Re: Rewiring the duster, need some size info
[Re: DemonDust]
#2101181
06/30/16 03:50 PM
06/30/16 03:50 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
A few questions for the wiring gurus.
I have a 60 amp self exciting alt. No longer driven on the street. Would only run tail and headlight circuit for night racing.
That being said what size wire should be run from the alt to the battery? Approx 15'
What size ground wire from the battery to the front? The positive side is 2AWG.
Last question... I think lol... What size wire from the junction block to the starter? approx 5'
Thanks! I would run a #10 or larger from the alternator to the battery so you can switch to a larger output(100+ amps) one later with no worrys On the negative wire from the battery to the front I woud use a #1 or 0 gauge. I would bond the motor with several smaller #4 wires to the frame also On the main feed from the positive wire feed from the battery to the starter up to feeding the car I would and do use a #4 also When it comes to electron flow in D.C. circuits a littel bigger wire gauge( 1 or 2 sizes bigger) is way better than 1/2 a wire gauge size size to small IHTHs
[Re: DemonDust]
#2101476
07/01/16 12:37 AM
07/01/16 12:37 AM
Posts: 20,925 A collage of whims
topside
A collage of whims
I'll second Cab's suggestions, that's what I've run with zero issues. Basically, the longer the wire, the heavier the gauge should be, meaning if in doubt go up. I think Del City also sells braided split loom covering in a few sizes: slit like that ribbed GM stuff, but much nicer looking; much like the OEM Mopar tail-light harness covering, but easy to install & live with. Not very spendy, either; I'm using it on my builds.
[Re: DemonDust]
#2101549
07/01/16 01:36 AM
07/01/16 01:36 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
If you are going to run the altenator cable to the battery disconnect(battery side) I would use #6 wire.
"Just a Bracket car dressed up like a streetcar"
[Re: DemonDust]
#2101554
07/01/16 01:48 AM
07/01/16 01:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Those your old as$ heavy glass head lights in the trash and get some plastic LED lights.. they draw way less and are lighter and brighter and you should look up a wire chart on line
[Re: Just-a-dart]
#2101571
07/01/16 02:07 AM
07/01/16 02:07 AM
Cab_Burge
I didn't think of you wiring a race car to NHRA specs, I ran a #8 from my 100 amp alternator directly to the positive cable on one battery(passenger side) and bypassed the battery cut off switch, which made that run about three feet shorter on my 1970 tube chassis cuda The battery cables are in parelel with each other (both positive leads are termainted on one + post) and I use one positive feed cable from the passenger side battery to the cut off switch
[Re: MR_P_BODY]
#2101613
07/01/16 03:08 AM
07/01/16 03:08 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Those your old as$ heavy glass head lights in the trash and get some plastic LED lights.. they draw way less and are lighter and brighter and you should look up a wire chart on line You have a part# for those lights?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: DemonDust]
#2101669
07/01/16 09:48 AM
07/01/16 09:48 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I just re-wried the alternator circuit, but this is a street car. Went with XS Power copper coated aluminum stranded cable, 4g to a heavy duty relay, then to battery side the disconnect switch. good price on lightweight cable: http://www.sonicelectronix.com/item_81466_XS-Power-XPFLEX4BK-20-Iced-Black.htmlLast year I went to H4 conversion housings from Amazon for like $35. Lightweight, but according to weight guru FMJ, not lighter than old sealed beams. The optics were horrible, and it is a street car, so I just recent switched to a true LED light, not light, and more than you need for racing: http://www.truck-lite.com/webapp/wcs/sto...p;storeId=10001
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2101727
07/01/16 10:54 AM
07/01/16 10:54 AM
MR_P_BODY
I went with these... much lighter weight and brighter by far than the old glass.. got them off e-bag... has 3 lights in each.. led perimeter the head light and a little blue bulb near the bottom I have the white led perimeter light as parking and the little blue hooked up to the turn signals.. makes the head light change color when flashing(barely changes color)
[Re: DemonDust]
#2101856
07/01/16 01:34 PM
07/01/16 01:34 PM
Thumperdart
State of confusion
Can't you just run the alt wire to the battery? As long as it's before the shut off it'll function the same.
Or is that a NHRA rule that it has to be done that way? I've never had anyone say anything. My batt cable(#01 iirc)runs from the trunk to a bulkhead on the firewall and the the alt. straight to the same bulkhead w/a batt. cable(big)...........14.5-14.7 at idle............
[Re: MR_P_BODY]
#2101857
07/01/16 01:35 PM
07/01/16 01:35 PM
Thumperdart
State of confusion
I went with these... much lighter weight and brighter by far than the old glass.. got them off e-bag... has 3 lights in each.. led perimeter the head light and a little blue bulb near the bottom I have the white led perimeter light as parking and the little blue hooked up to the turn signals.. makes the head light change color when flashing(barely changes color) I see you painted your fingernails to match the blue car..........
[Re: DemonDust]
#2101872
07/01/16 01:57 PM
07/01/16 01:57 PM
Posts: 2,083 CA
crackedback
CA
Voltage drop along that run from alternator to battery is going to be fairly large using anything smaller than a 6Ga wire Justa dart suggested. I'd run 6 or even a 4ga to minimize voltage drop. You can run the charge wire back to the battery or battery side of the disconnect switch, same basic location. The BAD of that... that wire is always hot! Something to look at for wire sizing.
[Re: DemonDust]
#2101876
07/01/16 02:04 PM
07/01/16 02:04 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
That is a good price for the liteweight battery cable for sure. We used all liteweight stuff when I redid the Stratus wiring
