I have an aftermarket steering wheel on my 90 Dakota column. It uses a Grant center hub, and has been there for a couple of years. About 6 months ago, when it got hot (above 85 outside temp) I would get a short squawk when I turned the steering wheel to go around a corner. Now it does it all the time.
I've pulled to column out of the truck, dissembled it, cleaned everything up and greased both the upper and lower bearings and reassembled it. The squawk is still there! If I pull the hub, and install the factory wheel, the squawk is gone. If I reinstall the Grant hub, and leave it a little loose there is no squawk, but if I tighten it, the squawk is back. I have two Grant hubs here, both do the same thing, one is a new hub. I've compared and measured the ends of both hubs and don't find a reason for the squawk. Any one else experience this? How do I fix it, short of using the original steering wheel? Gene
