Rocker Arms for BB Victors
#2098028
06/25/16 06:14 PM
06/25/16 06:14 PM
Posts: 153 Wildwood, FL
1fastabody
Wildwood, FL
Ok, so I'm to the point where I'm needing to get some rockers for my BB Victor project. It is a 500" Lowdeck with Max Wedge Victor heads going in my altered. Once my chassis fab work is done I'm planning on sending them to Hughes for CNC. The only rocker options I have found are the Hughes and T&D. How are the Hughes rockers? Also what ratio are you guys running without issues? Do the Max Wedge Victors need more of a rocker offset than the regular Victors? Thanks for the help.
Innovative Performance
Re: Rocker Arms for BB Victors
[Re: 1fastabody]
#2098724
06/26/16 07:53 PM
06/26/16 07:53 PM
1fastabody
Wildwood, FL
Did you see that the Harland Sharp rockers were better than they Hughes?
[Re: 1fastabody]
#2099512
06/27/16 08:09 PM
06/27/16 08:09 PM
1fastabody
Wildwood, FL
I checked out the Scorpion rockers and they look nice. Has anyone out there used them? They say they are good up to 750 psi open, which seems to be the same with most.
[Re: 1fastabody]
#2099815
06/28/16 08:44 AM
06/28/16 08:44 AM
1fastabody
Wildwood, FL
Thanks for the pics and information. That's the kind of feedback I was hoping for. What installed were you able to get out of them?
[Re: 1fastabody]
#2100422
06/29/16 04:30 AM
06/29/16 04:30 AM
Posts: 485 Central California
MoParFish
Central California
(Copied & Pasted from a thread I replied to in 2014) "Yeah, the Victors have their own set of hurdles. I run them and don't know anyone else personally who runs them but, that's the way I like it. FWIW Here's my combo if it helps at all. 440/512 Source kit, MW Victors, 274/280 .674/.674 solid roller, Trick Flow springs TFS-16943-16(which are actually PAC-1243)installed at 1.900 +or- a few .001", Comp tool steel retainers 1732-16(very compact low profile), Comp CCA-4785-16 locators, 621-16 lash caps, Smith Bros .375x.083 pushrods, Harland Sharp S70016EVK rockers. No spring/retainer clearance issues even without lash caps. I decided to run the caps only because the sharp rockers sweep the roller toward the outer tips of the valves and wanted more contact. I'm sure it's not the ideal setup but seems to be working OK. Has been to 7400 RPM a couple times but keep it below 7k now. Also, don't forget about the possible center rocker stand breakage issue. I preemptively removed the factory helicoil and drilled/tapped and installed a 1.0 inch helicoil further into the head so the top of insert is just below bottom of stand. Learned that trick here on Moparts". link to thread https://board.moparts.org/ubbthreads/ubbt...on-victors.htmlHope it helps
[Re: 1fastabody]
#2102062
07/01/16 07:20 PM
07/01/16 07:20 PM
1fastabody
Wildwood, FL
I contacted the guys at B3 Racing Engines and talked to him a while about these heads and different rocker setups. They were very helpful and would recommend them to anyone. I'm still on the fence about what setup to use though, stock shaft style or machine the pads and run a paired rocker setup(like jesel).
[Re: MoParFish]
#2102126
07/01/16 09:37 PM
07/01/16 09:37 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Also, don't forget about the possible center rocker stand breakage issue. I preemptively removed the factory helicoil and drilled/tapped and installed a 1.0 inch helicoil further into the head so the top of insert is just below bottom of stand. Learned that trick here on Moparts". link to thread https://board.moparts.org/ubbthreads/ubbt...on-victors.htmlHope it helps On my newer set of heads they, I think they had longer heli-coils in the rocker stand holes. We used PAC Ti +0.100" retainers and 0.030" spring seats to get right around 2.00" install height. The spring seats were originally 0.060", but PAC milled them down for us. I don't recall what that was extra?
