Small block Mopar ProMaxx head testing
#2113121
07/19/16 11:21 AM
07/19/16 11:21 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My Son Matt sold his .040 over 360 shortblock out of his Duster a couple of months ago to a Friend. Needing a set of heads for it I have been researching ways for him to get the engine assembled and into a Dart that he recently bought. Knowing the Procomps (Speedmaster) had some issues I tried to find some info on the ProMaxx small block head that Jegs sells. With springs good for up to a 575 lift cam they cost slightly over 1400.00 a set shipped, app 200 plus dollars cheaper than Edelbrocks. I told him if he bought a set I would flow test them on my bench and strip on down to check it out for free. So far I have nothing but GOOD news for these heads and they put the Edelbrock heads to shame in both quality and flow numbers. The only issue I see so far is that the exhaust port flows almost EXACTLY the same as the Edelbrock head and they both have terrible (slow) air-speed on the exhaust side. He is going to install these as delivered so I can't wait to see the results. Air-speed at .500 lift on the exhaust port maxed out at 175-180 FPS and I good exhaust port should be at least 325 FPS and needs bell-shaped to get there. Both exhaust ports maxed out around 182-185 CFM and were checked without a ex flow pipe
-----Edelbrock--------------ProMaxx --------Intake-----------------intake .200-----128--------------------129 .300-----182--------------------184 .400-----215--------------------235 .450-----226--------------------251 .500-----233--------------------255-260 high air-speed .550-----236--------------------260 .600-----242--------------------264 .650-----243--------------------270 .700-----243--------------------263-270 .750----------------------------263-270
As you can see by the numbers this BOTH ports need more volume. The air speed on the ProMaxx at the pinch at .400 lift is 300 average (center) at the pinch and 370 on the pinch turn. At .400 lift 365 FPS-390 FPS on the short-turn. At .500 lift at the pinch center 340-350 FPS and 401 FPS (pegged my gauge) at the pinch turn. At .500 the short-turn is way high at 390-401 FPS (pegged). So far 4 valves were removed and the valve guide clearance is GREAT and a very nice at least 4 angle valve job done. The stainless valves look nice and come with a 30 degree backcut. I will be buying a couple sets of these later this year. One set with stock 2.02 valves and one set bare so I can go with a 2.08 valve
Re: Small block Mopar ProMaxx head testing
[Re: Porter67]
#2114293
07/20/16 07:24 PM
07/20/16 07:24 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks. Honestly I was starting to think it wasn't worth the effort even posting results or findings anymore. Fat guys are more worried about installing aluminum bolts to go faster. Lol
[Re: Porter67]
#2114302
07/20/16 07:36 PM
07/20/16 07:36 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good info John, I think by the lack of replies it shows the mopar world here is still reluctant to embrace the offshore castings even when looked at from a decent company with decent qc.
If this were 25 years ago or better most would think the top pics were the usa cast headand the lower being the china junk.
I know your all about buy usa but what can ya do when it seems edelbrock takes so much for granted or simply just dont care.
Would you trust this company and quality of parts to run every set ootb, or would you still pull them down for inspection? I am never going to install an out of the box head on any of my builds. A good friend bought a set of AFR chevy heads that were then sent out for some cnc porting. The flow numbers provided were 20 cfm low and the air speed was out of control. 2 valve guides were so tight I know for a fact he would have had issues. I was very glad he was at my shop to witness this. Some guys think all CNC'd heads are the same but trust me they aren't. I sure hope more of today's kids take an interest or years from now I see problems. Someone's gotta get dirty
[Re: pittsburghracer]
#2114325
07/20/16 08:41 PM
07/20/16 08:41 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Those are some pretty good numbers as-cast. What sort of rocker gear do they take? What size valve stem?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: sgcuda]
#2114700
07/21/16 12:15 PM
07/21/16 12:15 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
Vey Interesting and useful info.
What's very telling is the ~20 to 25CFM OOTB difference from .400 through .600 is going to be worth roughly 40HP or more to a combination with enough cam and compression to take advantage of it, that's a VERY SUBSTANTIAL difference.
The Story Bryce Mulvey (yes I am aware of the horror Show) told was that Procomp sent their Eddy clones to DrJ's/Airwolf for testing and they suggesting some mods to the roof and the next batch would outflow the Eddies. Full disclosure, my 414 motor has the Airwolf SBM (using Steve Dulcich's 408" shortblock) heads from the magazine article.
[Re: Streetwize]
#2114705
07/21/16 12:24 PM
07/21/16 12:24 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What's very telling is the ~20CFM OOTB difference from .400 through .600 is going to be worth roughly 40HP more to a combination with enough cam and compression to take advantage of it, that's a VERY SUBSTANTIAL difference. That's what I liked too. I'm thinking that with very little work these heads would go 280 plus and I mean very little. Bell shape the exhaust port to get some speed and let her breath.
#2114726
07/21/16 12:49 PM
07/21/16 12:49 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looks like they did a better job of the port entrance/exit than they did with the BB head.
I am a little puzzled why they cost $320 more than the BB heads though.
If you open the exhaust exit, won't it be out beyond the size of most headers?
I don't know if it's just the pics or what, but the roof of the intake port, adjacent to the guide boss, looks much more "normal" than the Edelbrock head.
[Re: fast68plymouth]
#2114729
07/21/16 12:56 PM
07/21/16 12:56 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you open the exhaust exit, won't it be out beyond the size of most headers? The exhaust port kinda has a Herman Munster forehead on the exhaust short-side and needs widened some and shaping. Like I said on these its all free checking for a Friend to get him up and running so the grinder won't be touching these. It will be a good test. On my car I will make the exit however I deem necessary because my headers (1 7/8 hedmen) have already been modified. The headers on my Duster are W2 headers with adaptors.
