Page 2 of 3 1 2 3
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2096307
06/22/16 04:36 PM
06/22/16 04:36 PM
UK
rb446 Offline
rb446  Offline
UK
Yep loved mine, although my motor wasn't really what you'd put a cam that big into>
440SP stock block+.030", approx 9.8:1SCR
stock 906 heads to start with
Team G, 850DP, 2" f/wells
4.88's- 14x32 tyre
L-bars/coil-overs
A1 4800 verter
best 11.23@118
added ported (258cfm) 906's 2.14/1.81, HS roller rockers
best 10.7@125
this was with my '69 Cuda between 1989/1990
Cam ran great, no issues, ticked over at 900rpm really smooth, pulled like a train from around 4000>....I probably would've gone quicker with a cam with an earlier closing intake though for some more DCR/CP. Its definately a classic cam which worked but I would think there are cams that make more HP these days as in split pattern designs etc.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2096473
06/22/16 11:00 PM
06/22/16 11:00 PM
crabman173
crabman173
I have used that cam for decades
It was designed to work with ported iron heads as there was nothing else at the time--the thing is is Really works with Indys and better heads
The thing about that cam is WHERE it is installed at
We always had best results installing at around 101 in a 440 CI and 105 in a 500 CI
Now granted we always ran 1/8th mile for the most part but if it is retarded it does not show what it really has to offer
It is THE base line combo for a 440 or 500 CI with Dash 1 Indys--just darn hard to beat and...you have NEVER been in a car that sounded better
First one we ever fired up we switched off right away knowing we had plug wires mixed up--found out it just needed about 5000 RPM to "clear out"
It is an amazing piece --you have to try one at least once
The cam needs lots of spring pressure and Titanium retainers are a MUST--break it in....then up your spring pressure to at Least 150 seat the more the better
It will pull the slober out of your mouth in second gear and high gear is a stunner first time you really lay the wood to it! The sound this cam makes all through the run is just simply stunning!
WHERE it is degreed at makes all the difference--folks that did not like it had in in wrong--out of the box you may have to advance a LOT to get it to 101 or 105 even..leading you to think something is wrong but let me tell you what!!!!!!
Don't quit running Mopars until you have experienced the beast sounding cam of all time
Don't forget the compression more is better
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: Scott440] #2096677
06/23/16 11:29 AM
06/23/16 11:29 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted By Scott440
Hope no one minds bumping this older conversation.
If two cams have duration 324 and 305, and both lift 0.65, the second one seems more practical. ...
But for solid tappets, has anyone tried and preferred the MM305 cam with an add'l 4-6 deg advance? Even if the rpm range came down only 10%, that would still be appreciated. I think the MM305 p/n 23-630-5 sweet spot is 5000-7500. For most of us, that's a bit high.
I ran the Comp MM305 0.650"/0.630" cam for years in my 511 CID and loved it. The intake lobe is more aggressive then the old Comp 324 deg 0.650"/0.650" and I think it makes more torque and great horsepower. I ran it installed at 106 and also 109 and didn't notice much difference. I limited my shifts to ~7,200 rpm, mostly shifted at 7,000. 5,600 rpm stall converter and 13.5 CR.
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 440Jim] #2096821
06/23/16 03:38 PM
06/23/16 03:38 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Jim I'm hoping to pick up a bit with that cam over the 324. I'm approx 12.5:1 shift at 6500 and have a 5800 stall.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: Eric] #2096977
06/23/16 09:41 PM
06/23/16 09:41 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
It's a big-a$$ old-school sft cam that runs a lot of lash (wasted lift and net duration). Sounds "Totally wicked!" at idle... but it's not the secret weapon cam IMO that some folks I know have claimed.
The last two people I know who ran it stuffed 'em into moderately hot 440s and ran 11.0s (in an A body) and 10.7s (in a more serious street/strip B body). Considering that I was running comparable -- or faster -- times with cams about 25 to 35 degrees at .050" smaller, their choice didn't make much sense to me.
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: BradH] #2097035
06/23/16 11:22 PM
06/23/16 11:22 PM
UK
rb446 Offline
rb446  Offline
UK
I agree with that, I probably would've run as fast if not faster with less duration especially with my mild 446SP under 10:1 motor. However, even at that low SCR, you can see that going from stock 906 heads (approx 215cfm?) to 258cfm 906's netted me nearly 6/10ths and 7mph, now if I had the money to get those heads seriously ported to say 290>300cfm whats to say I couldn't have run down to low 10's@130?.....and I was only using around 6500rpm....that cam worked very well, just wish I could've thrown more at it to see more of its true potential.
