Page 2 of 4 1 2 3 4
Re: Help me with 383 upgrade! [Re: gch] #210617
02/14/09 11:15 PM
02/14/09 11:15 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Can 400HP get done on $3500?
I've got a LOT more than that in my 383. Granted, it's a stroker with all new parts though.
I can see an easy $1K in machine work alone before working on the heads...
Re: Help me with 383 upgrade! [Re: 70Cuda383] #210618
02/14/09 11:22 PM
02/14/09 11:22 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
here's my build...
383, 440 stroker kit, 438 cu. in.
eddy RPM heads--84cc chambers, OOTB
zero deck flat top pistons with valve reliefs
10.5:1 compression
comp XE275HL cam
RPM intake
1 7/8 headers
holley 750HP
made 505 hp on the dyno, tons of bottom end. over 500 ft lbs torque from 3000 rpm through 5800 rpm
with stock 906 heads reconditioned to like new, all else being the same, it was about 9.5 compression, and maybe only about 450 hp, due to the lower compression AND lower airflow of the heads
I'm trying to guess my HP. Do you remember off the top of your head what your cam specs are? Solid or hyd? Our combos are similar, but I went a little over/more/bigger on everything.
Re: Help me with 383 upgrade! [Re: 64Post] #210619
02/15/09 06:15 AM
02/15/09 06:15 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
the TRW 12.5 pistons are 12.5 with a 78cc head and a .020 gasket. Use a 88cc head and a .039 gasket and you're right there.
Re: Help me with 383 upgrade! [Re: cdp] #210620
02/15/09 09:19 AM
02/15/09 09:19 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
https://board.moparts.org/ubbthreads/show...rue#Post4933738
Use eigher a KB162 piston or a 2316 Federal mogul/TRW to keep your compression height correct. Anything less than these are a waist of money and super-low compression. Even with these pistons and an 85CC or so head, your barely at 9:1.
Follow the link on a Purestock 383 thread.
NEITHER of these pistons will get you the CORRECT compression height , the KB162 is deeper in the hole than the 2315 AND it's got a CANYON LIKE valve relief at 5cc .
Re: Help me with 383 upgrade! [Re: 64Post] #210621
02/15/09 09:27 AM
02/15/09 09:27 AM
JohnRR Offline
JohnRR  Offline
I don't see why not on a 383 cube build , most of the money will be spent on cylinder head work . A closed chamber head with about 78cc of volume with a flat top at zero deck and at the most 3cc reliefs would get the compression where it needs to be , though it won't get you 10.0 . Run a performer RPM with a good 750-800 cfm carb and a decent header.
fast68plymouth got 500 HP out of a 383 with unported 906's and an umder .500 lift cam.
Re: Help me with 383 upgrade! [Re: JohnRR] #210622
02/15/09 11:22 AM
02/15/09 11:22 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i am doing a mild 383 for my truck. Dodgefarmer here did the machining. KB400 pistons, lunati 220-226 475-494hyd cam, 440 source heads, rpm intake, 750 vac,
i probably have about $3000 into it should make reliable power
Re: Help me with 383 upgrade! [Re: JohnRR] #210623
02/15/09 12:42 PM
02/15/09 12:42 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I don't see why not on a 383 cube build , most of the money will be spent on cylinder head work . A closed chamber head with about 78cc of volume with a flat top at zero deck and maybe 3cc reliefs tops would get the compression where it needs to be . Run a performer RPM with a good 750-800 cfm carb and a decent header.
I guess it's going to depend on the quality of new parts used and the going rate for machine work in the area. I'm still skeptical, though. Plus, there's going to be another line item $500-600 for assembly labor.
I'm still more than a little suspect of Dwayne's numbers. Look at 70 Cuda's combo compared to Dwayne's -- it has more of everything and makes only 5 HP more.
Mine ought to make 600HP, then...
Re: Help me with 383 upgrade! [Re: 64Post] #210624
02/15/09 01:42 PM
02/15/09 01:42 PM
MO
cdp Offline
cdp  Offline
MO
Moparmuscle article.
