Modest upgrades to 5.7 daily driver #2095478
06/21/16 08:00 AM
06/21/16 08:00 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Considering some modest upgrades to my new ride (2012 R/T with manual trans) and surprised there doesn't seem to be much discussion on the board unless I'm using the search function wrong (again)
For Phase one: adding long tube headers, slightly cooler thermostat and a SRT-8 6.4 active intake manifold with SRT-8 air cleaner housing. The intake is noted for adding 20-30 ft/lbs to the 5.7 lower end and the headers are a nice 25+ hp bump. The factory SRT-8 airbox is very good and have no interest in "pipe with an air filter" kit.
Looking into tuner options now, appreciate any input.
Phase two would be an upgrade to 6.1 cam and springs and having the heads cleaned up modestly.
Thoughts? No interest in a blower or upgrading engine size. Just looking to upgrade power output without killing all gas mileage with the daily driver.
Car already has muffler delete out back.
"I think its got a hemi"
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2095562
06/21/16 11:38 AM
06/21/16 11:38 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
You can't use the 6.1 cam. Youll have to run a VVT style cam.
The first round of upgrades sounds good, but I don't think the intake is worth it. I really like the eagle intake that you've got now.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Modest upgrades to 5.7 daily driver [Re: AlexP] #2095784
06/21/16 06:18 PM
06/21/16 06:18 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Ah, I assumed the later 6.1 cam was VVT.
Good too know. Is there as decent aftermarket VVT cams?
On the intake I think the 25-30 ft/lbs of torque it provides to the wheels is worth the expense. If I'm going to spend a few hundred on headers to get 25-30 hp why not spend a few hundred for a better intake.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2095788
06/21/16 06:21 PM
06/21/16 06:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
A 392 cam is decent. I have one if you want it.
Mopar to the bone!!!
Re: Modest upgrades to 5.7 daily driver [Re: 72Swinger] #2095840
06/21/16 08:15 PM
06/21/16 08:15 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
6.4 cam and a real good tune should net you close to 100 with long tube headers.
Don't know if porting heads would be worth it.
Matt
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2095901
06/21/16 10:18 PM
06/21/16 10:18 PM
Central NC
gch Offline
gch  Offline
Central NC
Going to spend more than a few hundred on headers I would imagine.
Re: Modest upgrades to 5.7 daily driver [Re: gch] #2095919
06/21/16 10:55 PM
06/21/16 10:55 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
$470 for full length headers, chrome.
Re: Modest upgrades to 5.7 daily driver [Re: 72Swinger] #2095945
06/21/16 11:42 PM
06/21/16 11:42 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I just might be interested, is it an MDS camshaft?
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2096017
06/22/16 01:45 AM
06/22/16 01:45 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes it is an MDS cam so you would want the manual trans version with your 6spd. I remembered that right after I posted. I bought it to swap in my wifes '12 Charger.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2096215
06/22/16 01:42 PM
06/22/16 01:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would be interested in a cheap 6.1 or 6.4 cam for my motor and don't care if it is MDS, I don't think it is different enough to worry about unless you were going the other way around.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2096354
06/22/16 06:16 PM
06/22/16 06:16 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Well its either a VVT cam or a VVT w/MDS on the 392's and 09+ 5.7's. Either will work on a VVT engine but the 392 and 5.7 VVT cams for manuals are a little hotter lobes because they dont use MDS. A 6.1 cam is a non VVT or MDS cam.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2096399
06/22/16 08:41 PM
06/22/16 08:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have an 2003 5.7 block and an 2011 5.7 block, I can build whatever I get the best stuff for cheapest. But it sounds to me like gdonavan should buy that cam you got, maybe I am wrong?
Re: Modest upgrades to 5.7 daily driver [Re: HotRodDave] #2096424
06/22/16 09:47 PM
06/22/16 09:47 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I need a non-MDS cam with VVT.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2096577
06/23/16 01:35 AM
06/23/16 01:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You want the 392 manual cam or a Muscle Motors VVT cam. The 392 cam is usually worth about 30-40 RWHP in a 5.7. I have a 392 A8 cam because I wanted to retain MDS is wifes car.
Re: Modest upgrades to 5.7 daily driver [Re: HotRodDave] #2097371
06/24/16 02:31 PM
06/24/16 02:31 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I have one I will never use...... I bought it to upgrade my 09 5.7 jeep cam but did not realize I have VCT! I think it's from an 05/06 srt8...... I did buy a cheap 6.4 cam VCT that I Will install one of these days........ Get me at my screen name at the yaahoo site..... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2097464
06/24/16 04:18 PM
06/24/16 04:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
One of you want to PM me a price including shipping to my buisness address in 59901 zipper code?
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2097592
06/24/16 09:34 PM
06/24/16 09:34 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Anyone have links to a 5.7 on the dyno with a 392 camshaft? I'm told by one source it will turn the 5.7 into a pig downstairs.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2102359
07/02/16 03:44 AM
07/02/16 03:44 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I have a 5.7 manual 2010 challenger, this 392 cam sounds interesting. What's all would be needed parts wise. Exhaust tuner CAI catch can and tstat is all I run.
Mopar Performance
Re: Modest upgrades to 5.7 daily driver [Re: moparniac] #2102393
07/02/16 09:56 AM
07/02/16 09:56 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I have been reading some very conflicting info, I find it hard to believe it would make a 5.7 "a pig down low" since it is a fairly modest increase in lift and duration. I would NOT be surprised that it gives the 5.7 a shot in the arm considering in stock form the 5.7 makes peak power at 5300 rpm.
For a head that flows as much as it does that is a very low rpm and I'd wager the cam is the limiting factor. Dyno reports indicate as much as a 50 hp increase with a cam swap.
Re: Modest upgrades to 5.7 daily driver [Re: gdonovan] #2102526
07/02/16 03:45 PM
07/02/16 03:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Well anyone know the timing and lift specs on the 392 cam?