#2114741
07/21/16 01:06 PM
07/21/16 01:06 PM
fast68plymouth
So. Burlington, Vt.
What have you gotten out of an rpm head(intake port),and what was the runner volume when it was done?
#2114763
07/21/16 01:26 PM
07/21/16 01:26 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've never poured one after porting but I got 315-318 cfm with a 2.08 valve without moving the pushrod. Tubed but not moved and a lot of work. Bolt hole is also tubed but I do that on every Edelbrock head I port. K&S tubing makes it to easy not to. I won't be sonic checking the floor on this set but I'm betting they learned from Procomp (Speedmaster) to fill the floor some. From what I hear several guys approached Edelbrock about doing this and they didn't want bothered.
#2115442
07/22/16 12:37 PM
07/22/16 12:37 PM
fast68plymouth
So. Burlington, Vt.
That 315+ is way way more than I've gotten out of them. But, I'm usually going for the no-holes-no-tubes plan. I think low 280's is the best I've gotten out of a basic porting job, 2.055 valve. Those made 589hp on a 419.
#2115459
07/22/16 12:56 PM
07/22/16 12:56 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That 315+ is way way more than I've gotten out of them. But, I'm usually going for the no-holes-no-tubes plan. I think low 280's is the best I've gotten out of a basic porting job, 2.055 valve. Those made 589hp on a 419. This project was for a very good Friend that does my transmission work and it became a challenge project for me. They started out with me repairing a set of 400 dollar open chamber Edelbrock (340) style that I repaired then added a 2.05 valve. He was then curious how much we could get out of a 2.08 valve so I tried it. Without moving the pushrod I would NEVER do a set like this for anyone again, except for myself. A 2.05 is the way to go. He ended up never even using them and when he said he was going to sell them I bought them back because I had to much time in them to not have them. Being retired and not doing it for a living allows me to play around and I love flow testing and probing a port.
#2115461
07/22/16 12:56 PM
07/22/16 12:56 PM
Porter67
#2115467
07/22/16 01:03 PM
07/22/16 01:03 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Ok, good info.
So the procomp is the same as speedmaster? I do not like what i have seen in the procomp stuff for brand x
The promaxx is different then those castings?
I was in the market for sb heads and found it very confusing
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2115469
07/22/16 01:10 PM
07/22/16 01:10 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ok, good info.
I was in the market for sb heads and found it very confusing Did you watch the videos as they will answer a lot of your questions. This head is not even on the same page as the speedmaster (old procomp) and in my eyes so far is way superior than the Edelbrock.
#2115525
07/22/16 02:42 PM
07/22/16 02:42 PM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
Just to put this out there.... not a reflection on the Promaxx stuff. But I would find someone that has real world experience with them from a durability standpoint. My buddy just dropped off his truck with a very nice 496 stroker BBC short block topped with offshore heads and the quality of the guides and valves wrecked the whole thing. I am talking about mushroomed valve stems to the keepers , a valve that dropped a head off with no prior evidence of touching anything, valve to piston was .270, and valve guides that are .030, yes .030, out of round. The heads were very nice out of the box...I could not tell the metallurgical make up of the parts though. the casting looks ok even after all the destruction...... Has anyone run these heads for any extended period of time?
[Re: B1MAXX]
#2115529
07/22/16 02:47 PM
07/22/16 02:47 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
And what kind of heads were these. Please don't tell me procomp speed masters because there is a crazy amount of info out there to stay away from those heads.
#2115667
07/22/16 06:06 PM
07/22/16 06:06 PM
sixpackgut
Charleston
Ok, good info.
I was in the market for sb heads and found it very confusing Did you watch the videos as they will answer a lot of your questions. This head is not even on the same page as the speedmaster (old procomp) and in my eyes so far is way superior than the Edelbrock. Im in mexico. I will check them out when i get home
#2115672
07/22/16 06:13 PM
07/22/16 06:13 PM
B1MAXX
Apollo, PA.
And what kind of heads were these. Please don't tell me procomp speed masters because there is a crazy amount of info out there to stay away from those heads. These were not Procomp/ Speedmasters............
[Re: moderncylinder]
#2115684
07/22/16 06:39 PM
07/22/16 06:39 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Those are the ProComp/ Speed Master Heads Ok I always up for a good challange. I called and talked to PROMAXX in Alabama and Steven told be these are not Procomp (speedmaster) heads. 100 percent of the machining is done in house. So from this point on all the naysayers PLEASE start your own post and post any results YOU find. No wonder guys that used to pass tech on this site are in hiding and no longer post. PROMAXX http://www.promaxxperformance.com/index.php/racing-parts/sbc.htmlPROMAXX (Speedmaster) https://speedmaster79.com/contacts/
#2115687
07/22/16 06:42 PM
07/22/16 06:42 PM
fast68plymouth
So. Burlington, Vt.
If you go to the speedmaster website, it says that procomp is the sole US distributor for speedmaster. So speedmaster is procomp.
I can't speak about the SB mopar heads, but when the Sidewinder BB heads were first being talked about, one of the owners of the foundry in china confirmed that at least for the BB Mopar head that it was the same head as the ProMaxx head.
I just received a set of speedmaster BB mopar heads, and I can see no difference between these and the Sidewinder heads. They even came in the same looking box.
My guess is, the speedmaster/procomp/ProMaxx SB mopar head is all the same casting.