450hp with headers, intake and cam. STOCK rebuilt 383 longblock. No porting, no fancy pistons. A little machine work to keep the compression right.
The forged piston kit is around $650 thru Summit.
http://www.moparmusclemagazine.com/techarticles/155_0209_383_engine_restore/photo_14.html
http://store.summitracing.com/partdetail.asp?part=FEM%2DCSMHP738%2D300&autoview=sku
Just lower your CC's on your heads to about 80.
Re: Help me with 383 upgrade! [Re: cdp] #210625
02/15/09 02:07 PM
02/15/09 02:07 PM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
Lots of great info here. It's killing me not knowing what heads are on there now. As soon as I know I will post.
Re: Help me with 383 upgrade! [Re: ireland383] #210626
02/15/09 02:47 PM
02/15/09 02:47 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
As long as you don't plan on spraying any nitrous, I'd go with KB400 hyper pistons. They have a positive dome design, which should allow you to get nearly 10:1 with open chamber heads, if I remember correctly. A 383 with these pistons, some well prepped 452's or 906's and a camshaft in the 238* / .510 range would be my choice for a budget street / strip 383 build.
Re: Help me with 383 upgrade! [Re: JohnRR] #210627
02/15/09 03:48 PM
02/15/09 03:48 PM
IL
71383beep Offline
71383beep  Offline
IL
I am running 162's and with the first build on ported 906's the car ran like crap. On teardown for the 2nd build we found 7.8:1 compression along several other issues!!! DO NOT believe the calculators and ESPECIALLY the magazine articles.
Running the same pistons with 516's with a fair amount of work and a more properly matched cam and a calculated and verified 9.2:1 comp ratio and the motor is no longer an issue for me. 400 on the nose for hp and 430+ tq. Not land speed records here, but a good motor for the street that does fine for cruising around town.
And definately make sure this builder knows mopars. Most of them SAY they do becasue they want the business, but a good one will take the time to listen and maybe even show you the various stages of the rebuild. This is very important!
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Help me with 383 upgrade! [Re: 71383beep] #210628
02/15/09 04:08 PM
02/15/09 04:08 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The compression aspect must be blueprinted. Some shops may just put it together the way they get the parts and tell you its good. Best case scenario is to mill the block to suit.
Re: Help me with 383 upgrade! [Re: RemCharger] #210629
02/15/09 05:34 PM
02/15/09 05:34 PM
MO
cdp Offline
cdp  Offline
MO
I agree with Remcharger. Find the true deck height, pick your piston, mill your block and/or heads to get a good true compression ratio.
It may be wise to talk to mopar cylinder head expert and find a mopar shop to atleast do the heads for you.
Asking for a shortblock to Zero-Deck from a respectable machine shop shouldn't be to much of a problem. Have it balanced.
Re: Help me with 383 upgrade! [Re: cdp] #210630
02/15/09 10:50 PM
02/15/09 10:50 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
i did a zero deck with kb162s. eddy heads 84 cc cut to 72cc, hughes engines roller cam and a 440 6pk. 325hp 350tq at the rear wheels.
Re: Help me with 383 upgrade! [Re: 64Post] #210631
02/15/09 10:54 PM
02/15/09 10:54 PM
JohnRR Offline
JohnRR  Offline
You can be skeptical all you want , the math doesn't lie , other members have had their engines run on the same dyno and the numbers have been correct also . Dwayne is NOT one to fib about what he does , his business DEPENDS on being truthful .
Re: Help me with 383 upgrade! [Re: cdp] #210632
02/15/09 11:00 PM
02/15/09 11:00 PM
JohnRR Offline
JohnRR  Offline
How old is that article ??? Westech's dyno was HAPPY to say the least and that was finally brought to light a couple years ago .
Re: Help me with 383 upgrade! [Re: JohnRR] #210633
02/15/09 11:10 PM
02/15/09 11:10 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Dwayne had more cam and carb and compression
Re: Help me with 383 upgrade! [Re: JohnRR] #210634
02/15/09 11:23 PM
02/15/09 11:23 PM
MO
cdp Offline
cdp  Offline
MO
I think its around 2002-2003. About the same time Florida_70Bee's....Bee was featured in Mopar Muscle.
