Re: Carter HV Fuel Pump Pressure Loss [Re: fast68plymouth] #2099973
06/28/16 02:21 PM
06/28/16 02:21 PM
Mountain View, CA
68rrunner Offline OP
Mountain View, CA
Originally Posted By fast68plymouth
The two wear together...... Or live together.
You can put a new/different rod in it, but you'll be on borrowed time.
You didn't say what type of cam you have, but I'm assuming its a cast cam core.
If it's a billet core(roller cam), they don't often live when used with a std pushrod(although I did get away with it on my own motor).
Got impatient this morning and slammed it all together with the good rod. Cold fuel pressure was really good, drove it around on a few errands, no issues. As things warmed up pressure backed down to a steady 3 psi. I'll keep checking it as I drive it over the next couple of days.
It's a Comp Cam.
And the car used to be setup for an electric pump and full return system, so I have everything to convert it back, just don't like the limited life cycle of the electrics.
Re: Carter HV Fuel Pump Pressure Loss [Re: 68rrunner] #2100010
06/28/16 03:33 PM
06/28/16 03:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It's a Comp Cam.
Are all the fuel lines tight and leak proof? Happened on an MG years ago, idled ok but under load it was suckin air or leaking either way new rubber line and clamps and problem solved........