#2115696
07/22/16 06:56 PM
07/22/16 06:56 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Watch the videos on the valve guides. procomp like I said changed their name to Speedmaster because of poor reviews. They are sold right of the ship from China like all the junk electrical products. ProMaxx too recieves them off the ship from Chine as a rare casting then machined in-house adding to the price of the Speedmaster product. I'm done.
#2115711
07/22/16 07:18 PM
07/22/16 07:18 PM
fast68plymouth
So. Burlington, Vt.
I don't doubt the guides are better. When ProMaxx was Patriot they used to advertise that the guides were made and sized in the USA.
Edit- just checked one of my catalogs for ProMaxx, says all heads come with USA made guides.
#2115719
07/22/16 07:24 PM
07/22/16 07:24 PM
Porter67
#2115727
07/22/16 07:33 PM
07/22/16 07:33 PM
Porter67
[Re: Wedgeman]
#2115759
07/22/16 08:06 PM
07/22/16 08:06 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
to Bad our Promaxx heads didn't stand a few mile in a Little red.... a valve spring broke in 3 pieces and dropped a valve......
BUMMER......... Can I see some pictures of the head PLEASE. Front, back, ex side, and intake side please.
#2115765
07/22/16 08:16 PM
07/22/16 08:16 PM
Porter67
[Re: Porter67]
#2115780
07/22/16 08:37 PM
07/22/16 08:37 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
By reading that John it almost sounds like you dont think the guy is being truthful....or knows what he has. With that id like to see pics of the current small block procomp heads with trashed guides, Front, back, ex side, and intake side please.
And I will say PLEASE as well.
What it really comes down to imo, folks migh just buy the china castings and do your work and source your own parts.... its not that hard.
If the folks who simply buy the castings and put there names on them would be more upfront on every aspect of the product from castings, springs to valves as well as part numbers like edelbrock does they would sell more heads because the dyi guys will still do there own thing.
If I had a superior import cast head that was really different from the others Id have every other look alike torn down, cut up on my website to show "my" casting was really different from the rest.
But at the end of the day, most are drinking from the same well. A lot and I mean a lot of guys don't know what they have so yes I would like to see pictures from 4 angles. I will not buy a Speedmaster head (formerly PROCOMP) so I too am learning. Monte has spoken highly about ProMaxx heads before and being highly displeased with the quality of Edelbrock heads I started posting questions about the ProMaxx brand of heads. Probably 80-85% of racers entrust others to build their engines and don't know a Speedmaster from an Indy head if they held it in their hands. Like it says in the links I posted one place is in California and ProMaxx is in Alabama. Asking for pictures is a true way of getting quality information.
#2115787
07/22/16 08:47 PM
07/22/16 08:47 PM
fast68plymouth
So. Burlington, Vt.
I would assume, from the pics you've posted, if the head with a dropped valve is a ProMaxx head, it's CNC'd right into the end of the head.
#2115845
07/22/16 10:08 PM
07/22/16 10:08 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
Maybe... all of these heads (Speedmaster, ProMaxx, Airwolf, etc.) could all be manufactured at the same factory or factories in China. The head companies just place orders and have their name put on a box, or etched into the end of the head. https://www.alibaba.com/product-detail/S...4857.0.0.wvmncJSame for the big block casting out there. I bought some PC vectors after speaking with Jeff at MCH. He advised that the castings were decent but to buy them bare and build them using good valves, springs, etc.
[Re: camdog440]
#2115875
07/22/16 11:16 PM
07/22/16 11:16 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Maybe... all of these heads (Speedmaster, ProMaxx, Airwolf, etc.) could all be manufactured at the same factory or factories in China. The head companies just place orders and have their name put on a box, or etched into the end of the head. https://www.alibaba.com/product-detail/S...4857.0.0.wvmncJSame for the big block casting out there. I bought some PC vectors after speaking with Jeff at MCH. He advised that the castings were decent but to buy them bare and build them using good valves, springs, etc. That would be my thought as well.
[Re: B3422W5]
#2115915
07/23/16 12:06 AM
07/23/16 12:06 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
When given an reasonable option I will always put our own people to work..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2116010
07/23/16 09:15 AM
07/23/16 09:15 AM
Posts: 19,682 north of coder
moparx
with all that has been said so far, would/could it be possible to buy a set of heads that had problems real cheap, and rebuild them to some what acceptable standards using quality springs, retainers, guides, and seats, and have something usable on the low end of hp/torque for a reasonable/lower cost than spending big money up front ?[compared to rebuilding a set of iron heads]. this is just a rhetorical question. i'm guessing it would not be possible [unless a guy could do all the work necessary himself], but i'm asking because i will be needing heads in the future and pennies will be counted very closely. i understand also, a good,used pair of heads would be the way to go, but would still need disassembled and checked. just throwing this out there and hope not throwing the discussion way off track.
#2116056
07/23/16 11:39 AM
07/23/16 11:39 AM
sixpackgut
Charleston
Well, Im right back to being confused
[Re: B3422W5]
#2116076
07/23/16 12:09 PM
07/23/16 12:09 PM
B1MAXX
Apollo, PA.
Maybe... all of these heads (Speedmaster, ProMaxx, Airwolf, etc.) could all be manufactured at the same factory or factories in China. The head companies just place orders and have their name put on a box, or etched into the end of the head. https://www.alibaba.com/product-detail/S...4857.0.0.wvmncJSame for the big block casting out there. I bought some PC vectors after speaking with Jeff at MCH. He advised that the castings were decent but to buy them bare and build them using good valves, springs, etc. That would be my thought as well. All I would add to that is consider the guides also.... To all of this, all I would like to know is has anyone run a set of these successfully for an extended period of time....If 1 person has then we know it can be done. I know the set in this post is in very good hands. Wish that is all I would have said in my first post
#2116223
07/23/16 05:28 PM
07/23/16 05:28 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
People can believe whatever they want to.......but I know for a FACT that ProMaxx heads are machined and assembled here in the states. Guess I should have taken a picture of the pallets of raw castings to prove it. So while it IS an offshore casting.....it is NOT a China machined and assembled head with ProMaxx etched on the end.