Here is his combination, and according to an online calculator, he's making around 325 at the rear wheels based on the weight and speed. Note that he runs aroudn 13.50 in the 1/4 with a PURESTOCK legal standard bore, #'s matching 383.
Getting 400-450 horse should be fairly easy.
Purestock 383
"have done this same combo in my 70 Bee
To get the C.R. up you will need to deck the block and mill the heads and I think Speed Pro offers a correct flatop piston
Here are some specs on my combo
The block is the original std bore 383
I am using the original cast flatop pistons standard bore.
Speed pro plasma moly rings
The block has been decked to a piston to deck clearance of -.006. (NHRA stock elim minimum specs are -.004 (for a 70 383 335hp) in untouched form I measured the piston to deck at -.050
I am using a Fel Pro steel shim gasket for a 413 which has a compressed thickness of .020
The heads are stock unported 906's with stock size 2.08/1.74 valves with a good valve job. Additionally the heads have been milled to 80cc's (the NHRA minimum is 79.5cc's and in untouched form they were 88cc's)
All this adds up to a measured compression ratio of 10.12:1. This number would be higher with a .030 or .060 piston. Originally in untouched form I measured the CR at 8.44:1 (a far cry from it's 9.5:1 advertised CR.
The cam is a Mopar Performance stock resto cam for a 440 6 pack (same dimensions as the original 383 magnum cam except it uses a 3 bolt cam gear instead of the original 1 bolt)
The intake is the unported original.
The carb is the original 585 cfm holley
The converter is a dynamic 11 inch that stalls at 2300 (like the original converter
The ignition is a combination of Mopar Performance elctronic and FBO Ignition Box, and Coil
The exhaust is a TTI 2 1/2 H pipe with Dynomax Ultra Flow Mufflers
I am running a 4.10's in the rear and I am using a pinion snubber and I clamp the front segment of the original springs.
The car weighs between 3975 and 4015 lbs with me in it depending on the fuel load. I leave the line at around 2000 rpms and roll into the throttle (I don't stab it at green as I am running F70-14 Polyglas's) and shift between 5600 & 5700 and it goes through the traps at 5600 rpms. "
So John, are you saying they didn't make the 450 like they claim in the Moparmuscle/Westech article? I was unaware of this if thats the case.
Re: Help me with 383 upgrade! [Re: GTX MATT] #210635
02/15/09 11:38 PM
02/15/09 11:38 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
John, I'm not doubting Dwayne made the number, I just don't think it was as mild of a build as was let on.
My combo FWIW:
383 block .030+ By CRE
3.915 crank. 450 cid
12.3:1 static cr (10cc domes; .004/.005 below deck
MCH ported Eddys milled to 82 cc's-- we all know the numbers, plus I had them locally flowed. Jeff's numbers are a hair conservative.
Comp Custom solid cam= .261/.266 @ .050 .578/.585 gross lift
Eddy RPM intake
950HP worked by Biggs
1 3/4 Headers
HP? Unknown at this time. Might get it on the dyno in the spring...
Re: Help me with 383 upgrade! [Re: RemCharger] #210636
02/16/09 11:50 AM
02/16/09 11:50 AM
IL
71383beep Offline
71383beep  Offline
IL
That's true I did have the block decked.
It was a good thing my engine builder was such a cool easy going guy because during the build i made a point of stoping by on the weekends to see how everything was going. He was more than happy to show me the in's and out's and what was originally wrong and what he did to make it right. This aspect is a rarity in engine builders from what I have heard.
I agree that they do not take much to get them going, but it seems that good compression is crucial in achievieng it. Selecting cams and bolting on intakes and heads only works in fantasy land unless the motor had zero deck pistons to start with. My first builder just put in the pistons cleaned the deck and bolted on monstrous 906 open chambers...and gave me a motor that would not hold a tune to save its life.
Page 2 of 4 1 2 3 4
