NGK V-Power a good choice for MAGNUM 318? #2105465
07/07/16 05:55 AM
07/07/16 05:55 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Used these on other combos, older LA 318s. What about the magnums?
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2105570
07/07/16 11:52 AM
07/07/16 11:52 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yes all my cars and power equipment use either Denso or NGK plugs just because they are reliable and last forever twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2105613
07/07/16 12:36 PM
07/07/16 12:36 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Im with Gus.We used a lot at the shop.Run them in almost all we have also.Last set in my 440 went at least 5 years.Just replaced them as maintaince.They were still looking good.Rocky
Chrysler Firepower
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2105662
07/07/16 02:13 PM
07/07/16 02:13 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Stay with the stock heat range, Adam71. twocents
I tried a colder NGK in my 360 Mag and found the off-idle response was a little soft. Went back to new Champions with the proper number and it came back. shruggy
Can't explain it.
Mo' Farts
Moderated by "tbagger".
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2106043
07/08/16 02:04 AM
07/08/16 02:04 AM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
I would always put champions for sure.
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2106099
07/08/16 05:33 AM
07/08/16 05:33 AM
No matter what I put it in, on stock engines, I try to put same heat range. I like the NGK in my older stuff, just never had a magnum engine before
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2106277
07/08/16 03:17 PM
07/08/16 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I use NGK in every car I put plugs in in my repair shop, I have seen just about every plug brand with a bad "new" plug. Bosch are the worst we have to fix mis-fires caused by other people putting in new bosche plugs probably once a month on average. Autolite Delco and Champion are usually ok but ocasionally we see an issue with one of them.
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2106309
07/08/16 04:49 PM
07/08/16 04:49 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
I went to extent of checking resistances in a variety of manufacturers new unused plugs all same application. The only consistent plugs were ngk's all about 5000 ohms. Others were wildly variable in several cases. I put some ngk's in one of my darts and immediately saw improved starting and engine runs a wee bit cooler as well, (slightly colder plug installed too). I won't use anything else after that. Small engines run better with ngk's too in my experience.
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2106538
07/08/16 10:13 PM
07/08/16 10:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dave Ill agree Bosch are total crap.In 30 years at the shop I dont know how many setsI had to replace because they ran like s--t.Peopl pay big bucks for them and total trash.Only say 1 car that ran with them.Oh yeah my kid put a set in a 61 Dodge he had.Only thing he could get at the time.Didnt wabt to start idled bad poor power etc.I got some Autolites i had used put them in and it started super quick ran great and ideled fantastic.Now we run almost all NGKs.Rocky
Chrysler Firepower
Re: NGK V-Power a good choice for MAGNUM 318? [Re: Adam71Charger] #2106546
07/08/16 10:30 PM
07/08/16 10:30 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
wave
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: NGK V-Power a good choice for MAGNUM 318? [Re: DARTH V8Я] #2106566
07/08/16 11:23 PM
07/08/16 11:23 PM
the weekend must be here! (time flies when you're having fun)
Re: NGK V-Power a good choice for MAGNUM 318? [Re: dartgame] #2106651
07/09/16 01:40 AM
07/09/16 01:40 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
x2, especially two-strokes.
Mo' Farts