ProMaxx is owned by Jason Collins. Former IHRA Pro-Stock racer and also owns the track in Steele Alabama. He bought the company from Mart Witt. It started out as Alabama Cylinder head and they mostly did refurbishes on stock stuff. Marty worked for ACH and pushed the owner to get into performance stuff, which they did and renamed the company Patriot Performance. When owner retired, Marty bought company. He and Jason have always been close friends and when Marty wanted out, Jason bought it. Last time I was there, Marty was still running the shop, but not sure he still is. As I said before, they have state of the art equipment and guys who know how to run it.
To prove the quality of the castings, Marty ran his own heads on his twin turbo, big block Chevy, drag radial car. They were off the shelf water castings and he runs 50 lbs of boost. Car has been 4 teens on a radial
[Re: WHITEDART]
#2116225
07/23/16 05:32 PM
07/23/16 05:32 PM
Monte_Smith
North Alabama
When given an reasonable option I will always put our own people to work.. Good luck with that. You will not find a foundry here in the states willing to do it for you at a reasonable price. Reasonable price, demands you order a crazy amount of castings. How many small block Mopar heads you going to sell? Guys complain to high heaven if the head is a nickel higher than someone elses, so US foundry is out of the question. Edelbrock can do it, because they OWN their foundry
[Re: Monte_Smith]
#2116226
07/23/16 05:33 PM
07/23/16 05:33 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
To prove the quality of the castings, Marty ran his own heads on his twin turbo, big block Chevy, drag radial car. They were off the shelf water castings and he runs 50 lbs of boost. Car has been 4 teens on a radial Thank-you Monte. After calling them yesterday and talking to Steven I felt pretty comfortable dealing with this company.
#2116271
07/23/16 06:59 PM
07/23/16 06:59 PM
B3422W5
Portage,michigan
Basically, they are offshore heads with USA assembly, sounds like. You can( and I did) throw great parts at W5 heads, but they were cast like feces. Ended up as sprinklers.
That said, no matter who cooks the steak, if the meat isn't any good, it's gonna taste like poo. That seems to be the question here, and at least regards the small block Mopar heads.... It appears to remain unanswered until somebody flogs them for a good spell if they will hold up.
Back to your regularly scheduled programming............
[Re: B3422W5]
#2116275
07/23/16 07:18 PM
07/23/16 07:18 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That was such a good post you had to say it twice. Lol. It comes down to some guys are happy running 12's, some 11's, some 10's, some 9's and some are always searching. I'm a budget racer that loves testing and pushing so I will have a couple of sets soon running in the 9's and pushing for more
#2116279
07/23/16 07:27 PM
07/23/16 07:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have seen that a lot of China castings that are better than American.. as much as I hate to say that... my MP M1 manifold looks like crap based on casting quality
#2116281
07/23/16 07:34 PM
07/23/16 07:34 PM
B3422W5
Portage,michigan
That was such a good post you had to say it twice. Lol. It comes down to some guys are happy running 12's, some 11's, some 10's, some 9's and some are always searching. I'm a budget racer that loves testing and pushing so I will have a couple of sets soon running in the 9's and pushing for more Lol... Nah.... Just back in from being out on the lake. 95 degrees today, and the water is 86. Little too much sun I think. Nobody says they may not be good, at any power level, just long term dependability seems to be the concern. I think it's a valid concern at this point in time. Don't you?
[Re: B3422W5]
#2116289
07/23/16 07:46 PM
07/23/16 07:46 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That was such a good post you had to say it twice. Lol. It comes down to some guys are happy running 12's, some 11's, some 10's, some 9's and some are always searching. I'm a budget racer that loves testing and pushing so I will have a couple of sets soon running in the 9's and pushing for more Lol... Nah.... Just back in from being out on the lake. 95 degrees today, and the water is 86. Little too much sun I think. Nobody says they may not be good, at any power level, just long term dependability seems to be the concern. I think it's a valid concern at this point in time. Don't you? No I don't. I honestly think at this time a ProMaxx head is BETTER than an Edelbrock head. I've never owned a Proform head (now Speedmaster) and never will. Way to may stories about falling out seats, broke valves, and broke springs for me to invest in them. I love the looks of these heads so far and can't wait to see how they perform out of the box with the flow numbers I provided. I hate what has happened to Edelbrock over the years and can only hope the new Victor head shows more Quality. I want a set soon. I usually buy my heads bare and upgrade to a bigger valve but before these are gone I want to try to track down what kind of valves are in them. I should have asked yesterday when I called but forgot.
#2116364
07/23/16 10:28 PM
07/23/16 10:28 PM
Porter67
[Re: 408Dust]
#2116704
07/24/16 04:15 PM
07/24/16 04:15 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Want to tell us why he is what you say?? Further, WHAT does that have to do with him showing us a head casting? Did he steal it or something?...LOL. The head he is showing us, is what IT is; has nothing to do with him. The fellow making these videos is a thief and full of crap FYI.
[Re: 408Dust]
#2116868
07/24/16 10:06 PM
07/24/16 10:06 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
True, but the vid where he sets himself on fire is pretty hilarious. Just asking, but would these heads support 530ish horse on a 408 without winding it to the sky?
