Stock 69 RR what's the biggest tire/rim combo we can use?
#2100458
06/29/16 10:45 AM
06/29/16 10:45 AM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Hey guy's what's the biggest tire and rim combo you can run on a stock 69 Road Runner?
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: Stock 69 RR what's the biggest tire/rim combo we can use?
[Re: DaveDudek]
#2100476
06/29/16 11:20 AM
06/29/16 11:20 AM
Posts: 2,692 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
My buddy has 10" wheels and 295's on his 69 Charger. Not sure if the Charger has the same clearance as the Road Runner.
2011 Drag Pak Challenger
[Re: Stanton]
#2100494
06/29/16 11:54 AM
06/29/16 11:54 AM
DaveDudek
N of Detroit
[Re: DaveDudek]
#2100499
06/29/16 11:58 AM
06/29/16 11:58 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Smells like someone entered the Woodward street race. I'd beg, borrow or steal a set of ET streets.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DaveDudek]
#2100505
06/29/16 12:13 PM
06/29/16 12:13 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
68 satellite, I ran centerline 15x 8.5 wheels, which have odd back spacing choices. I used the 4 7/8" back spacing and a 1/2" spacer on my heap. I ran M/T 29.5 x 10.5 bias slicks for years. Wore out several sets of them. I also ran 9 x 30 bias and radial slicks.
[Re: rickseeman]
#2100547
06/29/16 02:05 PM
06/29/16 02:05 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
My buddy has 10" wheels and 295's on his 69 Charger. Not sure if the Charger has the same clearance as the Road Runner. Rick , charger wheel wells are fairly large. The Plymouth B bodies have always had tiny wheelwells compared to the Dodges starting in 68.
[Re: DaveDudek]
#2100570
06/29/16 02:54 PM
06/29/16 02:54 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I've got 295/55R15 Mickey Thompson Street ETs on my 15" x 10" steel wheels with 5.5" backspacing. My car's a '68, but I doubt that a '69 is much different. There's sometimes a little rubbing if I turn corners too quickly, but other than that, I haven't had any issues.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#2100635
06/29/16 06:10 PM
06/29/16 06:10 PM
JohnRR
I've got 295/55R15 Mickey Thompson Street ETs on my 15" x 10" steel wheels with 5.5" backspacing. My car's a '68, but I doubt that a '69 is much different. There's sometimes a little rubbing if I turn corners too quickly, but other than that, I haven't had any issues. 68 and 69 are the same.
[Re: JohnRR]
#2100690
06/29/16 07:22 PM
06/29/16 07:22 PM
Posts: 8,927 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I ran M/T 29.5 x 10.5 bias slicks for years. Wore out several sets of them. I also ran 9 x 30 bias and radial slicks. Totally stock suspension or S/S springs and hangers ?? I could not put a 28.5" slick on my 69 without rubbing the front lip - stock suspension.
[Re: Stanton]
#2100693
06/29/16 07:30 PM
06/29/16 07:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran M/T 29.5 x 10.5 bias slicks for years. Wore out several sets of them. I also ran 9 x 30 bias and radial slicks. Totally stock suspension or S/S springs and hangers ?? I could not put a 28.5" slick on my 69 without rubbing the front lip - stock suspension. You have to look at the factory tolerances to see if one will fit and another wont... yours rubbed by how much.. would a 1/4" cleared with no problem because the factory was pretty sloppy back then on the tolerances(and a 1/4" was nothing) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: DaveDudek]
#2100700
06/29/16 07:37 PM
06/29/16 07:37 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My buddy has 10" wheels and 295's on his 69 Charger This doesn't mean much by itself. The "295" is the tread width but without that second number we have no idea of how tall the tire is. that said, 295 is about 11-3/4" wide tread. A 295 55 15 tire would be just shy of 28" tall. With a 10" wheel and 5-1/2" backspacing these should work just fine with 1/4" to spare at the inner wheel well - provided the axle is in the right place !!
[Re: DaveDudek]
#2100702
06/29/16 07:44 PM
06/29/16 07:44 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I have 10" rims with 5.5BS in my 68 Satellite . I currently run 28x10.5 Pro bracket radials no worries . I have also run Hoosier 9x30R15 radials on a 8" rim , this is a 29.9" tall tyre , with no issues. I run a 29" tall street tyre , 255/70R15 . I did try a 295/65R15 MT et street radial , 30" tall , it just barely touched the dogleg , rubbed some masking tape I put there . This tyre was only driven around the block , but was on a possibly wrong offset rim - rim was a 10" for a E body I have Mopar XHD springs with Caltracs Good luck
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Stanton]
#2100728
06/29/16 08:27 PM
06/29/16 08:27 PM
MR_P_BODY
My buddy has 10" wheels and 295's on his 69 Charger This doesn't mean much by itself. The "295" is the tread width but without that second number we have no idea of how tall the tire is. that said, 295 is about 11-3/4" wide tread. A 295 55 15 tire would be just shy of 28" tall. With a 10" wheel and 5-1/2" backspacing these should work just fine with 1/4" to spare at the inner wheel well - provided the axle is in the right place !! Same tire I run... its closer to 12" on a 10" wheel.. but I built the car and the axle but I have plenty of clearance ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dogdays]
#2100733
06/29/16 08:43 PM
06/29/16 08:43 PM
MR_P_BODY
The 295 is the section width, not the tread width. See this quote from Tire Rack:
"Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86" "
Standard terminology helps us all talk about the same thing.
Slicks are another system entirely.
R. I measured mine with 2 squares and a tape measure pretty simple... I had to send my 295/65 back due to the height.. just too close EDIT from Summit Tire Size: 295/55-15 Wheel Diameter: 15 in. Sidewall Style: Blackwall Tire Construction: Radial Tire Diameter: 27.80 in. Tire Diameter Range: 27-27.99 in. Section Width: 12.20 in. Tread Width: 10.60 in. Minimum Recommended Wheel Width: 8.00 in. Maximum Recommended Wheel Width: 10.50 in.
[Re: dogdays]
#2100888
06/30/16 12:41 AM
06/30/16 12:41 AM
Posts: 126 Oregon
Jamie McGrath
"Section Width
P225/50R16 91S
R. I think Tire Rack confused themselves. First I've heard from widest point from the sidewall.... P metric tires are measured across there contact patch. 225mm = 9in the aspect ratio is a percentage of the tread width, and the last is the rim size. You guy's can figure out the rest.
[Re: His and Her 69's]
#2101177
06/30/16 03:43 PM
06/30/16 03:43 PM
fullmetaljacket
Go get 'em Dave. I know what you're (going) to do this Summer. Unfortunately, I will not be out there with my car this time around, but I'll come and spectate.
Lee.
[Re: Stanton]
#2101204
06/30/16 04:51 PM
06/30/16 04:51 PM
fast68plymouth
So. Burlington, Vt.
I ran M/T 29.5 x 10.5 bias slicks for years. Wore out several sets of them. I also ran 9 x 30 bias and radial slicks. Totally stock suspension or S/S springs and hangers ?? I could not put a 28.5" slick on my 69 without rubbing the front lip - stock suspension. With the original non-hp springs, then later with SS springs and hangers, then I went to a new set of XHD springs on the OE hangers with cal-tracs.
