Re: Rewiring the duster, need some size info [Re: DemonDust] #2101883
07/01/16 02:18 PM
07/01/16 02:18 PM
CA
crackedback Offline
crackedback  Offline
CA
I guess if you "Need" to watch the weight factors... the aluminum is 3x the cost of standard copper alternative.
A 20' run of 4ga copper cable is about 3.5-5# depending on style.
Re: Rewiring the duster, need some size info [Re: DemonDust] #2101890
07/01/16 02:29 PM
07/01/16 02:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Even though the alternator is rated at 60A, I doubt that there would be a time when it would actually need to supply that current. I used 8ga from front to back (at least 15') and had minimal voltage drop when checked and 14v going down the track. Use 6 if it makes you feel better.
I use 2ga for everything, positive and negative side. IMO that's plenty as long as the system is done correctly and the components and starter aren't junk. The big stuff is heavy and harder to work with. Once the engine starts, it's just along for the ride.
I'll add that I use welding cable exclusively which is more efficient than battery cable. Battery cable may need to use a larger size. 10' of 2ga welding cable weighs just under 3 lb.
Re: Rewiring the duster, need some size info [Re: DemonDust] #2101897
07/01/16 02:44 PM
07/01/16 02:44 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
I have gone stupid crazy trying to keep the weight down in my new car. Started with the care itself, a carbon body, carbon brakes, lightweight wiring, lithium battery, last piece is trying to convince myself I need $4500 in rear wheels...It has truly become a sickness for me....
Re: Rewiring the duster, need some size info [Re: Thumperdart] #2101911
07/01/16 03:08 PM
07/01/16 03:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By Thumperdart
Originally Posted By MR_P_BODY
I went with these... much lighter weight and
brighter by far than the old glass.. got them
off e-bag... has 3 lights in each.. led perimeter
the head light and a little blue bulb near the bottom
I have the white led perimeter light as parking and
the little blue hooked up to the turn signals.. makes
the head light change color when flashing(barely changes
color)
wave
I see you painted your fingernails to match the blue car.......... laugh2
LOL.. my hands dont look anywhere near as good
as my wifes.. she took the pic... I put those
lights in the Rampage.. the race car only has a
single rear light(thats all that is require)
wave
Re: Rewiring the duster, need some size info [Re: MR_P_BODY] #2101921
07/01/16 03:14 PM
07/01/16 03:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just bustin ya Mike but they do match........... biggrin
Re: Rewiring the duster, need some size info [Re: Thumperdart] #2102719
07/02/16 10:54 PM
07/02/16 10:54 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
#6 stranded for 60 amp alternator.
I run #4 welding cable for a 140 amp alternator.
Its not so much about voltage drop. You drop voltage you have an overheated wire. Next thing you know a break in insulation and risk of fire.
