Oiling holes line up...where??? on 273 trying to prime #210183
02/01/09 01:37 AM
02/01/09 01:37 AM
Kentucky
Greencospeedshop Offline OP
Kentucky
Trying to get oil up to the rockers....I have it everywhere else.
I tried all 4 quardants.......tdc,90,bdc,90...
nothing ... I even tried straight up and down in relation to the crank centerline.... and at a 90 to it as well....
I have done this before and sucessfully....can't seem to strike oil now though....
Nothing on it in the 1969 or 1970 Chassis service manual... I know someone out there knows this....
Thanks.
GCSS
Officer to me...
"I had my pedal to the floor and you were still pulling away like a rocket!"
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210184
02/01/09 02:26 AM
02/01/09 02:26 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Are you running Magnum heads?
Re: Oiling holes line up...where??? on 273 trying to pr [Re: dart4forte] #210185
02/01/09 09:08 AM
02/01/09 09:08 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Before my SR heads that oil through external lines I would spin the motor over with a kicker button clipped on to the start relay as I run the drill clockwise SB and counter clockwise. That seems to be the ticket
Re: Oiling holes line up...where??? on 273 trying to pr [Re: Dodgem] #210186
02/01/09 09:10 AM
02/01/09 09:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
counter clockwise BB sorry. or have some turn it by hand as you prime or turn little bit at a time But there may be an exact spot??
Re: Oiling holes line up...where??? on 273 trying to pr [Re: Dodgem] #210187
02/01/09 09:12 AM
02/01/09 09:12 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Turning with the starter as you prime also gets the lifters pumped up better on a hydraulic cam as then they all get a turn at pressure at a low preload station
Re: Oiling holes line up...where??? on 273 trying to pr [Re: Dodgem] #210188
02/01/09 09:24 AM
02/01/09 09:24 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Also make sure to have the notches on the end of the rocker shafts down and to the front on the drivers side and down and to the rear on the Rt. (passenger) side of the engine. If they are not installed correctly oil will not be supplied to the top of the engine. Also the top of the engine is oiled alternately according to camshaft rotation with one side getting oil at a time depending of camshaft position to the oil feed to the head.
Re: Oiling holes line up...where??? on 273 trying to pr [Re: MoparforLife] #210189
02/01/09 12:27 PM
02/01/09 12:27 PM
I'd grab a helper & have him turn the crank slowly w a breaker bar(take plugs out) while you man the drill(CW)
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210190
02/02/09 05:54 PM
02/02/09 05:54 PM
Kentucky
Kentucky
I am using stock 273 heads.
I turned the crank quite a bit and no oil. I do have the rocker shafts correctly located.
I will have an assistant turn the motor over slowly while I run the drill.
I am doing all this BEFORE I install it.
I am asking if anyone knows at exactly what point (degree) do the oiling holes line up ??
If I don't get oil, I will pull the cam out to check and be sure the oil holes are exposed.
Thanks.
GCSS
Officer to me...
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210191
02/02/09 06:59 PM
02/02/09 06:59 PM
Thanks. GCSS
I do not know the exact degree but the next SB & BB I do I am going to write it down as it comes up often enough. I hope your head gasket holes aren't blocked.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: RapidRobert] #210192
02/02/09 08:03 PM
02/02/09 08:03 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I don't know if these photos will help. This is from a 426 Hemi.
The red lines represent the oil flow through the cam journal.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Snoopy] #210193
02/02/09 08:11 PM
02/02/09 08:11 PM
Snoopy Offline
Snoopy  Offline
This is a picture of the cam bearing from the bottom of the block. The oil supply holes leading to the heads are shown.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Snoopy] #210194
02/02/09 08:20 PM
02/02/09 08:20 PM
Snoopy Offline
Snoopy  Offline
Passenger side head oil flow.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Snoopy] #210195
02/02/09 08:20 PM
02/02/09 08:20 PM
Snoopy Offline
Snoopy  Offline
Driver side head oil flow.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Snoopy] #210196
02/02/09 08:28 PM
02/02/09 08:28 PM
You don't need all this about the degrees. If you can't get oil by spinning the pump and either wrenching or cranking the engine with the starter, you have a problem. Either you have something basically wrong in the pump path--plugged passage, etc, a missing plug, etc
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210197
02/02/09 11:21 PM
02/02/09 11:21 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Instead of trying and turning 90 deg and trying again.
Try running the pump while you SLOWLY turn the crankshaft 2 full rotations.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Magnum] #210198
02/03/09 12:33 AM
02/03/09 12:33 AM
What about your other cam bearing? On a SB the #2 & the #4 cam bearings have 2 holes to direct oil topside rather than just (1) cam bearing for BB's. If your other one is dead on like the one in the pic(I would think it is since that one is good), & you have checked your rocker shaft alignment & if your turning the crank slowly by hand(& I'm thinking you are) that pretty much leaves a problem with the head gaskets blocking the(2) holes on each bank.
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210199
02/03/09 12:52 PM
02/03/09 12:52 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Is the engine on a stand or in the car? did you check the plugs in the back of the block?
Re: Oiling holes line up...where??? on 273 trying to prime [Re: dart4forte] #210200
02/04/09 02:05 AM
02/04/09 02:05 AM
Kentucky
Kentucky
engine is on the stand...
What plugs??
I am out of town right now and can't do anything till Saturday..
I will have an assistant help and also look at the plugs.....But are you talking about the ones that are behind the frost plugs???
Officer to me...
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Snoopy] #210201
02/04/09 02:08 AM
02/04/09 02:08 AM
Kentucky
Kentucky
are the hemis the same regarding this????
Also regarding the headgasket holes, I am using 318/340/360 type.
I am fairly sure I looked at the holes when I put it together, But if no oil with an assistant, I may need to pop them again...
Officer to me...
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210202
02/04/09 02:38 AM
02/04/09 02:38 AM
you might take off the drivers rocker arm assy & see if you can blow some air in the passage & see if it's coming out at the #2 cam journal, (if so) take the passenger rocker arm assy off & see if its clear to the #4 cam journal. If both are open you wont have to R&R the heads. (If not) your only out a pair of head gaskets