[Re: slantzilla]
#2116888
07/24/16 10:42 PM
07/24/16 10:42 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
True, but the vid where he sets himself on fire is pretty hilarious. Just asking, but would these heads support 530ish horse on a 408 without winding it to the sky? Heck Ya with some porting work. I've gone 9.73 with Edelbrock heads with a 2.08 valve and stock pushrod location shifting around 6800 rpm in my duster. And these have more porting avalible if I am hearing right that the intake floor is poured solid. I won't be sonic checkng a set till I buy my own
[Re: slantzilla]
#2116899
07/24/16 10:59 PM
07/24/16 10:59 PM
B3422W5
Portage,michigan
True, but the vid where he sets himself on fire is pretty hilarious. Just asking, but would these heads support 530ish horse on a 408 without winding it to the sky? Easy. I went 10.70's shifting at 6600 with stage 2 eddies from Hensley(275@600) with a flat tappet and 727 at 3400 pounds with a cast crank 416. I figured that was probably 530-550. Absolutely nothing fancy. Small TTI step headers, excellerator intake, 4150 carb.
#2117076
07/25/16 05:12 AM
07/25/16 05:12 AM
slantzilla
Park Forest, IL
Sounds interesting. I'm wanting to end up running 10:50's @2850#. Should be a piece of cake.
[Re: slantzilla]
#2117241
07/25/16 12:58 PM
07/25/16 12:58 PM
Thumperdart
State of confusion
Sounds interesting. I'm wanting to end up running 10:50's @2850#. Should be a piece of cake. As long as you don`t go EFI that should be easy.........
[Re: Bad340fish]
#2117313
07/25/16 02:25 PM
07/25/16 02:25 PM
dogdays
What you naysayers are not getting, and probably that's because you don't want to, the China supply line is very much like a Chinese restaurant. The list of options is endless.
So when the Promaxx head guy orders up a set of bare castings, he can order any alloy he wants. It might cost him $5.00 per head.
He may be able to make mods to the casting cores as well. Bryce Mulvey talked about that when he was blowing up Moparts about the Airwolf heads. It was pretty clear from what he said that they were cast by/for ProComp and he made some changes to the port shape.
When you talk about keeping work in the USA, fine. I can go along with that. I write that into every specification I produce. BUT, keep in mind that the casting is probably the cheapest part of the head. Handling, machine work, valve guide and seat supply and installation, springs, valves are added. Then there is advertising and making the boxes and shipping from the port to the machine facility.......get the picture?
I bet if Keith Black used a Chinese foundry he'd be able to triple his output. Whoever said it above has it right, it's hard to get any product, much less a quality product, from an American foundry. They're dirty, the work is hard, and there are many dangers. Thus, the number of foundries is dwindling and the good ones are overbooked. At the same time that it's hot, dirty work, the foundryman has to have experience because casting is more of an art than a science. So foundries can't just hire someone off the street. And, the good ones probably can't expand because of the Not In My Backyard factor.
Kudos to pittsburghracer for keeping an open mind.
R.
[Re: dogdays]
#2117332
07/25/16 02:54 PM
07/25/16 02:54 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks and that was well written but I will go one step further. PA isn't the greenist state in he nation but the EPA really hit us hard in the specialty steel market. As a Millwright we used to make and pour our own babbit bearings for our equipment. I retired in 2010 but they stopped us from work like that yeas ago and you should have seen the junk we were forced to use. A local bronze shop was totally closed down
[Re: Thumperdart]
#2117336
07/25/16 02:59 PM
07/25/16 02:59 PM
MR_P_BODY
That`s what Mr.Pbody said...........AT FIRST............. At first I didnt know it.. and my cam didnt help with as much overlap it had... now that I understand it.. its nice stuff.. I'd rather sit in the car and push a few buttons... some day even you will come around and to say it doesnt work well because of one person.. thats pretty lame
[Re: slantzilla]
#2117370
07/25/16 03:31 PM
07/25/16 03:31 PM
B3422W5
Portage,michigan
Slant....... Your not eating enough beans... Lol
[Re: MR_P_BODY]
#2117415
07/25/16 04:53 PM
07/25/16 04:53 PM
Thumperdart
State of confusion
That`s what Mr.Pbody said...........AT FIRST............. At first I didnt know it.. and my cam didnt help with as much overlap it had... now that I understand it.. its nice stuff.. I'd rather sit in the car and push a few buttons... some day even you will come around and to say it doesnt work well because of one person.. thats pretty lame Was just pointing out that it can be harder than just "pushing buttons" but I WILL NEVER go EFI since I've learned from some of the the best at Carb tuning w/overall good results.........LAME?
[Re: Thumperdart]
#2117423
07/25/16 05:04 PM
07/25/16 05:04 PM
MR_P_BODY
That`s what Mr.Pbody said...........AT FIRST............. At first I didnt know it.. and my cam didnt help with as much overlap it had... now that I understand it.. its nice stuff.. I'd rather sit in the car and push a few buttons... some day even you will come around and to say it doesnt work well because of one person.. thats pretty lame Was just pointing out that it can be harder than just "pushing buttons" but I WILL NEVER go EFI since I've learned from some of the the best at Carb tuning w/overall good results.........LAME? For me it could have been as easy as pushing buttons but I didnt know that... with a little help I understand it now.. much better
[Re: MR_P_BODY]
#2117424
07/25/16 05:09 PM
07/25/16 05:09 PM
Thumperdart
State of confusion
Hey, no different than any of us who've struggled over the years to figure stuff out.......... I still struggle..........
