Re: Trick Flow 240 Heads What are you doing for valve covers?
[Re: patosmith]
#2096353
06/22/16 06:12 PM
06/22/16 06:12 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Can you post a picture with the cover off, but a gasket on? Sounds very strange.
[Re: TRENDZ]
#2096361
06/22/16 06:29 PM
06/22/16 06:29 PM
Posts: 295 Spanaway, Washington State
patosmith
I don't have a picture like you ask but I know that the gasket overhangs a little on top and bottom. I made a cardboard template of the width of TF head and compared it to a valve cover. This Edelbrock valve cover measures the same width as a stock one.
[Re: patosmith]
#2096366
06/22/16 06:37 PM
06/22/16 06:37 PM
TRENDZ
Milwaukee WI
From that pic, I cant see how the head would even have the bolt holes in it.
[Re: patosmith]
#2096459
06/22/16 10:46 PM
06/22/16 10:46 PM
Posts: 31,220 Oregon
AndyF
No doubt that most cast covers are wider than the heads. I've pointed this out in several threads in the past. I even have a little valve cover template which I use to measure valve covers.
The TF gasket rails might be a tiny bit narrower than a cast iron head but it isn't much. I know that the combination of a Mopar cast valve cover and a TF head doesn't work very well but the 440Source valve covers look like they fit the TF head fairly well.
I have a set of new 440Source valve covers if you're interested. I've lined them up on my TF heads and I don't see any problems with them. Might be roughly 0.060 of overhang which should work okay.
I made my own valve covers for this engine and they line up perfectly.
[Re: patosmith]
#2096578
06/23/16 01:38 AM
06/23/16 01:38 AM
AndyF
Here is a picture of the template matched up with the 440Source valve covers. The other picture shows the 440Source valve covers on the engine.
[Re: roadhazard]
#2276632
03/26/17 05:29 PM
03/26/17 05:29 PM
Posts: 9,113 Rogue River, OR
Jeremiah
Rogue River, OR
Cometic, the only gasket worthy of mention..... My Superformance valve cover gaskets worked great with the cheapo Summit/440 source/Indy cast aluminum valve cover. I'd try the Summit cast covers and a set of you r favorite gaskets. Stamped steel and the MP finned covers are both headaches on an aluminum head. Correction, MP finned aluminum covers are a pain on any cylinder head with any gasket until they have been surfaced. Might as well break out a tube of The Right Stuff and I'll send you my gold aluminum Moroso covers.
[Re: 1964superstock]
#2276754
03/26/17 09:27 PM
03/26/17 09:27 PM
dartman366
Mt. Vernon, Ohio
I am running the Indy no logo cast aluminum VC with Superformance Carbon X gaskets, just a little grind work at the distributor location and my MSD fit's, snug but fits.
