zeus fasteners #211151
02/01/09 06:53 PM
02/01/09 06:53 PM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
i just bought a used fiberglass hood that has zeus fasteners. what is the best way to install the female end on the car. any pics would be helpful. thanks
"I aint here on buisness baby,Iam only here for fun"
Re: zeus fasteners [Re: 1swingin] #211152
02/01/09 07:37 PM
02/01/09 07:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The greek king of the gods has his own fasteners?
Don't be the exception.
Re: zeus fasteners [Re: Supercuda] #211153
02/01/09 08:02 PM
02/01/09 08:02 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
you know what he means...
Re: zeus fasteners [Re: 440newport] #211154
02/01/09 08:28 PM
02/01/09 08:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The correct name is Dzus, for reference. Maybe try posting this in the race section, too- no doubt someone there has installed them.
Here's a webpage to check out: http://wolfcentral.net/multistrada/garage/dzus/Dzus%20Installation.htm
Re: zeus fasteners [Re: In_The_Pink] #211155
02/01/09 10:29 PM
02/01/09 10:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Check with the racer stores that advertise in Dragster; they have Dzus brackets & receiver wires, even kits. Basically you have a bracket & the wire receiver for the button, which you pop-rivet to the bracket. Typical bracket installation to the car also by pop-rivets. Height of the buttons varies depending
on thickness of material being fastened, or where the button and/or receiver wire need to be. You'd be wise to also use supports; for my thin 'glass hood, there's a 1/2x1/2 length of angle aluminum to keep the hood from sagging.