[Re: Thumperdart]
#2117442
07/25/16 05:20 PM
07/25/16 05:20 PM
MR_P_BODY
Hey, no different than any of us who've struggled over the years to figure stuff out.......... I still struggle.......... But my struggle is on a computer... I dont even have to get out a wrench.... plug in
[Re: MR_P_BODY]
#2117453
07/25/16 05:32 PM
07/25/16 05:32 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
40 plus years of changing carb jets for me and I will continue doing so. Way to many carbs sitting here and very happy with their preformance.
By the way what the heck does this have to do with ProMaxx heads. Wholly post robber Batman. Lol
[Re: Chris'sBarracuda]
#2117497
07/25/16 06:31 PM
07/25/16 06:31 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That's a Small Block Chevy Head he's cutting up. NOT a Mopar head. Oh I know and will be sonic checkng mine befor I start porting. These heads are my friends and are going on a steer car that may hit the track once in awhile. I really try to stay off the bottom as much as possible but it's nice to know meat is there if needed. Edelbrocks are a little lean in that area
[Re: Porter67]
#2129623
08/10/16 05:05 PM
08/10/16 05:05 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hey can we get an update on these heads?
I edited some of my detracting posts, Im a real dick some days.
But since you have hands on these heads...... whats the report card look like? Like I said above this was a freebe job for a friend. It is still mounted to my flowbench as I ended up in the hospital with a few health issues and I'm very limited in what I can do until hopefully getting straightened up. If my health returns I will have a set of my own and will dig deeper into them. Th four valves that I removed so far feel great as far as valv guide clearance. I told my friend that if he wants to come over some evening and tear them completely apart I will assist him so he can as a 22 year old learn the process. I truly like what I see so far and will update when I have more info. This head will go 300 plus CFM with little work
[Re: slantzilla]
#2130037
08/11/16 12:39 AM
08/11/16 12:39 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hope you heal up soon. Thank you very much
[Re: Porter67]
#2130225
08/11/16 12:15 PM
08/11/16 12:15 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks guys and fingers crossed all goes well soon. Its crazy how good you can feel at 59 years old and how quickly a bad spell can set you back at 60. Last year i started walking and called it my RiverWalk program. I cut unhealthy carbs and worked up to walking 4 miles a day 5-6 times a week. I lost 55 pounds and although I didn't hit my target I FELT GREAT. Then Winter set in and stupidly I stopped instead of going to the gym. On on the downhill slide we went with 4-5 health issues so far this year. I started walking again this week for the first time since April so now its up to me and the Doctors.
#2130232
08/11/16 12:25 PM
08/11/16 12:25 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
During the time this post started going south 7-23-16 to 7-24-16 I was sicker than a dog and ended up in the emergency room. I apologise if I offended anyone but posting from my cell phone only I was trying to keep this post on point for myself as much as others so hopefully some good info could be shared. Trust me I tried to research them before my Friend bought them but there is almost NOTHING floating around. I'm super glad he bought a set of heads that put Edelbrocks to shame and I for one will never buy another set of Edelbrock RPM's till the issues are addressed. Victors???? yes I hope to have a set SOON.
[Re: cudadoug]
#2140310
08/24/16 11:38 PM
08/24/16 11:38 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Dateline, Pittsburg 8/24/16: Any updates????? Hope you are well, sir. No updates, I'm finally back in the shop some and he was sick. Its up to him now to take them apart with my tools if he wants to and check the remaining valve guides. The 4 I took apart to flow the head were great. As I said earlier everything I did on these was free and he won't be charged. We both wanted to see what the flow numbers were so I threw the FREE part out there. Now its up to him to take the rest apart to check the rest if he chooses to do so. I'll help but I have to much of my own work to do. I'm still slowly getting my stamina back but by time the yard work is done and my 3 mile walk I'm to tired to hit the shop for very long. Thinking I will buy my set bare, have them opened up for a 2.08 valve, push the pushrod over, port them, and see if I can improve much on the hair over 315 cfm I've gotten out of a stock location pushrod on my Edelbrock heads. If I can't find 325 PLUS its not worth the added costs.
[Re: slammedR/T]
#2140312
08/24/16 11:39 PM
08/24/16 11:39 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do they have a magnum version?? Not sure but check Jegs website or ProMaxx.
#2140321
08/24/16 11:46 PM
08/24/16 11:46 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Do they have a magnum version?? Not sure but check Jegs website or ProMaxx. Ok
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: cudadoug]
#2155704
09/16/16 01:47 PM
09/16/16 01:47 PM
Posts: 2,094 central texas
krautrock
central texas
I hear crickets.
Chirp, chirp, chirp... did you see the first post in the thread???
[Re: krautrock]
#2155830
09/16/16 05:05 PM
09/16/16 05:05 PM
cudadoug
I hear crickets.
Chirp, chirp, chirp... did you see the first post in the thread??? Lol...thus the crickets! No I came in late and never clicked back far enough. Okay, done being stupid now.
[Re: cudadoug]
#2155861
09/16/16 06:02 PM
09/16/16 06:02 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He picked them up over a week ago and finished striping them down. He said all the other valve guides felt great. Not thinking that the engine will be together this year as he has SEVERAL projects going like most of us do.
#2311518
05/26/17 01:48 PM
05/26/17 01:48 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
What's very telling is the ~20CFM OOTB difference from .400 through .600 is going to be worth roughly 40HP more to a combination with enough cam and compression to take advantage of it, that's a VERY SUBSTANTIAL difference. That's what I liked too. I'm thinking that with very little work these heads would go 280 plus and I mean very little. Bell shape the exhaust port to get some speed and let her breath. Will you please elaborate on what you mean by this?
