Page 4 of 5 1 2 3 4 5
Re: lifter valley plate for trick flows [Re: Jimbo] #2091582
06/14/16 03:04 AM
06/14/16 03:04 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
The AN10 bung have a 90° elbow with a pickup for the last dry sump stage, as I have a 6-stage pump.
Lifter area is sealed of in the center.
Re: lifter valley plate for trick flows [Re: RT540] #2091605
06/14/16 04:37 AM
06/14/16 04:37 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Good, it will get plenty of oil there.
Mopar to the bone!!!
Re: lifter valley plate for trick flows [Re: Jimbo] #2103114
07/03/16 04:39 PM
07/03/16 04:39 PM
AndyF Offline
AndyF  Offline
I think this is the combo that I'm going to use (although I could change my mind again). This is a solid valley plate made from 0.250 aluminum. The plate is beveled on the edges and then I made up a pair of aluminum "bat wings" that will RTV to the bevel on the plate. I'm going to glue paper gaskets to each side of the bat wing.
Re: lifter valley plate for trick flows [Re: AndyF] #2103282
07/03/16 10:08 PM
07/03/16 10:08 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Andy, when you get this system ready for sale let me know, I am interested in useing this set-up.
Re: lifter valley plate for trick flows [Re: dartman366] #2103416
07/04/16 02:52 AM
07/04/16 02:52 AM
AndyF Offline
AndyF  Offline
I can sell you the same parts that are in the picture. I have extra valley plates and bat wings on hand. Just shoot me a PM. If you already have an Indy valley plate then I can sell you just the bat wings. I have solid valley plates for B blocks only. The RB plates that I have on hand have the inspection cover machined in them so they are more expensive.
Re: lifter valley plate for trick flows [Re: Jimbo] #2103509
07/04/16 12:05 PM
07/04/16 12:05 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Like mentioned before, there are so many variables as far as head milling, block milling, port size and location, wouldn't it be best to just tig an aluminum plate to the bottom of the intake and seal the ends with RTV like a small block?
[image][/image]
Re: lifter valley plate for trick flows [Re: sgcuda] #2103822
07/04/16 07:23 PM
07/04/16 07:23 PM
AndyF Offline
AndyF  Offline
Welding on a plate might work for a guy who only has one intake manifold but it isn't a good solution for me. I have a bunch of intake manifolds to test so I need a "bolt on" solution.
Re: lifter valley plate for trick flows [Re: Jimbo] #2104581
07/06/16 12:21 AM
07/06/16 12:21 AM
AndyF Offline
AndyF  Offline
With the bat wing design I now have very good port alignment. Can't see all of it but what you can see by looking down the runner lines up exactly with the port in the head.
Might be good for a little extra power. I was at 715 last time on the dyno so we'll see what she does this time.
Re: lifter valley plate for trick flows [Re: Jimbo] #2121020
07/30/16 12:37 AM
07/30/16 12:37 AM
AndyF Offline
AndyF  Offline
I sent the valley plate back to the shop for a little weight reduction.
Re: lifter valley plate for trick flows [Re: Jimbo] #2121031
07/30/16 12:56 AM
07/30/16 12:56 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
NICE, I need to put in more effort with my intake alignment.
1963 Plymouth Max Wedge
1971 Barracuda
Re: lifter valley plate for trick flows [Re: AndyF] #2121143
07/30/16 09:39 AM
07/30/16 09:39 AM
moparx Offline
moparx  Offline
how much does that weigh now ? good looking for sure ! up
beer
Re: lifter valley plate for trick flows [Re: Jimbo] #2121167
07/30/16 10:40 AM
07/30/16 10:40 AM
sgcuda Offline
sgcuda  Offline
That weight reduction makes it look like a whole different component. Very nice, Andy.
[image][/image]
Re: lifter valley plate for trick flows [Re: Jimbo] #2133104
08/14/16 11:35 PM
08/14/16 11:35 PM
AndyF Offline
AndyF  Offline
Now that I have the other head back from machine shop jail I can go back to mocking up the options. The one piece valley cover I built ended up fitting perfectly but I still think I'll go with the 3 piece setup. Here is the one piece. Port match is perfect.
Re: lifter valley plate for trick flows [Re: Jimbo] #2133107
08/14/16 11:38 PM
08/14/16 11:38 PM
AndyF Offline
AndyF  Offline
Here is the 3 piece setup with a solid valley cover and then the pair of batwings. I like this solution better since I can move the batwings around to get the alignment that I want and then just lay a bead of RTV down to seal things up. This solution will also work with different deck heights and different head gasket thicknesses.
Re: lifter valley plate for trick flows [Re: Jimbo] #2151431
09/10/16 01:29 AM
09/10/16 01:29 AM
AndyF Offline
AndyF  Offline
The bat wing design passed the dyno test with flying colors. We made a bunch of dyno pulls without any issues and we made multiple intake swaps. The intake just lifts off without any issue and does not damage the gaskets. So the gaskets can be re-used multiple times.
Re: lifter valley plate for trick flows [Re: AndyF] #2151443
09/10/16 01:49 AM
09/10/16 01:49 AM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
Hi Andy! It appears that you glue (gasgacinch?) the gaskets to both sides of the bat wings, and then spread a little grease (white lithium) on the gaskets so they won't stick. Correct??
Re: lifter valley plate for trick flows [Re: Jimbo] #2151614
09/10/16 01:16 PM
09/10/16 01:16 PM
AndyF Offline
AndyF  Offline
Yep. I use contact cement to glue the gaskets to the aluminum bat wing and then smear some white grease on the intake face of the gasket.
Re: lifter valley plate for trick flows [Re: Jimbo] #2184558
10/28/16 02:58 PM
10/28/16 02:58 PM
AndyF Offline
AndyF  Offline
I decided to move the breather to the valley plate so I had a #12 bung welded to the plate and then used a Peterson breather. I think this will work better than the valve cover mounted breather that I was using.
Re: lifter valley plate for trick flows [Re: Jimbo] #2184882
10/28/16 09:26 PM
10/28/16 09:26 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
would this 3 piece plate work with 440 Source heads ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: lifter valley plate for trick flows [Re: Jimbo] #2184915
10/28/16 10:07 PM
10/28/16 10:07 PM
AndyF Offline
AndyF  Offline
Sure but it is really only needed with a fully ported head. If the heads are unported then the standard bathtub gasket should work just fine.
