Re: Comp 324, .650 lift solid cams. Do you use,like'em?
[Re: AndyF]
#2100528
06/29/16 01:18 PM
06/29/16 01:18 PM
Posts: 16,934 NC
440Jim
NC
440Jim is running the Comp MM 305 which is 279 at 50 on the intake side with .650 lift. So the 324/.650 has the same lift but another 11 degrees of duration at 050. These are the numbers I measured on both cams: MM305 S: 305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 143º/143º@.300", 112º/107º@.350", 0.433"/0.420" 324/324: 324º/324º@.020", 290º/290º@.050", 200º/200º@.200", 145º/145º@.300", 112º/112º@.350", 0.433"/0.433" The new MM305 S cam has a more aggressive intake lobe, with less duration at 0.050" but the about the same at 0.200" lobe lift. The exhaust lobe is not as aggressive as the intake, very similar to the old 324/324; perhaps more stable from a valve float perspective.
[Re: 440Jim]
#2682042
07/28/19 02:37 PM
07/28/19 02:37 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Any one have a sound clip of the 324 at idle ?
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2682209
07/29/19 05:51 AM
07/29/19 05:51 AM
Posts: 570 UK
rb446
UK
Any one have a sound clip of the 324 at idle ? I don't have a sound clip but I can still remember from all those years ago when idling waiting to enter the water box@900rpm on my all iron 446ci, you could almost count the cylinders as they were firing, that motor made 529fwhp with that cam and it was only around 9.8:1 with nothing special BV 906 heads with a stock 440+6 bottom end and a crappy team G and an 850DP, best part in that motor were the HS roller rockers....
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Ray408G3Hemi]
#2682353
07/29/19 01:17 PM
07/29/19 01:17 PM
BradH
Any one have a sound clip of the 324 at idle ? As best as I can remember from listening to the BB Duster parked next to me in the pits one day: "RUMPity... RUMPity... RUMPity..."
[Re: rb446]
#2682728
07/30/19 02:43 PM
07/30/19 02:43 PM
Posts: 10,031 Frostbitefalls MN (Rocky&Bullw...
gregsdart
This cam was designed for big motors with crap heads. I had a 535 with 906 heads on it. About a perfect match.. stall it to 5,000, shift at 6000, maybe shorter . I would like to know what the running duration AT THE VALVE is at full lash. I bet it is a ton shorter than a guy would think.
[Re: gregsdart]
#2683128
07/31/19 02:41 PM
07/31/19 02:41 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ve never used one........ and I can’t imagine actually building something with the parts that are easily accessible these days, where that would end up being my cam of choice.
My understanding is they were designed at the request of Herb McCandless specifically for high CR bracket race 440’s with ported stock heads for guys who didn’t want the expense of a roller cam. (I see this thread in ancient....... and that this was already mentioned years ago).
They’re probably fairly well suited towards anything in that vein, as in....... high compression, race only, small heads.
