Page 2 of 3 1 2 3
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Rapid340] #2108592
07/12/16 11:13 AM
07/12/16 11:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By Rapid340
I have found in general, rubber that is formulated or designed by Chinese companies is terrible. A very large reputable US manufacturer (like OEM or Dorman) will be good about making sure the correct rubber technology is in place even if made in china and I have had good experience using these.
You hit the nail on the head about rubber.
off topic ...
I replaced tie rod ends on my pickup in the fall , one was the lowest grade Napa part , the other a Duralast from Vatozone. The Napa boot split after a couple of months and yesterday I see the Duralast boot is all dry rotted ...
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: JohnRR] #2108627
07/12/16 12:05 PM
07/12/16 12:05 PM
moparx Offline
moparx  Offline
off topic ...
and what does a guy do for replacements ? almost all rubber components related to mechanical components are off shore junk. engine, transmission, suspension related "brand" names. check under the hood of your 90 up vehicle often for deteriorated rubber components. you may be [unpleasantly] surprised at the condition of hoses, boots, connections, etc.
beer
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108756
07/12/16 03:07 PM
07/12/16 03:07 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Just got of the phone with pro race products. I asked about which 440 dampers were made in China and which in Australia. He asked for a part number, I gave it, then he said "I'm sorry, that's information we don't share."
Maybe Mancini will pop open a box and tell me what's printed on one
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108781
07/12/16 03:42 PM
07/12/16 03:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Buy the SFI one , if it comes in with made in China ... send it back.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108791
07/12/16 03:57 PM
07/12/16 03:57 PM
Chicago
PurpleBeeper Offline
Chicago
Sudden jolts to the belts are what tears up the rubber in harmonic balancers....so high rpm 4spd shifts, nitrous hits, even turning the A/C on & off, will all wear out the rubber. I got a Summit SFI balancer on my Mustang and after about 3 yrs. the battery wouldn't stay charged & I couldn't figure out the problem (neither could 3 other mechanics & 1 Mopar dealership mechanic)....turns out the balancer rubber went bad and the outer part of the balancer was still spinning (where the pulley is on a Mustang) but just not as fast as the center part of the balancer. I was surprised it didn't squeal like a pig.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108800
07/12/16 04:15 PM
07/12/16 04:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That would have made my decision a lot easier.
My guess is, it it had been Oz made, he would have said so.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108810
07/12/16 04:25 PM
07/12/16 04:25 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The balancer on the 440/505" stroker used to be on my 400/451" stroker.
I bought it from Summit along time ago, but I believe it was made in Australia (Pro Race?) it was the chrome SFI rated one, and has been good for years. I don't know if Summit still sells them, I bought it over 20-years ago.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: PurpleBeeper] #2108830
07/12/16 04:53 PM
07/12/16 04:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That doesn't make a difference then because the balancer he wants doesn't have the belts riding on the dampening part ...
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: fast68plymouth] #2108835
07/12/16 05:02 PM
07/12/16 05:02 PM
Thats exactly what I was thinking, and kinda weirded me out because Ive never been denied that sort of information from someone who knew the answer.
I did call mancini, they're checking the box for me and calling me back. At this point, if its still made in OZ I'll probably buy it from mancini because they're doing some leg work for me, but if not Im going with the powerbond
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108836
07/12/16 05:03 PM
07/12/16 05:03 PM
Thats a good point, the pulley is bolted directly to the inner part of the damper, not the outer ring
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2109374
07/13/16 02:32 PM
07/13/16 02:32 PM
Pasadena, Texas
fal3 Online content
fal3  Online Content
Pasadena, Texas
When my 440 was overhauled in '96, the original damper was junk. I bought a Fluid Damper, forgot the price but I remember it was pricey for the time. Has been on the car ever since w/ no issues.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2109415
07/13/16 03:28 PM
07/13/16 03:28 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Fluidampr b pricy.
2011 Drag Pak Challenger
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2116198
07/23/16 04:39 PM
07/23/16 04:39 PM
Jegs sold me the the Pro Race pro street 34279 for $166, Ill let everyone know where it was made when it gets here
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2116220
07/23/16 05:19 PM
07/23/16 05:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
FWIW - i got this one in the spring
http://www.manciniracing.com/chv838inhe2.html
Chinese
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2116229
07/23/16 05:39 PM
07/23/16 05:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
If that's an Oz made sfi damper for $166, that's a really good deal.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2116232
07/23/16 05:47 PM
07/23/16 05:47 PM
My pbalancer is the 34279, yours is the 24279. They may be made in different locations, but I doubt it. Bottom line is, if its not made in OZ when I open the box to inspect, its going right back to jegs and Im buying a power bond
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2120799
07/29/16 06:18 PM
07/29/16 06:18 PM
Damper arrived today. Ron, looks like they arent made in OZ anymore, or mine wasnt at least. That alone doesnt necessarily make it a bad product, but this combined with my bad experience with the Pro Race representative, and also the scuffing all over the front of the damper (hard to see in the picture) is enough to not want their product. Im sending it back and going to try a power bond
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2120804
07/29/16 06:23 PM
07/29/16 06:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Does it say where it's made somewhere?
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2120807
07/29/16 06:25 PM
07/29/16 06:25 PM
No it does not. Just bare metal with a pro race sticker.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2120837
07/29/16 07:07 PM
07/29/16 07:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
Nothing on the box either?
Page 2 of 3 1 2 3