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: Prochargedmopar]
#2311533
05/26/17 02:20 PM
05/26/17 02:20 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What's very telling is the ~20CFM OOTB difference from .400 through .600 is going to be worth roughly 40HP more to a combination with enough cam and compression to take advantage of it, that's a VERY SUBSTANTIAL difference. That's what I liked too. I'm thinking that with very little work these heads would go 280 plus and I mean very little. Bell shape the exhaust port to get some speed and let her breath. Will you please elaborate on what you mean by this? I guess this question was pointed towards me about exhaust port air speed? If so the average head porter has a desired ex port shape that we aim for. Most ex ports when on a bench are very loud with turbulence in an unported state. When I took a 2 day "theory' class given by Darrin Morgan (google the name) Very little time 1 1/2 hours out of 17 hours was spent on the ex side. Most of us had flowbenches and access to checking port speed so his short lecture on the exhaust side was to properly size the throat to the proper size of the valve being used, bell-shape the port, make the exit as big as possible (without getting carried away) and DON"T just concentrate on ex flow. He was more worried about "airsppeed" than he was about flow number. He gave us a speed number to aim for on the exhaust side (I'll just say OVER 300fps) and it has paid off for me well in testing. I can't get into a discussion on why he told us to do this but like I said, it works. This is exhaust side only. He gave us a number to stay UNDER on the intake side.
#2312466
05/28/17 05:00 PM
05/28/17 05:00 PM
Prochargedmopar
Granbury TX
#2312473
05/28/17 05:15 PM
05/28/17 05:15 PM
Prochargedmopar
Granbury TX
Did a search for Darrin. Reher-Morrison is about 40 miles from my house. A guy at work just dropped an engine in his S-10 that was built by them. It's a NOS motor. $995 for a seminar. https://www.facebook.com/darin.morgan/posts/10210628944712720
#2312518
05/28/17 06:35 PM
05/28/17 06:35 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I went to the one in Columbus Ohio years ago and stayed overnight at the Holiday Inn where the class was. I called him ahead of time and asked Darin if the class wasn't full if I could bring my Son Matt along for half price. his answer was Hell yaaa" as he loved to see the younger crowd learn how to port heads.
#2312545
05/28/17 07:21 PM
05/28/17 07:21 PM
Prochargedmopar
Granbury TX
I went to the one in Columbus Ohio years ago and stayed overnight at the Holiday Inn where the class was. I called him ahead of time and asked Darin if the class wasn't full if I could bring my Son Matt along for half price. his answer was Hell yaaa" as he loved to see the younger crowd learn how to port heads. That is VERY cool of him. I noticed in the comments section of the above vids I posted this. " I know the point your trying to make, and I have taken it guy, I just hate it when people try to defend those dam companies that don't give a dam about anyone's engine after they paid all there hard earned money. It is all about getting the right port for the right CID, Cam, vehicle weight (that has a LOT TO DO WITH IT) Carb and other things. The right speed in FPS for the right Weight and valve size is the game." Headbytes Porting3 years ago One more time, FLOW NUMBERS DONT MEAN CRAP, if you ask any of the top cutters in the US, they will tell you that they hardly turn on the bench (Mondello, Vizzard, AL Neil, so on), and that they only put the head on there for peoples "Bragging Rights". They found out years ago that the numbers off the SF-600 don't take into consideration the fuel mixed in with them. Now on the exhaust it is different, and COULD help there but once again, it is more about CSA, line of sight, expansion rates. " Headbytes I see now why you talk about speed and monitor it when you port heads. I've been out of this for so long, hope I have another 20 yrs in me to play with it. When I left I was studying Vizards books and Steve Dulcich porting articles. I remember when RyanJ first posted pics of his port work. Fun to be back. Info is a lot more freely available now. And the horsepower of cars is out of hand. LOL
#2352992
08/12/17 09:47 PM
08/12/17 09:47 PM
Thumperdart
State of confusion
I'm no pro porter for sure, but but the E-brock pics you posted are horrible and no way would that would leave my station if I had my hands on em. I spent way more time on my junk than a pro would but common sense sez keep the ports nice, smooth and consistent and I pity the poor guy who doesn't know and installs em cos it sez on the box "Out of the box performance".............The Promaxx look really nice by comparison.........
#2353224
08/13/17 02:48 PM
08/13/17 02:48 PM
Prochargedmopar
Granbury TX
Look 👀 good.
Sidewinders are supposedly the same casting, cost LESS, and have all machine work done. Also assembled with name brand hardware.
Helps that I can get them from a mopar specific hot rod shop which is the reason I picked em'
Otherwise I would have went speedmaster. LOL 😂
#2374787
09/21/17 11:18 PM
09/21/17 11:18 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
So I'm thinking I may want a set of the Promaxx for the 416 we're building for Dad's Duster...Would really be interested in bare castings...any advice???
...FAFO...
[Re: skicker]
#2374811
09/21/17 11:40 PM
09/21/17 11:40 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Todd Marsh (Sasquatch) should be able to get you bare castings. Call Todd for his pricing before you order from Summit or Jegs. 👍
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: skicker]
#2374819
09/21/17 11:49 PM
09/21/17 11:49 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
So I'm thinking I may want a set of the Promaxx for the 416 we're building for Dad's Duster...Would really be interested in bare castings...any advice??? Great talking to you today.
[Re: skicker]
#2407086
11/21/17 10:49 PM
11/21/17 10:49 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
any more input on these heads?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#2407089
11/21/17 10:55 PM
11/21/17 10:55 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
any more input on these heads? Not from me. As luck would have it I grabbed a set of Edelbrock heads when Summit was still giving out the 10% off coupons and threw them on a shelf. I am slowly playing with them finally and my next purchase will probably be a set of the newer Victor heads. I wish the price would come down some on those.
