best penetrant for 65 y/o brake lines #2104259
07/05/16 02:58 PM
07/05/16 02:58 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
well? I know it isn't WD-40. Torch didn't work either.
Re: best penetrant for 65 y/o brake lines [Re: Mr.Yuck] #2104263
07/05/16 03:02 PM
07/05/16 03:02 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Kroil, the oil that creeps.
Re: best penetrant for 65 y/o brake lines [Re: 71birdJ68] #2104269
07/05/16 03:10 PM
07/05/16 03:10 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
If the flame wrench didn't do any good, no penetrant in the world is going to work.
Parts are fused together.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: best penetrant for 65 y/o brake lines [Re: Mr.Yuck] #2104387
07/05/16 06:37 PM
07/05/16 06:37 PM
Kentucky
E
ewolfe Offline
ewolfe  Offline
E
Kentucky
GIBBS spray...it's ridiculous stuff!
Re: best penetrant for 65 y/o brake lines [Re: Mr.Yuck] #2104390
07/05/16 06:40 PM
07/05/16 06:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had good luck with PB Blaster, but when it comes to old, rusted brake fittings, they often weld themselves together so that nothing can get them unthreaded.
Re: best penetrant for 65 y/o brake lines [Re: Mr.Yuck] #2104392
07/05/16 06:44 PM
07/05/16 06:44 PM
STL
cdstl Offline
cdstl  Offline
STL
I took a "toothbrush type" wire brush and knocked loose any external rust so that the penetrant could soak in. I then used a mix of 1/2 Acetone and 1/2 trans fluid and let it soak. I was able to break loose 13 45 year old brake lines and reuse the original lines.
Let it sit a day or two and keep squirting it in.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: best penetrant for 65 y/o brake lines [Re: cdstl] #2104524
07/05/16 10:22 PM
07/05/16 10:22 PM
propane or acetylene? You might put the acet (sparingly) on it then shoot it while hot with some WD40 or whatever you have & see if it works
Re: best penetrant for 65 y/o brake lines [Re: RapidRobert] #2104793
07/06/16 11:04 AM
07/06/16 11:04 AM
moparx Offline
moparx  Offline
heat the fitting and/or around the casting. then apply a birthday candle, allowing the wax to generously melt against the hot surface[s]. the wax will wick into the joint[s] like solder does when soldering copper piping. you may be pleasantly surprised at the results. you may have to do this a couple of times though. i remove all of the 5-40 slot head screws on the cowl vent screen on my 33 dodge humpback panel truck using this method, even though many of them had badly messed up slots in the screw heads. all but one turned out as if they were installed yesterday and were new.
beer
Re: best penetrant for 65 y/o brake lines [Re: Mr.Yuck] #2104847
07/06/16 12:12 PM
07/06/16 12:12 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
Mix ATF with acetone 50/50. Way better than kroil.
Re: best penetrant for 65 y/o brake lines [Re: superchuck] #2104908
07/06/16 02:11 PM
07/06/16 02:11 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I'll give it a try since that stuff is nowhere to be found (except by mail) plus it is EXPENSIVE.
Re: best penetrant for 65 y/o brake lines [Re: Mr.Yuck] #2105835
07/07/16 07:26 PM
07/07/16 07:26 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Home Depot has acetone, plus I have a can of it at my house, right around the corner from you. Come and get it.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: best penetrant for 65 y/o brake lines [Re: Dads426] #2105904
07/07/16 09:26 PM
07/07/16 09:26 PM
IN
ahy Offline
ahy  Offline
IN
I often get the threads freed up but the line is fused to the nut and spins.
If they don't come loose its not worth fighting too much IMO. Nip the lines off with a bolt cutter and bend up new when it is time to put it back together. Easier to get the nut off on the bench in case you are saving the wheel cylinders or calipers. Most of the time they need rebuilt or replaced anyhow.
