4.7 losing power
#2111376
07/16/16 10:09 PM
07/16/16 10:09 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
My 04 Dakota 4x4 is losing power and sounds like it has a cold, like it's plugged up, but it's not the cats, even had the pipes cut to verify with a visual after the normal diagnostic crap.
164,000 miles Auto transmission New fan clutch, plugs, TB cleaned, new TB sensors, no codes, not over heating, all fluids look good.
It has a cat back Magnaflow exhaust on it and instead of hearing the exhaust note behind me, I hear it under the hood and in the cab, it's really down on power...Used to be a snappy little motor, fun to drive..Now it sucks.
Re: 4.7 losing power
[Re: stumpy]
#2111457
07/16/16 11:59 PM
07/16/16 11:59 PM
Adobedude
New Mexico
Not the cats how about the muffler? I thought about that as I posted up...I'll look because it sure sounds like it's the exhaust side.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2111500
07/17/16 01:10 AM
07/17/16 01:10 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
Spark Plugs? the OEM 4.7 plugs are copper plugs and give up after about 40k miles. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#2111506
07/17/16 01:26 AM
07/17/16 01:26 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Spark Plugs? the OEM 4.7 plugs are copper plugs and give up after about 40k miles. Scott Not true at all. Mopar suggests a plug change later than that and I went 140K on the original Champions in my 02 4.7 quad cab.
[Re: Chris2581]
#2112109
07/17/16 11:20 PM
07/17/16 11:20 PM
finadk
East Brunswick, NJ
Spark Plugs? the OEM 4.7 plugs are copper plugs and give up after about 40k miles. Scott Not true at all. Mopar suggests a plug change later than that and I went 140K on the original Champions in my 02 4.7 quad cab. I guess your mileage will vary. I bought my truck brand new and at a 40K it was running fine, then one day would not start. Had it towed to the dealer and was informed the plugs were shot. This dealer said that 40k was max for the copper plugs. I swapped to iridium and never had another issue. Scott
Scott
1976 Corvette
[Re: finadk]
#2112203
07/18/16 01:45 AM
07/18/16 01:45 AM
Posts: 20,189 Park Forest, IL
slantzilla
Park Forest, IL
I guess your mileage will vary. I bought my truck brand new and at a 40K it was running fine, then one day would not start. Had it towed to the dealer and was informed the plugs were shot. This dealer said that 40k was max for the copper plugs. I swapped to iridium and never had another issue. Scott I had the same thing happen on my '06 4.7 HO. Pulled the plugs at 40K and 3 of them had the center electrodes burnt out of them. I couldn't believe it still ran.
[Re: Adobedude]
#2112470
07/18/16 02:37 PM
07/18/16 02:37 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Sounds like timing chains jumped