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2098871
06/26/16 11:12 PM
06/26/16 11:12 PM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
did any of you guys run this on the street,if so how was the manners
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: EDDIEB] #2099263
06/27/16 02:09 PM
06/27/16 02:09 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
290@.050 on the street... whistling
Why not just weld the valves open and save money on pushrods, springs, rockers, etc boogie
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2099273
06/27/16 02:15 PM
06/27/16 02:15 PM
AndyF Online content
AndyF  Online Content
Might be streetable in a 540 or 572 inch engine. Even then you would most likely need a lot of rear gear since the low end torque is going to be missing.
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: DrCharles] #2099340
06/27/16 03:37 PM
06/27/16 03:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m 276-281 on the street no issues at all and only 470 cubes...............
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2099382
06/27/16 04:13 PM
06/27/16 04:13 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
276 is quite a bit more docile in a 470" than 290 would be....\ I guess it all depends on what your definition of "streetable" is, as Bill Clinton might have said laugh
RPM range is 5000-7200 and it doesn't smooth out till 6000. You better have a steep converter.
Doesn't sound like something I'd want to spend much street time in, unless your stoplights are 1/4 mile apart and you have friendly law enforcement! Listen to Andy, he has a lot of experience...
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: DrCharles] #2099390
06/27/16 04:34 PM
06/27/16 04:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
276-281 @ 470 cubes is a joy ride to say the least however till YOU drive one you can only speculate and Andy has knowledge for sure but mine again is on the street and track w/good results not in a dyno cell where the pulls usually start past the hardest carb tuning which is idle, transition and cruise. I will go much bigger next time around............ beer
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2099407
06/27/16 04:58 PM
06/27/16 04:58 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Hey, it's your car, overcam it any way you like! shruggy
For the guy who asked, though, keep in mind that almost all street driving is done below 5000 rpm... 'course it'll sound really bad-ass though with all that lope...
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: DrCharles] #2099411
06/27/16 05:05 PM
06/27/16 05:05 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
..keep in mind that almost all street driving is done below 5000 rpm... 'course it'll sound really bad-ass though with all that lope...
Something alot of people seem to forget. Just like it' great to have heads that flow 400 cfm... but not when the velocity blelow .5 is like the mild breeze coming off a singer sewing machine at full boogie.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: DrCharles] #2099426
06/27/16 05:29 PM
06/27/16 05:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Right now I`m undercammed............ wink
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: Thumperdart] #2099608
06/27/16 10:38 PM
06/27/16 10:38 PM
BradH Offline
BradH  Offline
As far as I ever tell anyone, I'm ALWAYS under-cammed... whistling
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: ProSport] #2099627
06/27/16 10:59 PM
06/27/16 10:59 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Originally Posted By ProSport
My 514 engine makes about 850 hp with a cam that is only 266 at 050. So I'm not sure why I would need 24 more degrees of duration?
Can we hear more about this combo and camshaft?
I run that cam in my car with the minus 90hp crossram, it's bad a$$ 272/276 620 lift. should run in the 9's easy with a single plane and dommi
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2099704
06/28/16 12:30 AM
06/28/16 12:30 AM
indy
E
eds dart Offline
eds dart  Offline
E
indy
run that cam in my current ride. 68 dart back half 4 link. have used it in lots of bracket motors. always find myself slowing car down, less launch rpm, turn shifter down, to stay out of the nines. is a bad mofo. years ago muscle motors said that advancing that cam
, like icl@ 99 will just make it faster. over the next winter during a freshen up I tried it. I chickened out when I got to icl@ 101. sure enough car picked up a bunch in 60, 330 and 660. had to slow car. that cam ia a oldy but a goody. got a deal on a 660 lift roller cam swapped it in and gained zero. your results may vary. I put the 650 back in.
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2099934
06/28/16 12:51 PM
06/28/16 12:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sounds like another candidate for Keith Dannuck to do a cam shoot out with.
Get a "suitable" 500"-ish motor to try it in, and have a few others try and supply something that makes more power.
I've never used one in anything myself, so no personal experience with it.
Re: Comp 324, .650 lift solid cams. Do you use,like'em? [Re: 6PACMAC] #2100054
06/28/16 05:19 PM
06/28/16 05:19 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well putting one in a 10 to 1 motor regardless of CID is nuts. They need compression and converter to work.(big shock there)In stock head and the smaller aftermarket heads they work very well.(eddies, sidewinders, stealths) We still use them pretty often in a bucks down build. Yeah you can drive them on the street (yes I have) but you might need some Excedrin when you arrive at your destination....Not saying it cannot be beat but you will be up past your bedtime if it is used correctly. The larger port Indy and Victor stuff like it but there are some better options. They do like to be advanced even down in the 100 to 102 range. (sorry never pushed one past about 101). Probably sold a hundred or more by now.....Todd
Page 2 of 3 1 2 3
