02/02/09 04:30 PM
02/02/09 04:30 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
the car on the right
Re: 71 340 Cuda vs 67 440 GTX [Re: rtplumcrazy1] #211343
02/02/09 05:09 PM
02/02/09 05:09 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Way too many variables to say, but if all things were equal my money would be on the GTX. The 'Cuda's gearing and weight advantage are too small to make up for the difference in power...in theory anyway.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 71 340 Cuda vs 67 440 GTX [Re: rtplumcrazy1] #211344
02/02/09 08:45 PM
02/02/09 08:45 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Way too many variables to call a winner here. Depends what cams, depends what headers, depends if the timing curve on both cars are set up correctly and the driver is a huge deal in these matchups.
I would bet a no option 440 automatic 67 GTX weighs within 100lbs of a small block 4 speed 71 Cuda but that could depend on options and how much bondo is in each car (seriously).
If both cars were stock I would bet on the Cuda if I was driving it, the 71 340's were the best year and the 67 GTX was hampered by a too small carb, a 71 340 Cuda 4 speed with 3.55's could touch a 14.0 if tuned and driven correctly, a lot of stock 67 GTX's were at 15.0
Sheldon
Re: 71 340 Cuda vs 67 440 GTX [Re: RUNCHARGER] #211345
02/03/09 12:56 PM
02/03/09 12:56 PM
P
Paul_Fancsali Offline
P
's on the Cuda all other things aside, the 340 was close to the real power output of the 67 440 the 340 was underrated the 440 was not making real 375hp in 1967
Re: 71 340 Cuda vs 67 440 GTX [Re: Paul_Fancsali] #211346
02/03/09 02:16 PM
02/03/09 02:16 PM
DPelletier Offline
DPelletier  Offline
We know the rated power shows a 100hp advantage to the 440, but I've never put that much stock in the ratings. I've heard the "real" gross flywheel number for a 340 is 320hp. How much power do you think a '71 340 makes? and the 440?
Of course the 440 would still have a significant torque advantage even if HP levels were identical and I agree with Sheldon; I doubt the weight is that far off.
I dunno....now if it was a 340 A body, then I could see the 340 out in front.
Re: 71 340 Cuda vs 67 440 GTX [Re: DPelletier] #211347
02/03/09 02:44 PM
02/03/09 02:44 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I love messing with big blocks,
Re: 71 340 Cuda vs 67 440 GTX [Re: ademon] #211348
02/03/09 04:21 PM
02/03/09 04:21 PM
P
P
Back in 1973 my friend had a 67 440 RT basically stock 440 4spd headers 3.54 Dana and slicks. I recall its 1st pass at the track was a 14.57 I know it went faster but not much that I recall can the 340 take a 440 Yes I have done it dozens of times I also have lost against the same 440 traction driving skills and In one case I blew my clutch apart. I love to watch and participate in races that are close
Re: 71 340 Cuda vs 67 440 GTX [Re: rtplumcrazy1] #211349
02/03/09 11:39 PM
02/03/09 11:39 PM
tough question-back in the day i raced my 71 340-4 speed Challenger against a 67 4 speed 440 GTX-it was prtty much a toss up-winner depended on who drove the best race-at that time my 340 was running 3.23 gears and the GTX was running 4.10 gears-i wonder what would have happened if i had 3.91's in the 340 challenger---previously the GTX had 4.56's---with the 4.56 gears it wasnt even a close race-the 340 car won every time-the GTX just didnt have enough top end to beat the 340
Re: 71 340 Cuda vs 67 440 GTX [Re: rtplumcrazy1] #211350
02/04/09 01:49 AM
02/04/09 01:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I gotta give the edge to the bigblock GTX. The E-bodies are not all that light as they weigh just about the same as a B-body if equipped the same. Now if it was an A-body 340 it would be a very close race but in this race I like the bigblock torque to take the win. Ron
Page 1 of 3 1 2 3