[Re: Stroker Scamp]
#2407137
11/22/17 12:24 AM
11/22/17 12:24 AM
YO7_A66
Indiana
""Any more input on these heads"" Not the stock Promaxx but I do on Todds Sidewinders. I bent a valve on my 2.02" bowl blended J's this past Spring and that is when I bought Todds bowl ported Sidewinders for my stock stroke 340 (+.040"). With no other changes, new heads/gaskets came out to the same 9.7 compression as my J's. I was expecting the bottom end to be a little soggy since these heads were tested at 280@.550". At 30mph, I can hit WOT and spin my new Nitto 275's. I tried this several times on several different occasions and each time I was breaking traction. It pulls harder on the top end at WOT too. I purposely did not change the cam (mostly because I did not have the cash) because I wanted to feel the difference with just a good head swap. Now after running these on the street for the late Summer and early Fall, I now want to make a cam swap this Winter. I think there is some more in it than my current 226/238@.050", .538"/.528" hydraulic FT combo feels. My Yella Terra 1.65's bolted right up and my 5/16" push rods had no clearance issues with the existing HFT lifters. My Powermaster alternator mounted up just like before, and my stock valve covers fit too. I did have to go to a one step hotter spark plug after a few test drives. But this was an easy head swap for the average wrencher like myself. 👍
[Re: RoadRunnerLuva]
#2681486
07/26/19 08:08 AM
07/26/19 08:08 AM
Posts: 39 MD
1965fish
MD
I think they are a very good head for the price. Better than Edelbrocks in my opinion. They were on my 394 in my 3500 lb Dakota. Went 10.80 at 121mph. 394 cu 3.79 stroke 4.070 bore 11.4 comp Eagle H beam rods JE flat top pistons Lunati .581 flat tappet cam unported 171cc Promaxx heads Comp cam roller rockers M1 intake 1000 cfm Holley carb These Promaxx heads dont have a lot of runs or street time on them which are for sale now. Have not posted them anywhere yet. I'm swapping them out for the new Trick Flow 190's. Let me know if you're interested in them.
1965 Plymouth Barracuda Formula S 1965 Plymouth Valiant 200 Convertible 1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104 2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile 1965 Plymouth Valiant Signet 2DR HT
[Re: 1965fish]
#2682757
07/30/19 04:35 PM
07/30/19 04:35 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
We built a SBF with the 180cc intake, 10-1 comp .525 lift cam, edelbrock duel plane intake, made 450 hp only 331ci engine, we also built a small mopar, but engine has not been installed yet.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
#2683798
08/02/19 06:56 PM
08/02/19 06:56 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Might want to ask this over at A body’s only too
[Re: 1965fish]
#2698144
09/16/19 05:12 PM
09/16/19 05:12 PM
krautrock
central texas
I think they are a very good head for the price. Better than Edelbrocks in my opinion. They were on my 394 in my 3500 lb Dakota. Went 10.80 at 121mph. 394 cu 3.79 stroke 4.070 bore 11.4 comp Eagle H beam rods JE flat top pistons Lunati .581 flat tappet cam unported 171cc Promaxx heads Comp cam roller rockers M1 intake 1000 cfm Holley carb These Promaxx heads dont have a lot of runs or street time on them which are for sale now. Have not posted them anywhere yet. I'm swapping them out for the new Trick Flow 190's. Let me know if you're interested in them. did you put some trick flow heads on and pickup any power over the promaxx??
[Re: krautrock]
#2698156
09/16/19 05:52 PM
09/16/19 05:52 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think they are a very good head for the price. Better than Edelbrocks in my opinion. They were on my 394 in my 3500 lb Dakota. Went 10.80 at 121mph. 394 cu 3.79 stroke 4.070 bore 11.4 comp Eagle H beam rods JE flat top pistons Lunati .581 flat tappet cam unported 171cc Promaxx heads Comp cam roller rockers M1 intake 1000 cfm Holley carb These Promaxx heads dont have a lot of runs or street time on them which are for sale now. Have not posted them anywhere yet. I'm swapping them out for the new Trick Flow 190's. Let me know if you're interested in them. did you put some trick flow heads on and pickup any power over the promaxx?? Pretty sure a guy over on A body’s only bought his ProMax heads. Still waiting to hear results
#2698434
09/17/19 12:41 PM
09/17/19 12:41 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
I think they are a very good head for the price. Better than Edelbrocks in my opinion. They were on my 394 in my 3500 lb Dakota. Went 10.80 at 121mph. 394 cu 3.79 stroke 4.070 bore 11.4 comp Eagle H beam rods JE flat top pistons Lunati .581 flat tappet cam unported 171cc Promaxx heads Comp cam roller rockers M1 intake 1000 cfm Holley carb These Promaxx heads dont have a lot of runs or street time on them which are for sale now. Have not posted them anywhere yet. I'm swapping them out for the new Trick Flow 190's. Let me know if you're interested in them. did you put some trick flow heads on and pickup any power over the promaxx?? Pretty sure a guy over on A body’s only bought his ProMax heads. Still waiting to hear results That was me. I'm everywhere. I bought his old heads but I won't have them mounted until next spring. They are used but look really good. I'll take them apart this winter for inspection and to familiarize myself with them. I don't know where @1965fish is with his TF project.
[Re: Texas Backroader]
#2759524
04/03/20 03:13 PM
04/03/20 03:13 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hello, this is my first post on here. I'm researching to prepare for my first build. I am up in the air on making a decision between the Promaxx and Edelbrock heads for my 318. Have the Promaxx heads still shown to be reliable since the last post on this thread? Thanks!!! I only know a couple of guys that bought and used them. The set I checked out are being used but not raced.
